I'm looking for ideas for our master bedroom glass gable. We are now pretty much felted and batterned in so I need to get on with ordering the windows and doors.
The glass apex is open from the floor to the steel ridge and I'm wanting to use aluminium frames. There is going to be a juliet balcony hopefully with sliding doors.
I spoke to one glazing firm so far and they had concerns that I need to add a horizontal steel to split the glass up. This isn't a big deal as I've done all the steel fabrication myself onsite, but didnt want to go down that route.
Who has done this and have you any pictures you could post to show me?
Many thanks
34 minutes ago, Onoff said:
That's very nice. Which house is yours? ?
Thanks.. I'll be living in the container if my wife has her way!  ?
I can't particularly help with specifics.
Try about 20% of episodes of Grand Designs ? .
And the rear elevations of things in National Parks, where they have the potemkin heritage facade at the front. So country walking "round the houses" required.
Here is a piece from Build-it with examples and links to suppliers, which may be more useful.
https://www.self-build.co.uk/design-details-glazed-gables/
if you're having a door in there you'll need a horizontal anyway, I guess it's just a case of keeping it as small as possible?
If it was me I'd go direct to manufacturers at this point and see what they can achieve in that opening, it looks pretty large!
Here is mine. Height is 4 .5 meters to ridge. Bi folds at the bottom. I didnt want a chunky steel splitting the top and bottom section horizontally and it would have  made the portal frame design redundant. The horizontal piece of steel used was as thin as possible and had a vertical piece of steel added in the centre to tie to the steel at the top and prevent sagging. This was clad in black aluminium by the window manufacturer to disguise it.
Glazing was from a place in Middlesborough, and was 10 k less then my next quote. Happy to share details if required.
  • Like 4
That looks fantastic and very similar idea to what we have in mine although we are going for a 3 rail sliding door arrangement. I'm impressed by how you've managed to hide the horizontal and vertical steels so they are virtually invisible. What size section steel are they? And I assume RHS?
Have gone upwards of 5 metres tall without intermediate supports before. It's just a case of what wind-load you have to deal with and how much you have to spend.
Upwards of 2.5-3m spans is where the cost starts to increase. Certainly if you have a door as part of your gable, you will be wise to have a steel at the head of the door - you can't rely on a fixed window to support the head of the door frame.
1 hour ago, Mr Punter said:
Good luck with the curtains and blinds!
Who uses curtains and blinds nowadays... except in bedrooms? ... unless you are in a built up area, but I’m guessing anyone who is adding this much glass has big views without many houses looking back.
It always surprised me when I'd stay in hotels in central London as no-one bothered to shut curtains in their homes despite being overlooked and surrounded by offices, hotels, other residential places etc. I could literally look out of my hotel room into someone's dining room and see what they were eating for their tea and no, not everyone bothers with curtains or if they do have them they certainly don't always use them ?
Curtains and blinds aren't in our budget at the moment so we will be moving back in with newspaper on the bedroom window!
Classic look, economical with environmentally friendly upcycling. ... but newspapers are getting scarce these days so better start collecting now if you’re planning on a vast glass gable too.
we found cardboard boxes are better as they're stiffer and can be more easily removed during the day. ?
I don't care on covering the sliders and glass gable. Priority due to scarceness of newspapers ?
Good point, I'll start stockpiling Amazon boxes. Order a mobile phone case and they will pack it in a box the size of a small child.
  • Haha 2
  • 2 months later...
On 11/09/2020 at 18:38, simon45089 said:
Hi Olly. Yes it was RHS, from memory about 100mm I think. I am away from home at the moment but back Sunday so will double check then.
Simon.
Hi Simon
Did you find out what size RHS steel you used?
We are currently fitting the sliding doors upstairs and downstairs, frames are in, glazing on Monday. After that I need to install a horizontal steel 4.8m long at least 50 x50 SHS that will support the two triangular ali frames and glass above it. I will see about putting a horizontal in too to reduce the risk of sagging.
Sorry for the delay Olly. The horizontal beam is 60mmx 60mm. The vertical is the same. It was attached just to stop any minor bowing. The overall span is just under 5 metres.
All then clad in aluminium to match the glazing.
Thanks Simon.
I found some 70x70mm so I've put that in above the sliding doors.
