eandg Posted April 12, 2021 Share Posted April 12, 2021 Not sure where to start with getting quotes from fitters (any recommendations for fitters in west central Scotland welcome) for 11 windows totalling 25.66m2, three doorsets (including front door with side panelling, sliding door and rear door) totalling 12.84m2. Any ballpark estimates - I've had one quote so far provided by a potential supplier for more than £5k, not including any plant required and ancillaries, which instinctively sound very expensive? Link to comment Share on other sites More sharing options...
Gus Potter Posted April 12, 2021 Share Posted April 12, 2021 Are you having a full finish.. by that I mean are they doing a full timber finish or are they just fitting a window into a hole in a kit and leaving it at that? Also, what kind of doors? Are they bifold or sliding / plastic or aluminium? How big are the doors? Some big sliding door glass can take four folk to fit as the glass is heavy and expensive. Link to comment Share on other sites More sharing options...
eandg Posted April 12, 2021 Author Share Posted April 12, 2021 4 minutes ago, Gus Potter said: Are you having a full finish.. by that I mean are they doing a full timber finish or are they just fitting a window into a hole in a kit and leaving it at that? Also, what kind of doors? Are they bifold or sliding / plastic or aluminium? How big are the doors? Some big sliding door glass can take four folk to fit as the glass is heavy and expensive. Just fitting. Joiners will do internal reveals etc. Front and rear doors standard sizes, sliders 3000x2100. 3G aluclad. Link to comment Share on other sites More sharing options...
jamieled Posted April 13, 2021 Share Posted April 13, 2021 Is there any reason you're not asking the joiners to do it? Link to comment Share on other sites More sharing options...
eandg Posted April 13, 2021 Author Share Posted April 13, 2021 1 hour ago, jamieled said: Is there any reason you're not asking the joiners to do it? I thought it was separate trades. I've got a partitioning firm doing some framing then cabinet makers lined up for the internal reveals - haven't yet spoke to a finishing joiner as that's a way down the line at hanging doors (I think!). Link to comment Share on other sites More sharing options...
jamieled Posted April 13, 2021 Share Posted April 13, 2021 Most decent joiners round here can fit windows. Having said that you're taking a slightly different approach to me as I'd use a joiner for all those tasks! 1 Link to comment Share on other sites More sharing options...
TonyT Posted April 13, 2021 Share Posted April 13, 2021 One joiner to fit everything, otherwise the window fitter will fit stuff and then the next guy will complain about what he did and so on. joiner all day long. and give them a spec of what you want done, so it’s fitted the way you want, so that way no arguments later. Link to comment Share on other sites More sharing options...
ProDave Posted April 13, 2021 Share Posted April 13, 2021 I am paying £600 (hopefully this Friday) to have 4 windows and a 3M sliding patio door set fitted. That's just to fit the windows in the frame, I will be detailing inside (plasterboard) and outside (timber cladding) It's more because it's a 3 / 4 man job to lift them, particularly the patio door set, that I am paying labour to do this rather than DIY. Ground floor, my own scaffold set up outside. Link to comment Share on other sites More sharing options...
craig Posted April 13, 2021 Share Posted April 13, 2021 Between £250 and £350 per man per day is the going rate. Any joiner can install a window, however, not always to the manufacturers specifications. That's when arguments about install v's product occur, if anything goes wrong. Link to comment Share on other sites More sharing options...
recoveringbuilder Posted April 13, 2021 Share Posted April 13, 2021 3 hours ago, eandg said: I thought it was separate trades. I've got a partitioning firm doing some framing then cabinet makers lined up for the internal reveals - haven't yet spoke to a finishing joiner as that's a way down the line at hanging doors (I think!). Think you’re complicating things for yourself, roughing joiners can usually do kit erection, window fitting and partitioning plasterboarding etc and finishing joiners for all your doors , skirting , reveals etc Link to comment Share on other sites More sharing options...
