The ridge height in the previously granted PP on our site and our revised planning application both have a ridge height of 6.4m, but not a single drawing states what the 6.4m height is taken from.  Is it taken as 6.4m from the road frontage, eg where your driveway starts from the highway?
As above The ridge is measured from
00 on your drawing (DPC)
Here is the topo survey that was done, lots of elevation points, but I cannot see the datum point which the ridge height / FFL is based off.
It should have been specified on your planning drawings. Something like; Floor level 122.65. If your architect hasn't made any reference to the FFL on the plans it might be worth confirming with the planners (to avoid any potential problems in the future).
You could assume that FFL would be 150mm above ground level (if you are building on a flat site) but this is not always the case.
Neither the revised planning application or the previously granted application specified any FFL measurement.   All very strange, as don't the planners want to know that?
With PD applications, they take the max ridge height from the highest point of the ground around the building.  Is there a planning condition requiring further details on height?
It is seldom clear and seldom questioned.
I think I had an unhappy neighbour complain to the council once.
We are talking 100mm or so.
It was very easy to show whatever was needed as long as it isn't a lot.
Reference to the origjnal ground makes most sense, and you could choose the highest point, esp as you of course usually build above that. But if you referred to floor level it would be OK.
The condition is not about 100mm but any large increase.
All our planning drawings were done with heights referenced to a temporary bench mark which was a row of nails driven into a fence post on the highest corner of the site.  That is still there.
Surely a ridge height is only important when it does not want to exceed that of neighbours.  Nobody ever checked any of our heights.
All my planning drawings state FFH at 88.75 which when referenced to the TOPO shows exactly where it should be.
you then take a fixed point from the TOPO like a manhole cover, for arguments sake, manhole at 87.75, so FFH  1m above that manhole, give or take a little bit, you generally bang a stake in well out the way and transfer all the crucial measurements to it, so you can then rip the site up and it doesn’t matter if the manhole gets disturbed.
I think this is a general loophole. In theory ridge height is from GL. Where’s GL? Unless it was specified on the PP drawings (not required by many LAs)  it’ s the highest point around the proposed building outline on your topo.  But the topo doesn’t cover every point on your plot, only some representative points. Once the topsoil has been stripped and the ground generally mangled by heavy machinery, where was it again?
3 hours ago, Alan Ambrose said:
where was it again?
It's so easy to specify.
I don't think planners are generally into such technicalities....eg that levels are easy to control.
Even when the height was  questioned during  planning apps,  numbers were not required. Show us a stick on site / show an artists impression.
