Adsibob Posted April 19, 2024 Share Posted April 19, 2024 (edited) After 25 months in the new house, we’ve had our first lightbulb fail, a GU10 6W non-dimmable. It was fitted in our understair loo, so no window to provide natural light. It probably gets switched on and off at least 5 times a day, some days more. Let’s say 6 in/offs on average, over 760 days (ignoring holidays when we are away). So 4560 on/offs and then it’s failed. In terms of hours on, the kids sometimes forget to turn it off, so maybe it’s running at most 4hr a day, so 3040 hours total. Should I feel conned that the bulb was marketed as lasting “up to 20,000 hours” or is the multiple on/offs a day the limiting factor here? Edited April 19, 2024 by Adsibob Link to comment Share on other sites More sharing options...
TerryE Posted April 19, 2024 Share Posted April 19, 2024 Well the old Tungsten bulbs were rated at a nominal 1,000 hours or about a year at 4 hrs / day. How many bulbs have you got? The weakness with these is that the cheap capacitors(s) in the voltage drop-down circuit can blow. Big Clive on Youtube did a teardown explaining the failure mode. 1 Link to comment Share on other sites More sharing options...
billt Posted April 20, 2024 Share Posted April 20, 2024 I'd guess that it's in a recessed down lighter fitting. If it is they tend to get warm which seriously reduces the life expectancy of LED bulbs. Link to comment Share on other sites More sharing options...
Kelvin Posted April 20, 2024 Share Posted April 20, 2024 It’s averages. All the other bulbs might last longer than 20,000 hours. Link to comment Share on other sites More sharing options...
ProDave Posted April 20, 2024 Share Posted April 20, 2024 At least you had the sense to fit light fittings where you can change the bulb. There is a growing trend for downlighters to have non replaceable bulbs. If anyone asks me to fit some (I would not buy them) I advise them to go and buy a box of spares, on the basis when one fails in a few years time, you probably won't be able to buy identical replacements. 2 Link to comment Share on other sites More sharing options...
Kelvin Posted April 20, 2024 Share Posted April 20, 2024 Yep. I disregarded all the built in bulb types and any downlights that are plastered in as nice as they are. 1 Link to comment Share on other sites More sharing options...
bassanclan Posted April 20, 2024 Share Posted April 20, 2024 1 hour ago, ProDave said: At least you had the sense to fit light fittings where you can change the bulb. There is a growing trend for downlighters to have non replaceable bulbs. If anyone asks me to fit some (I would not buy them) I advise them to go and buy a box of spares, on the basis when one fails in a few years time, you probably won't be able to buy identical replacements. I wish someone had told my electrician this! He fitted Saxby downlights. £10-12 each and they haven't lasted 18 months. I will systematically change them over time 2 Link to comment Share on other sites More sharing options...
joe90 Posted April 20, 2024 Share Posted April 20, 2024 1 hour ago, ProDave said: At least you had the sense to fit light fittings where you can change the bulb. Slightly different but a relative has had her LED headlight fail on her car the LED,s are built in it and just the headlight unit is over £800 (I am glad I drive an old banger with halogen bulbs 🤷♂️). Link to comment Share on other sites More sharing options...
ProDave Posted April 20, 2024 Share Posted April 20, 2024 33 minutes ago, joe90 said: Slightly different but a relative has had her LED headlight fail on her car the LED,s are built in it and just the headlight unit is over £800 (I am glad I drive an old banger with halogen bulbs 🤷♂️). That is criminal, I thought things had to be "repairable" now? That's one more thing on the list to check next time I buy a car. Link to comment Share on other sites More sharing options...
Onoff Posted April 20, 2024 Share Posted April 20, 2024 43 minutes ago, joe90 said: Slightly different but a relative has had her LED headlight fail on her car the LED,s are built in it and just the headlight unit is over £800 (I am glad I drive an old banger with halogen bulbs 🤷♂️). And I thought my Mondeo was a pain needing a T30 torx and a Phillips to change a bulb. Link to comment Share on other sites More sharing options...
Onoff Posted April 20, 2024 Share Posted April 20, 2024 I reckon the pot hole repairs round here last longer than the LED stuff (all makes) I've fitted. Green washing the lot of it. 2 Link to comment Share on other sites More sharing options...
joe90 Posted April 20, 2024 Share Posted April 20, 2024 1 hour ago, ProDave said: That is criminal, I thought things had to be "repairable" now? Yes I agree, but the new “repairable “ was brought in more recently than her car was made, plus I am sure the manufacturer would say replacing JUST the headlight is a repair 🤷♂️ Link to comment Share on other sites More sharing options...
ProDave Posted April 20, 2024 Share Posted April 20, 2024 7 minutes ago, joe90 said: Yes I agree, but the new “repairable “ was brought in more recently than her car was made, plus I am sure the manufacturer would say replacing JUST the headlight is a repair 🤷♂️ Then they need to supply parts at a reasonable price. There are 2 headlights in a car (sometimes more) I simply do not believe at manufacture time they cost £1600 which would have been more than 5% of the cost of the car (possibly a lot more) 2 Link to comment Share on other sites More sharing options...
