rail/track saw options
Alexx
I was looking at an entry level track saw or rail saw (not sure what is the best name) and I was eyeing the Evolution  R185CCSX+ as it seems to be a interesting DIY option. The saw cost £90, the 2800mm tracks cost £77, but when I started checking the reviews of the track, it seems to be crap, not accurate. As I'm planning to start doing a lot of DYI and get more into woodwork, I was hoping to get something that is not crap, but also not expensive. Is there something decent around the £150-£250 mark for a saw + track of decent size or should I be aiming at a lot more?
Correct term is plunge saw …
What are you cutting with it and what length are you looking for..? Keep an eye on Facebook market place as decent 110v makita ones come up for £100-150.  Evolution are rubbish, Rutland not much better.
If you have a decent circular saw then the Kreg kit is nice and not expensive.
https://ffx.co.uk/product/Get/Kreg-Kma2700-647096807177-50In-Accu-Cut-Circular-Saw-Track-Guide
Thanks! I started looking for plungesaws, it seems I may be better off getting a second hand on ebay, still looking for a good deal
  • 3 months later...
I have the makita plunge saw....its goods, but same as Istevensuk, the tracks are naff. One has a slight cup to it, so the saw can wobble ever so slightly, no amount of adjustment seems to get it to cut consistently.
The other thing I don't like about it is the track length. When cross cutting an 8 x 4' the track is too short, unless you're at maximum plunge depth. The track adjustment knob (used to take the sidways movement out from between the saw and rail) just slips off the rail end, leaving a crappy cut for the last few cm. Very annoying.
  • 2 weeks later...
I got a scheppach plunge saw again the tracks aren't the best.  To be fair the only time where I've really needed to use the track rather than using my dewalt circular saw and cutting by eye was trimming some granite work tops. I ended up thinking I'd have been better served just buying a better skill/circular saw.
On 13/08/2022 at 11:58, Big Jimbo said:
I have got the Festool and the 2 1400mm tracks that join together for cutting longer boards. Expensive but very good
Same here, very happy with the tracks and good resale prices should I ever want to get rid.
I have got the Festool and the 2 1400mm tracks that join together for cutting longer boards. Expensive but very good.
I have those tracks too, mostly used with the Festool HK85 rather than the TS plunge version. I have the Mafell plunge saw which uses both the Festool tracks and the Mafell tracks. After 4 years of use I found the Festool tracks to be really robust apart from the splinter guard which always peels off. The biggest issue is aligning them even with the self-aligning connectors I bought. Always have to check with a straight edge, especially for 2nd fix and making cupboards/cabinets and then if you knock them while moving about...... Overall I'd have to say I prefer the Mafell track system, which I think Bosch also uses.
6 hours ago, SimonD said:
Mafell
I've heard and read very good things about Mafell though never used any of their kit. I only use mine on 1st fix, any inaccuracy in the kit would be more than offset by my skills 😬
I really liked my Festool HK85. It was a beast until I experienced the so called 3 year service included service from Festool. My experience from this was that they do the absolute minimum they can. My HK85 went back twice and the second time I was getting some pretty bad noises and vibration from the saw within a few weeks of receiving it back from them the first time. The second time it came back supposedly fixed but with smaller noises and vibration and very much not right - the cutting blade vibrates slight against the saw body when you start it up but apparently this is fine by them. Funnly enough, if you send the same product back after the 3 year service has expired they'll charge you for making the saw like new. After this experience, I won't be buying Festool again.
I've found my Mafell to be very robust and if I was going to buy a cheaper saw I'd probably opt for the Bosch GKT 55 as it is essentially a Mafell with some differences.
57 minutes ago, joe90 said:
I have never had a track, I use a long straight edge (a piece of ply) two clamps and mount it xy mm from where I want the cut, works great.
Same here. I made the mistake of buying a stand-alone, clamp on track from Lidl. At only 1m long it's no good on an 8'x4' board!
 Peter Millard has some lovely videos about selecting and using track saws -
  • 4 weeks later...
Hi @AdamSee can I check which length of track you were using for the cross cut? I think Makita do 1400mm and 1500mm lengths? Were you using the 1400mm? Keen to know as I need to buy some track soon. Thanks
Remembered to check today. The tracks I have are 1400mm long. Explains my issue with them.
