Declan52 Posted September 30, 2016 Posted September 30, 2016 My four stages with the ulster bank where, 1st wall plate, 2nd roof on, 3rd plastered out, 4 th complete. Each cert than my architect wrote out went something like, I can confirm that following an inspection of the building at, house address, it has been plastered out and the building is in accordance with building regulations.
Declan52 Posted September 30, 2016 Posted September 30, 2016 Forgot to add mine is a two storey building so the stages are slightly different to a single storey. Also I only had the inside plastered out. They weren't concerned with the outside not being plastered.
vfrdave Posted October 5, 2016 Posted October 5, 2016 Wall ties and their cost. Is there a huge cost differential going beyond a 125mm cavity for wall ties, few places advertise prices so thought is easy to ask here for those currently building. @DeeJunFan @JamieM
JamieM Posted October 5, 2016 Posted October 5, 2016 Sorry @vfrdave I cant remember. There was quite a difference between the steel ones and the teplo wall ties. In the end i just went with the steel ones (my cavity was just 150mm)
JamieM Posted October 5, 2016 Posted October 5, 2016 Copied below from ebuild which may be of help (posted july 2014) Teplo wall tie for 200mm cavity ~£1.75 each GRP wall tie for 200mm cavity ~£1.28 each (200mm cavity max) Stainless steel wall tie for 225mm cavity ~£0.62 each http://www.ebuild.co.uk/topic/13941-cavity-wall-in-new-build/page__p__93473__hl__teplo#entry93473
Kev106 Posted October 5, 2016 Posted October 5, 2016 I paid 46p + vat for a 350mm stainless steel wall tie last July. I would imagine they're still about the same. 1
vfrdave Posted October 5, 2016 Posted October 5, 2016 On 05/10/2016 at 18:08, Kev106 said: I paid 46p + vat for a 350mm stainless steel wall tie last July. I would imagine they're still about the same. Expand Any idea where you got them?
Lolliedog Posted October 5, 2016 Posted October 5, 2016 There is a company in Limerick (Southwest Ireland) that manufactured wide stainless wall ties. I have no idea what of cost, but I'd imagine they are reasonable priced. The company is Shannon coiled springs if anyone wants to check them out.
Shell820810 Posted October 5, 2016 Posted October 5, 2016 (edited) Try vartry engineering in Wicklow or wexford Edited October 5, 2016 by Shell820810
Kev106 Posted October 6, 2016 Posted October 6, 2016 Clady Timber, Portglenone or Mackles building supplies Toome.
Kev106 Posted October 10, 2016 Posted October 10, 2016 It may be different now but that's what I paid a year ago. Most of the other prices I got were 65p +.
Ryan85 Posted October 10, 2016 Posted October 10, 2016 Folks in terms of NIE doing the final connection how pinnickidy are they? my spark has 90% of the work done bar a few pendants and low level lights. Will they still switch the power on if I put block connectors on the remaining cables.
vfrdave Posted October 21, 2016 Posted October 21, 2016 Got my NI Water connection price through, on the face of it its not too bad:- Connection: £888 Building Supply: £20 Infrastructure Charge Water £314 Total: £1222 What confuses me is they have stated that the watermain is 27.47 meters from my property. My house will be alot more than that distance from the road. From my boundary to the watermain, which is the other side of the road, would be 5.5m. I do recall others having issues like this @slidersx200 definitely mentioned something similar on ebuild but I couldnt find an outcome. Going to phone them and query but thought I would ask the wise on here first.
Weegaz Posted November 14, 2016 Posted November 14, 2016 Evening folks, our new build is coming on rightly, timber frame is up, roof on and external block work going up. we have to get a decision made on heating and current proposal is ashp, ufh to both floors and mvhr system. It seems good setup and visited a few properties with same system installed. Before I make the decision has anyone any comments on system or installed and can give feedback?
vfrdave Posted November 14, 2016 Posted November 14, 2016 What system are you thinking of putting in?
Guest Alphonsox Posted November 15, 2016 Posted November 15, 2016 We have a similar system but have chosen not to install UFH on the first floor. This decision was reached on the basis that the house is near passive spec so the UFH wont be needed too often. We also like thick bedroom carpets which are not a good mix with UFH so instead we are using small electric panel radiators to take the edge off if and when required.
Weegaz Posted November 15, 2016 Posted November 15, 2016 Currently we are working with a company who will supply and install:- Hitachi Yutaki Monobloc ASHP 11Kw 300l unvented cylinder UFH to both floors Electric / plumbed towel rads to main bathroom, en suite and WC Zehnder Comfo MVHR Central Vacuum System
Shell820810 Posted November 29, 2016 Posted November 29, 2016 Airtightness testing - recommendations and prices please?
Weegaz Posted December 6, 2016 Posted December 6, 2016 Has anyone any contacts for safety glass for the side of stairs and a balcony?
Ryan85 Posted December 6, 2016 Posted December 6, 2016 On 06/12/2016 at 10:30, Weegaz said: Has anyone any contacts for safety glass for the side of stairs and a balcony? Expand Try top glass in Toome.
Ryan85 Posted December 6, 2016 Posted December 6, 2016 On 29/11/2016 at 10:36, Shell820810 said: Airtightness testing - recommendations and prices please? Expand I'm using Atlantic air for mine. Having the test carried out towards the end of next week. They are usually 200 for the air tightness test Shell.
Declan52 Posted December 6, 2016 Posted December 6, 2016 Spotlight tonight all about the rhi scheme, should be a good watch.
ProDave Posted December 6, 2016 Posted December 6, 2016 On 06/12/2016 at 14:14, Declan52 said: Spotlight tonight all about the rhi scheme, should be a good watch. Expand Thanks for the heads up. I will watch or record that. I assume NI has the same RHI scheme as the rest of the UK? I mentioned in another thread a friend of mine has paid £16K to have an air source heat pump installed. I calculated the parts cost and a reasonable estimate (no a generous estimate) of the labour it took to install it would work out at £6K. Therefore it appears to me he has paid a £10K premium to have it installed by a registered company in order to claim the RHI payments, which I hope for his sake add up to a lot more than £10K
joe90 Posted December 6, 2016 Posted December 6, 2016 That's the reason I decided to not bother with RHI.
