February 3, 20179 yr Are there any alternative uses for PIR rigid foam? I got way more than this photo shows and don't really want to land fill it. Other than jamming it in little gaps as a secondary insulation I'm at a lost what to do with it. Is it fire-proof? Is it heat proof? Can I carve it and cover in clay ? Can I use it for moulds? Does hot glue stick to it or melt it? Does it give off fumes when hot/burning? Is it petrol resistance? Can I use it for polishing? Can I grind it up and use it to fill small gaps? Can I mix it into cement?
February 3, 20179 yr Stick it on freecycle. I got a car full of offcuts like that and used them to insulate under the floor of our static caravan.
February 3, 20179 yr Ebay, I bet it'll go. http://m.ebay.co.uk/itm/Kingspan-Offcuts-90mm-thick-/192091018250?hash=item2cb984540a%3Ag%3ASBQAAOSwAvJW8zKA&_trkparms=pageci%3A12a013d1-ea51-11e6-a675-74dbd180ae0b%7Cparentrq%3A05b56e1315a0a5e295e3e638ff9f3a99%7Ciid%3A1 Failing that stick together with low expansion foam to make a big useful sheet.
February 3, 20179 yr I did see somewhere that a chap converts off cuts into poly beads ( I think he used a garden shredder?).
February 3, 20179 yr 3 minutes ago, joe90 said: I did see somewhere that a chap converts off cuts into poly beads ( I think he used a garden shredder?). Wasn't that EPS? PIR gives off nasty, itchy, eye watery, fumey.....nastiness as far as I'm concerned. The Devil's own stuff!
February 3, 20179 yr Twas I! I've not actually tried any PiR, just XPS will do tmrw if I get a chance! It does chop xps into flakes but think PiR would yield better results. In the end tho, I gave up and tossed it in a skip we needed any way.
February 4, 20179 yr Useful as fairing boards for sanding down things like car bodywork, boat hulls etc.
February 4, 20179 yr I made an insulated cat box for use in the shed. We also used it for padding at the bottom of garden planters, or insulating the sides thereof. F Edited February 4, 20179 yr by Ferdinand
February 4, 20179 yr Following on from the insulated cat box theme how about a carefully crafted, well insulated take away boxes? Useful for when you have to drive some distance to grab a pizza etc. Of course, depending where in the world you live take away CAT may be on the menu! (Pretty sure there was a special edition Ford Fiesta years ago with a built in gimmick/feature for keeping food warm!)
February 4, 20179 yr Is it feasible for use to sound proof internal walls instead of rockwool? Or to wedge between joists to reduce noise transmission? I would still probably use rockwool between studs where I have services running down (cables etc) but I was considering using left overs elsewhere.
February 4, 20179 yr Polyurethane & polystyrene foams have no acoustic properties. Must be mineral wool, glas or rock.
February 4, 20179 yr 15 minutes ago, ADLIan said: Polyurethane & polystyrene foams have no acoustic properties. Must be mineral wool, glas or rock. Wish somebody had told that to the people I used to work for, who had converted a music studio and used sheets of Celotex to block up the windows.
February 4, 20179 yr So far i have made an insulated dog kennel and a few weeks ago i made a very elaborate hot composting box, this was a lot of work as the insulation must remain dry from both inside steam and moisture and outside elements. It was all worth the effort as now in the middle of winter i have a very effective composting system, when i open the lid there is a great waft if hot steamy air.... very satisfying.
February 4, 20179 yr 5 minutes ago, Cpd said: So far i have made an insulated dog kennel and a few weeks ago i made a very elaborate hot composting box, this was a lot of work as the insulation must remain dry from both inside steam and moisture and outside elements. It was all worth the effort as now in the middle of winter i have a very effective composting system, when i open the lid there is a great waft if hot steamy air.... very satisfying. And are you tapping into this heat source? Jean Pain is the King of compost heating!
February 4, 20179 yr Not at this time, after i finish various other projects i will be looking into a much bigger system built within a large polly tunnel.
February 5, 20179 yr A friend of mine is building a large model railway layout and used loads of the off cuts to build scenery. He said it was easy to sculpt the hills that he then covered with plaster of paris.
February 5, 20179 yr 12 minutes ago, Ashburyselfbuild said: A friend of mine is building a large model railway layout and used loads of the off cuts to build scenery. He said it was easy to sculpt the hills that he then covered with plaster of paris. Bet he was chuffed.....
February 5, 20179 yr Author 1 hour ago, Ashburyselfbuild said: A friend of mine is building a large model railway layout and used loads of the off cuts to build scenery. He said it was easy to sculpt the hills that he then covered with plaster of paris. Best idea so far! Tried hot wire cutting it today, okish
February 5, 20179 yr 20 minutes ago, readiescards said: Best idea so far! Tried hot wire cutting it today, okish Did you make the hot wire cutter yourself?
February 5, 20179 yr Author Nope my 11 year old nephew used his hobby hot wire cutter - it was slow and painful he said but not too bad result.
February 5, 20179 yr While since I worked in pur foam industry but I'm sure the gases generated by HW cutting are pretty nasty. Perhaps ok if well vented room and on a small scale.
February 6, 20179 yr 12 hours ago, ADLIan said: While since I worked in pur foam industry but I'm sure the gases generated by HW cutting are pretty nasty. Perhaps ok if well vented room and on a small scale. Just don't do it. I worked with this stuff 30 years ago and the risks where known about then. Have you thought of secondary insulation around a thermal store/DHW cylinder.
February 6, 20179 yr I DREAD it when I've cut a bit of PIR to go between joists. "Shaving" the edge is ten times worse than the initial cut.
February 11, 20179 yr Author Today I used the left over foam for: * making a box around the generator earthing rod - prior to the garage concrete floor pour * making a box to prevent the Icynene spray foam going where the LPG boiler flue will go * sittng on it to eating my lunch off * stacking tons of bits - ready for when I come up with the brainwave what to do with this stuff I also tried setting fire to it: https://goo.gl/photos/ruuUZczYPTikMfsi7 Was quite impressed how it withstood a gas torch - not particularly recommended though as certainly some fumes were given off