Adsibob Posted April 20, 2024 Author Share Posted April 20, 2024 (edited) 5 hours ago, billt said: I'd guess that it's in a recessed down lighter fitting. No, it is in a down lighter, but the down lighter is surface mounted. There doesn’t seem to be any ventilation to the base of the down lighter. It’s basically this: https://www.commerciallightingbyrightlights.co.uk/one-light-12105mbbs-brushed-brass-gu10-10w-dark-light.html?utm_term=&utm_source=google&utm_medium=cpc&gad_source=1&gclid=CjwKCAjwz42xBhB9EiwA48pT75xTxg5FDhWUFUgLOexHikOUfwUMHcnyLNH1MxIbpJOgs0kCf-4B-xoCMl0QAvD_BwE as you can see, that is designed for up to 10w GU10 bulb, and I was only using 6w. The replacement I fitted is only 4.3w, so let’s see if that lasts any longer. Just a bit pissed of because the original light bulb was quite expensive, £10 or so. Not all of the ones I’ve fitted are that expensive, but for some fittings we used what we thought were high end bulbs with high CRi index and particular beam angles (I a this one was 25 degrees, which is what bumped up the price). Edited April 20, 2024 by Adsibob 1 Link to comment Share on other sites More sharing options...
saveasteading Posted April 20, 2024 Share Posted April 20, 2024 Didn't the cheap ones used to be made with glued connections instead of solder and it melted? They also used to have great big metal heatsinks ( or pretend ones in plastic) but don't any longer. Link to comment Share on other sites More sharing options...
ProDave Posted April 20, 2024 Share Posted April 20, 2024 I think the LED GU10's I have were Screwfix cheap ones (probably LAP) sold in boxes of 10 for about £1 per lamp. Only 2 failed so far in nearly 5 years. Link to comment Share on other sites More sharing options...
Mattg4321 Posted April 20, 2024 Share Posted April 20, 2024 The expensive ones are no better than the good quality ‘cheaper’ ones. No need to spend more than £2-3 1 Link to comment Share on other sites More sharing options...
Andehh Posted April 20, 2024 Share Posted April 20, 2024 We fitted 22 LAP down lighters in our soffits from screwfix last summer, and 5 have failed so far!! Bloody things, some are 5m high to access. Link to comment Share on other sites More sharing options...
Mattg4321 Posted April 20, 2024 Share Posted April 20, 2024 I generally steer clear of LAP. It rhymes with a good description of its quality. GU10 lamps are meant to be quite good, and I’ve heard that from a few sources. Integrated downlights - not good. Switches and sockets are comically bad. Link to comment Share on other sites More sharing options...
SteamyTea Posted April 20, 2024 Share Posted April 20, 2024 what does LAP stand for? Link to comment Share on other sites More sharing options...
CalvinHobbes Posted April 20, 2024 Share Posted April 20, 2024 This is so helpful. I was going to buy spots or downlights and will now make sure the bulb can be swapped out and will avoid LAP. Thank you. Link to comment Share on other sites More sharing options...
Mattg4321 Posted April 20, 2024 Share Posted April 20, 2024 59 minutes ago, SteamyTea said: what does LAP stand for? Rhymes with… c… Link to comment Share on other sites More sharing options...
Mike Posted April 20, 2024 Share Posted April 20, 2024 20 hours ago, Adsibob said: Should I feel conned that the bulb was marketed as lasting “up to 20,000 hours” A lifetime of '20,000 hours' is most likely referring to the 'catastrophic failure rate', often 10%, under which no more than 10% of the bulbs should fail within that time. But someone has to buy the ones that make up that 10% - looks like it could have been you 41 minutes ago, CalvinHobbes said: I was going to buy spots or downlights and will now make sure the bulb can be swapped out For a step-up from GU 10s, without going to sealed units, take a look at @Carrerahill's tip of using Tridonic LED modules. I'll be installing a batch over the next few weeks. The only sealed lights that I'm installing are are in-floor uplighters by Collingwood Lighting - expensive but they've a good reputation. Link to comment Share on other sites More sharing options...
Adsibob Posted April 20, 2024 Author Share Posted April 20, 2024 4 hours ago, Andehh said: We fitted 22 LAP down lighters in our soffits from screwfix last summer, and 5 have failed so far!! Wow, that’s barely 10 months’ use! Link to comment Share on other sites More sharing options...
Onoff Posted April 20, 2024 Share Posted April 20, 2024 3 hours ago, SteamyTea said: what does LAP stand for? LEDs Are Pants? https://www.kingfisher.com/en/own-exclusive-brand.html 1 Link to comment Share on other sites More sharing options...
