So...
Running the 16mm Pex-Al-Pex around to where the rad is.
2016-12-10_10-47-12
I'm using a 16/15 elbow:
20161210_223126
So it'll end up like this, two stubs of 15mm copper poking through the plasterboard at 965mm centres ready for the rad.
20161210_222952
The thing is, the next step is to put the vcl on the wall and then the plasterboard so I WON'T be getting to these compression joints again! Assembling with a smear of Jet Blue Plus btw. Should I test them somehow or just take a chance?
Expand
Look, I get very little excitement in my life so the adrenaline rush from taking chances like this is welcome! ;)
You've answered your own question!!
20161210_223126
Expand
If that is going to be visible do you not have any chromed copper lying about as it always looks a bit neater ....
Expand
Good point, thanks for the reminder! Yes I have some. I'd put it to one side and forgotten about it tbh as at one time I was looking at push fit fittings which don't play nicely with chromed copper.
Tempted once the two lengths of Pex and chrome tails are in, to temporarily bridge the chrome tails to form a pseudo loop and use my (Welsh designed :) ) test rig to prove those elbows:
SAM_3340
  • Like 3
I do so wish I'd planned for the pipes to the towel rad BEFORE I cast the floor slab! :(
I need to get the pipes to it under this wall (where the tape is) and run parallel to the UFH pipes that are in the grey foam insulation for protection until I dig up the adjacent floor.
20161211_211213
Got as far as a 125mm core cutter through the first 2" of the slab then a 127mm Starrett through the A142 mesh.
20161211_211250
20161211_211604
Not sure whether to try and bend the Pex-Al-Pex or just get two elbows?
  On 11/12/2016 at 22:22, Nickfromwales said:
Use elbows ;). That way you won't be grazing the pipe on the concrete whilst trying to wrangle it in.
Expand
Ta. I wasn't looking forward to gingerly bending it back on itself then threading down the hole. It'd be one minimum bend radius followed by another.
Then, in two minds whether I need to insulate these pipes to the rad or not. On the one hand I can't see the point of heating the boxed in space under the bath...might be detrimental to the pump motor too. Or should I leave them uninsulated so the (big) bath doesn't lose heat so quick when full?
Where they go thru the slab I'll either thread them through some 20mm flexible conduit then make good the concrete or run thru some 15 mm pipe insulation and again make good.
Heat from those pipes will be the square root of naff all - pump motor will get hotter from the bath above than that pipe ...
Expand
OK, I'll insulate then on the basis of cutting down losses to the rad. Cheers.
On the subject of insulation and keeping the bath warm I'm thinking to infill between these studs on the long side of the bath:
20161125_204951
Currently behind that vcl is 50mm of Celotex then the cavity wall. I've some 100mm off cuts that I'm looking to use up. Or would some 50mm EPS doubled up be better. Thinking that Celotex is a bit noxious smell wise in a warm environment.
Double up on the EPS and save the good stuff for elsewhere. It's not exactly going to be hot against cold under the bath ;)
You could just drill a half inch hole in the side of the boxing in, after fitting the bath, and squirt a dozen cans of exp foam into the void :D
Pleased with the "rigidity" of the tap adapters through the ply/stainless backing plates. All seems good and solid.
Now a couple of random plumbing questions:
1) Using chromed copper pipe is there any difference if using copper or brass olives? The brass ones that came with the 15/16mm elbow were a real tight fit. They went on, eased by a smidge of Jet Blue Plus but I wasn't sure they were going to!
2) Pushing the Pex-Al-Pex elbow onto the Pex was quite hard. I worried it was starting to lift the first O ring out of it's groove so I countersunk the end of the Pex a tad. Right or wrong? I also gave a little squirt of silicon spray to ease it in.
20161212_161743
20161212_161839
With hindsight I'm sure there was an easier way of feeding this rad but with no proper flow and return anywhere near...
20161212_181118
Anyway, getting the "economy" thickness insulation on the Pex-Al-Pex:
20161212_181225
16mm Pex-Al-Pex is a bloody tight fit in 15mm pipe clips and the retainers won't snap into place. All for 1mm! Who knew! Think I'll just snap them off.
2016-12-12_06-19-35
The more I try and "plumb" properly the more I respect those who do it for a living. God knows why there's the historic plumbers vs electricians issues (aside from scorched T&E ;)).
Like the old vampires vs werewolves thing I guess, they're both pretty bad ass! :)
Edited by Onoff
Using up some 50 & 25mm EPS. 50mm first and I should get a cover of 25mm over that:
20161212_203148
20161212_203256
20161212_203215
Edited by Onoff
Wouldnt it be better for any heat loss from the pipes to be lost under the bath so perhaps not covering the pipes with insulation?  I always pack the space under a bath with loose insulation - I think it helps keep the water warm for longer
CC
CC
Expand
I was thinking not to add any more heat under the bath for the sake of the pump motor.
Slowly does it... :)
The slab broke out quite neatly so I'll be able to get two runs in though might have to chop the Polypipe tray a bit.
A bit of scrap pipe in just to gauge things but looks like the elbows will fit fine.
20161213_222459
20161213_222509
20161213_222551
Then sleeve the pipes and make good!
Edited by Onoff
Bugger!
I've bought these 15mm x 3/4" to go on the taps:
But they're too big diameter wise to fit down the adapter bosses unless I trim off the lugs:
SAM_4301
Or do I cut my losses and get these (again Hepworth) ones?
Well they fit down the adapter a treat!
20161215_151939
20161215_152117
Guess the spare conical rubber washers are if you have tap tails that are slightly countersunk?
20161215_152027
Half a dozen Pex-Al-Pex adapters came in the post today so I've run the towel rad feeds. Going to insulate them before I concrete.
20161215_192804
20161215_192640
Christ knows how tight you do these elbows up? Being built like Burt from The Big Bang Theory I have a habit of breaking things! :ph34r:
(It's Doom Bar btw).
20161215_192804
20161215_192640
So...the plan is that these lengths of Hep2O PB will "pivot" up and down to feed the taps and allow their removal:
20161215_213143
20161215_213204
