eandg Posted June 30, 2019 Posted June 30, 2019 I'm currently looking at an ICF quote which assumes a concrete cost of £121/m3 and an additional £865 per pump. A quick look on google suggests these are at the higher end of what the costs perhaps should be though some of the sources are dated. What's the 'real life' cost of concrete for slab (and potentially for ICF walls) just now?
Russell griffiths Posted June 30, 2019 Posted June 30, 2019 £87+ vat a cube £600 cash for a 30m pump.
eandg Posted June 30, 2019 Author Posted June 30, 2019 2 minutes ago, Russell griffiths said: £87+ vat a cube £600 cash for a 30m pump. Thanks - appreciated.
ToughButterCup Posted June 30, 2019 Posted June 30, 2019 £80 ish per cube plus £500 for the 24m pump. 'Course the real costs depends how many - and of the volume - of bursts you suffer dunnit ? ?
eandg Posted June 30, 2019 Author Posted June 30, 2019 18 minutes ago, AnonymousBosch said: £80 ish per cube plus £500 for the 24m pump. 'Course the real costs depends how many - and of the volume - of bursts you suffer dunnit ? ? Indeed, thanks.
Simplysimon Posted June 30, 2019 Posted June 30, 2019 (edited) depends if you are going readymix or volumetric, volumetric will give a consistent mix every time and to the consistency you want but will be more expensive. i've used these guys before https://www.dandmhaulage.co.uk/ Edited June 30, 2019 by Simplysimon insert link
eandg Posted June 30, 2019 Author Posted June 30, 2019 9 minutes ago, Simplysimon said: depends if you are going readymix or volumetric, volumetric will give a consistent mix every time and to the consistency you want but will be more expensive. i've used these guys before https://www.dandmhaulage.co.uk/ Thanks - I'll be sure to ask them for a quote.
recoveringbuilder Posted June 30, 2019 Posted June 30, 2019 We used volumetric and it was cheaper than all the other quotes we had for readymix
willbish Posted June 30, 2019 Posted June 30, 2019 Readymix £86+VAT for my most reason ICF pour. Pump was less than all the above but I'm getting a great deal as the pump has to travel less than a mile to my site.
epsilonGreedy Posted June 30, 2019 Posted June 30, 2019 Small load of 5 m3 delivered for my garage concrete floor slab last week at £84 + VAT + extra for fibres and no charge for "air" on part loads between 4 m3 and an 8 m3 full load. This was in mid Lincolnshire,.
eandg Posted June 30, 2019 Author Posted June 30, 2019 Appreciated all - there's multiple concrete companies within 5 miles of the build so definitely reckon the pump costs are heavily inflated.
Russell griffiths Posted June 30, 2019 Posted June 30, 2019 Concrete is easy to find, it’s the pump guy with icf knowledge that you want, if they have never done an icf pump job, don’t use them. This is something you definitely want by recommendation, not the local smash it and run crew.
eandg Posted June 30, 2019 Author Posted June 30, 2019 16 minutes ago, Russell griffiths said: Concrete is easy to find, it’s the pump guy with icf knowledge that you want, if they have never done an icf pump job, don’t use them. This is something you definitely want by recommendation, not the local smash it and run crew. Sage advice I'm sure!
LA3222 Posted September 19, 2019 Posted September 19, 2019 Just re-read this. My quote of £80+vat for C35 pump mix seems like a good price now.
Adam2 Posted September 19, 2019 Posted September 19, 2019 Any of you have waterproof admix? if so, what % increase did that make? I'm looking at ~40% - gulp
Mr Punter Posted September 19, 2019 Posted September 19, 2019 48 minutes ago, Adam2 said: Any of you have waterproof admix? if so, what % increase did that make? I'm looking at ~40% - gulp Yes and it is a crazy price once you have a special mix. Even more if you want it signed off by Sika or whoever. I would say voids and honeycombing are more of a risk as normal concrete, especially if it has a low water:cement ratio, is fairly waterproof anyway. For quality concrete, specify correctly, don't let the pump guy or concrete lorry driver bully you into adding water and let the batching plant know you will be doing cube tests. 1
Oz07 Posted September 19, 2019 Posted September 19, 2019 They do try and bully you into adding water nearly had an argument on last job. Was being pumped as well. I'm sure less reputable firms do it because they know their mix probably isn't up to scratch anyway, so they want you to add water so you sign the disclaimer. 1
Bitpipe Posted September 19, 2019 Posted September 19, 2019 Who is supplying pokers? You need at least two incase one fails. We have a Sika warrantied system on out basement - used traditional shuttering, not ICF as I wanted to see the quality of the pour and I applied the insulation to the exterior after (just 200mm blocks of EPS70 stuck on with LE foam). The Sika system also includes waterbar between pours and sealing of penetrations (including through bolts to hold the shuttering, don't think ICF needs those). Has an inspection regime to get the warranty so not a cheap option but for me it was the only waterproofing method so wanted it done properly. Why do you need waterproofing - is part of the pour underground? Where is the water table?
Adam2 Posted September 20, 2019 Posted September 20, 2019 15 hours ago, Bitpipe said: Why do you need waterproofing - is part of the pour underground? Where is the water table? Building down a hill so lower 2 floors have their backs in the ground and sides partially. Water table is not a problem and ground is mainly compressed sand/sandstone so drains well apparently - consequently not especially concerned about water penetration but planning on a warrantied solution (likely Triton) to provide some assurance to a future owner as may not live here for 10 years.
Bitpipe Posted September 20, 2019 Posted September 20, 2019 1 hour ago, Adam2 said: Building down a hill so lower 2 floors have their backs in the ground and sides partially. Water table is not a problem and ground is mainly compressed sand/sandstone so drains well apparently - consequently not especially concerned about water penetration but planning on a warrantied solution (likely Triton) to provide some assurance to a future owner as may not live here for 10 years. Our basement was mostly in river gravel on chalk so equally well draining, water table 2m below us. In addition to the Sika concrete, we put a land drain at the foot of the slab, draining to a soakaway, and backfilled the 1m working gap with clean, fist sized, stone - essentially building a giant french drain. We have a section of concrete that forms the box for the external basement stairs and it is in standard concrete as it's exposed to the elements and is decoupled from the basement structure itself so i can compare the pricing. Looking at the pricing we got in 2015, the Sika concrete had a supply & place cost of £200/m3 compared to the standard which was £120/m3 - this includes all the labour costs for the pour etc so in our case it was about 60% more but that includes all the tapes, mastic, plugs, prep & Sika inspections etc. There's also contractor margin in those prices too. 1
Danny68 Posted September 20, 2019 Posted September 20, 2019 On 30/06/2019 at 19:38, epsilonGreedy said: Small load of 5 m3 delivered for my garage concrete floor slab last week at £84 + VAT + extra for fibres and no charge for "air" on part loads between 4 m3 and an 8 m3 full load. This was in mid Lincolnshire,. Did you use fibres instead of rebar or as well as .
epsilonGreedy Posted September 20, 2019 Posted September 20, 2019 50 minutes ago, Danny68 said: Did you use fibres instead of rebar or as well as . Just fibres, no rebar. There was some confusing advice offered in prior threads on this forum, my advise is that if the concrete slab needs extra strength hen rebar is the solution. Metal fibres are a fringe solution and not applicable in a garage floor slab, plastic fibres offer marginal reinforcement with perhaps some resistance to surface cracking. In the end other factors nudged me towards a thicker than usual floor slab, the pour was about 80% thicker than standard. 1
Danny68 Posted September 20, 2019 Posted September 20, 2019 Thanks , I think I'll go belt and braces on mine seeing as it's on sloping ground
