Scotland has banned Wood Burners in new homes and conversions
Heat loss from (cavity) party walls has been in the Regs for many years - all linked to air movement within, into and out of the cavity. Fully filling with mineral wool and sealing the wall edges are deemed to give zero U-value. Description here
Thermal Mass is actually 'thermal mass parameter' used within SAP. Based on the heat capacity of internal linings (kJ/m2K), area of each element and total floor area. In older versions of SAP it was broadly classified as low, medium or high depending upon construction method but now has to be calculated more precisely.
On 10/04/2024 at 11:43, saveasteading said:
Wood-burning stoves and other heating systems that cause emissions can also still be installed in new homes to provide emergency heating, where a need can be justified – responding to feedback from rural communities.”
Repeated for anyone who has started at the end of the discussion.
This makes every sense. Any new housing must have ashp or similar. Wbs can be added but must be justified. e.g   if your house is 2 miles up a track it will be one of the last to get power restored after a storm.  Explain to the  bco and it should be ok.
Likewise if your electric supply is unreliable.
I used to look at the 'woodburners forum' on facebook and it demonstrates the worst of wbs. People who used it as their only space heating, coming home with whatever they could find. pallets, chipboard, tanalised waste, just anything.. If it's free, burn it.
That's why it needs a rule.
The ONS has some numbers on heating types.
Here is a quick analysis for England.
Type of central heating in household (13 categories) Number
No central heating 367119
Mains gas only 18298730
Tank or bottled gas only 260108
Electric only 2113123
Oil only 865944
Wood only 35720
Solid fuel only 49469
Renewable energy only 98729
District or communal heat networks only 220893
Other central heating only 225399
Two or more types of central heating (not including renewable energy) 2113324
Two or more types of central heating (including renewable energy) 134659
I do hope it's implemented this way. Our local (SNP) MSP has been pretty critical about this.
I wonder how much leeway individual councils will have?
The environmental and health hazards associated with wood burners, particularly the PM2.5 emissions, cannot be ignored. As the attached image clearly demonstrates, traditional wood burners emit a significant amount of these fine particles compared to other heating methods. PM2.5 particles pose a serious health risk as they can penetrate deep into the lungs and are linked to a range of ailments, from respiratory issues to heart disease.
Furthermore, the idea that gas boilers could be banned for their emissions while wood burners remained permissible was a point of contention for me. Gas, in comparison to solid fuels, burns much cleaner.
The real concern is in urban settings where houses are in close proximity. Here, wood burners can essentially "gas" neighbors with pollutants, especially when users are burning wet wood or treated materials like pallets, which release even more harmful substances. I would advocate for a rule that only allows open fires or wood burners in properties that are a significant distance from others, perhaps 100 meters or more, to prevent this kind of neighborhood pollution.
Apart from this bit. Like @Kelvin says.
Our PHPP predicts 2625kWh/m2/Annum at the moment.
If I put the limiting values in for Air permeability and ditch the MVHR it goes to 7525kWh.
It really is the lowest hanging fruit. Far more so than super insulation.
We were talking about this earlier.
Over the last perhaps 10 years, around us all public buildings like schools, leisure centres have moved over to wood pellet boilers for their heating.   So now the Scottish Government have banned such things, will we see these now replaced with heat pumps?
58 minutes ago, Gus Potter said:
Look folks. What is happening in Scotland has nothing to do with science and all to do with political ideology.
Trying to rationalise this is not achievable.
I disagree. I think it's a knowingly unpopular move led by clear science on particulate emissions.
But let's just agree to disagree on this.
  • Like 3
Sure but the argument is that the impact of wbs in rural homes is minimal. I’m with you but I can understand the other side of the debate for rural houses. The house we rent is freezing. You’d have to set it alight to heat it. It does have a wbs and we get free seasoned wood from the farmer which is all produced on the farm. But I hate the thing. It’s makes a mess, the heat is hard to control, the air quality in the room it’s in isn’t great etc.
6 minutes ago, SteamyTea said:
Not as you mention later on, on indoor air quality.
Indeed but I meant the impact on the outside air quality.
The only argument my wife and I had about the house build was over the fitting of a wbs. She loves them and wanted one in our house. Not for any practical heating reasons more because of the romance and cosiness of a real fire on the worst winter days when it’s blowing a gale outside.
@Kelvin and @Iceverge have, IMHO highlighted the glaring omission. Just using the heat loss calculation spreadsheet easily shows the importance of airtightness.
Once you plug in the required U value, even slight improvements in airtightness have real positive impacts on heating requirements. Even to a point where lesser levels of insulation can still achieve lower running costs with better airtightness.
I think the changes should have focused more on heat loss giving the designer more flexibility to balance u values and airtightness to achieve an efficient solution.   The cynic in me would suggest a bit of lobbying from the expensive insulation manufacturers added more weight to the argument.  For my build Airtightness was, in material costs,  relatively inexpensive to achieve, but labour and attention to detail expensive. And "no body" would be lobbying for that.
My cynical view too. Plus better insulation is easier to understand for the average home buyer and easier to achieve for your average builder. I also think some of this is because they knew that setting a much better airtightness target wouldn’t be achievable by the building industry. Also when you get to three or below you increasingly need active ventilation which adds to the complication and cost. An opportunity missed imo.
They have changed the ventilation as well.