Thorfun Posted April 13, 2021 Share Posted April 13, 2021 7 hours ago, craig said: Any joiner can install a window, however, not always to the manufacturers specifications. That's when arguments about install v's product occur, if anything goes wrong. I’m getting the manufacturer to fit for this exact reason. I’ve no doubt I could find someone to do it cheaper but our windows are a high % of our total build costs (approx 120m2 of 3G glass iirc) and I only want a single point of contact for the purchase, delivery, installation and support. I’m happy to pay that premium to reduce the risk on this big ticket item. 1 Link to comment Share on other sites More sharing options...
eandg Posted April 13, 2021 Author Share Posted April 13, 2021 6 hours ago, recoveringbuilder said: Think you’re complicating things for yourself, roughing joiners can usually do kit erection, window fitting and partitioning plasterboarding etc and finishing joiners for all your doors , skirting , reveals etc I've asked the partitioning firm (which employs roughing joiners) - they're doing boarding and framing. The current plan is for the cabinet makers who will do the window reveals and potentially stairs and kitchen units to fit them. Then I guess we'd need another finishing joiner for doors, skirting etc. Will look at streamlining! Link to comment Share on other sites More sharing options...
gaz_moose Posted April 14, 2021 Share Posted April 14, 2021 in the midlands people would be paying around £1600 supply and fit for a composite front door. what windows are you having fitted, Link to comment Share on other sites More sharing options...
ProDave Posted April 16, 2021 Share Posted April 16, 2021 Mine fitted today. It took 5 hours and cost me £400 That big slider was a good 4 man lift and we had the help of a friend plus me to give some grunt. More pictures on my blog if you want, direct link. http://ardross.altervista.org/Wilowburn/the-sun-room/ Link to comment Share on other sites More sharing options...
Mr Punter Posted April 16, 2021 Share Posted April 16, 2021 15 minutes ago, ProDave said: That big slider was a good 4 man lift and we had the help of a friend plus me to give some grunt. Could you decouple it or was it the whole thing? Is it lift and slide operation and is it smooth / easy operation? Link to comment Share on other sites More sharing options...
ProDave Posted April 16, 2021 Share Posted April 16, 2021 10 minutes ago, Mr Punter said: Could you decouple it or was it the whole thing? Is it lift and slide operation and is it smooth / easy operation? We removed the slider to reduce the weight for install, and just the fixed pane and frame was heavy enough. Then lifted the slider back in. It's lift and slide, turning the handle lifts it up onto the rollers and it slides easily but it is a big lump of window. Just shy of 3M wide so the sliding pane is probably about 1.4M wide and 2.1M high triple glazed. 1 Link to comment Share on other sites More sharing options...
Makeitstop Posted April 16, 2021 Share Posted April 16, 2021 29 minutes ago, ProDave said: We removed the slider to reduce the weight for install, and just the fixed pane and frame was heavy enough. Then lifted the slider back in. It's lift and slide, turning the handle lifts it up onto the rollers and it slides easily but it is a big lump of window. Just shy of 3M wide so the sliding pane is probably about 1.4M wide and 2.1M high triple glazed. Can I ask who manufactured the slider and what system is used for the framing? Link to comment Share on other sites More sharing options...
Makeitstop Posted April 16, 2021 Share Posted April 16, 2021 Sorry, can see on the sticker now... Oops Link to comment Share on other sites More sharing options...
Bonner Posted April 16, 2021 Share Posted April 16, 2021 2 hours ago, ProDave said: More pictures on my blog if you want, direct link They look great, are they Alu-clad? What colour please, inside and out? Link to comment Share on other sites More sharing options...
ProDave Posted April 16, 2021 Share Posted April 16, 2021 59 minutes ago, Bonner said: They look great, are they Alu-clad? What colour please, inside and out? Yes Ali clad, Rationel Aura Plus. What they call Pebble Grey, same colour inside and out. I can look up the RAL number if you need. 1 Link to comment Share on other sites More sharing options...
Bonner Posted April 16, 2021 Share Posted April 16, 2021 RAL 7032 according to the Rationel catalogue. That is one of the colours I was looking at, good to see it on real window frames rather than just a swatch. Link to comment Share on other sites More sharing options...
ash_scotland88 Posted April 16, 2021 Share Posted April 16, 2021 I received a quote today for replacing single glazing with double. Think it's 20 windows but about 8 of them are "duplicates" £28k! Had a supply only quote for £12 from a company but they can manufacture to a custom design. Link to comment Share on other sites More sharing options...
