Kelvin
Everything posted by Kelvin
Is a 44mm hockey stick enough for a 35mm2 cable?
Kelvin replied to saveasteading's topic in Electrics - Other
The cable from the kiosk to the house is 35mm2. I’ll take a picture and post it shortly. Have you been asked to provide your own earth? I generally add extra ducting just because it’s hard to add it afterwards. -
If you have the cable on-site that will be easier. Just keep in mind the cable is very unwieldy. The issue we had was I put the kiosk in when the plot was still a field so just had the service cable from the pole and nothing else. I made up a template out of a sheet of plastic board marking the holes where the ducts came through the bottom of the kiosk. The spec I got from SSEN had a duct to put in the trench I couldn’t buy anywhere. When the guys came to fit the service cable they basically said as long as it’s black 😂 I had a temp CU and some sockets fitted to get us power on-site. -
I used a 44mm hockey stick for 35mm2 SWA cable. It fitted but it was hard work. If it’s into a kiosk the guys won’t care if it’s a hockey stick or the smoothwall flexible electrical ducting. I put an extra hockey stick into my kiosk just in case I had a need to run something else into it. -
There’s no reason to let them take photographs of anything other than the retaining wall. The SE won’t want to get involved in whatever the wider dispute is. They will have heard it all from your neighbour. Don’t give in to the temptation of you telling the SE your side of the story just concentrate on the wall and nothing else.
Design for mull of Galloway. Thoughts?
Kelvin replied to DannyT's topic in New House & Self Build Design
Difficult and relatively expensive. Would be happy to talk with you about our experience. I’ve documented it on here too. -
Adding wet UFH to the first floor is an unnecessary expense that adds a degree of complication to your floor build up. A lot of us on here don’t have any heating upstairs apart from heated towel rails and/or electric UFH in the bathroom(s) which is what I’ve done. In addition I fitted sockets at points where we could fit electric wall panel heaters in the upstairs rooms should it ever be necessary. If you build the house well enough you’ll not need UFH upstairs and for the odd day you might want extra heat input there are other ways to achieve that. We’re in Perthshire and the heating has barely come on at all since the weather turned over the last few weeks and the upstairs rooms are still around 21°C.
Good shout. I have a tin of ACF-50 on the shelf. I forgot about that.
I used silicone gel and tape. But only just installed them so time will tell. Mine are behind the timber cladding so won’t get wet as such. I expect they will still fail due to moisture however. My original plan was to bring the Reolink cable into the house through a duct to avoid this but the cables aren’t long enough.
We're featuring on Grand Designs next week 🎥
Kelvin replied to thefoxesmaltings's topic in Property TV Programmes
What’s great was finding that local builder guy to help you. He came across brilliantly well. Like you the thing I found hard in our build was not knowing what I didn’t know so you easily get caught out with stuff. Plus all of the energy sapping time wasting balls ups done by others that you are left to resolve. The worst one of those for us was the ducting for the electrical cable from the kiosk to the house. Groundsworker didn’t use a coupler to join the two bits of duct together and just used tape. This split apart when the trench was backfilled. When I came to feed the SWA cable through it got stuck. Unfortunately this was all behind our retaining wall so under several hundred kg of gravel that I had to dig out by hand trying to find what the problem was. Complete waste of two days to resolve something that should have been a few hours work max. -
Many ASHP/UFH have a floor drying mode. It ramps up to max temperature over a number of days and then brings the temperature back down again. We then switched it off for 48 hours before we started tiling then left it off for a few weeks after tiling. We also used Ditra mat and expansion joints at every door and across the biggest run of tiles in the open plan area. Screed was Cemfloor. Best practice? Overkill?
Very well done. It looks terrific. -
LVT over a cemfloor liquid screed with UFH
Kelvin replied to iMCaan's topic in Wood & Laminate Flooring
Still quite thin. Imagine a small stone under that. -
How thin is the LVT you’re using? The click LVT stuff is generally thicker than say the Amtico stick down stuff. Some folk also lay it on a foam underlay. The thicker it is the more forgiving it is I expect but you still want it scrupulously clean. -
You need to make sure it’s completely flat and smooth. The builder badly installed LVT at our previous place and you could see all the floor imperfections under the LVT. They had to lift it and fix the floor and relay. It’s also better to fit LVT that isn’t shiny and has some kind of texture especially if you have a large floor length window opposite it. The first type that went down was a shiny smooth wood effect type and showed every tiny surface scratch. The second type was more matt textured wood effect. The difference was night and day. Both were Amtico. I also wouldn’t assume it’s level without checking. We had one room where it wasn’t in that it was slightly higher than the hallway. This was due to the hardboard crack inducers across the doorway. No issue for us as we were tiling over a decoupling mat. -
There’s a thread of my build here: -
An app or website, so I can play with my plans
Kelvin replied to Strangey71's topic in New House & Self Build Design
Something like this? https://help.magicplan.app/import-and-digitalize-an-existing-floor-plan For electrical layout, lights, circuits, switches, sockets etc I just used Powerpoint. -
It’s pretty much like ours (which is a Heb Home) and we also have a 45° degree pitch although I decided not to fit the PV on the roof. How deep is the porch section? We made ours 4m deep as when we visited some other HH their standard depth seemed too small. -
Cold unventilated loft - condensation risk?
Kelvin replied to G and J's topic in Roofing, Tiling & Slating
Our main living room is vaulted as is the upstairs sitting room and we created a high coombed ceiling (2.7m) in the master bedroom. It’s meant the rooms are all quite different which has added a bit of character I think. -
Internal Walls - Marmox Thermoblocks & Concrete Blocks
Kelvin replied to Mulberry View's topic in Brick & Block
I calculated it that way too largely informed by one of your posts on one of my threads. -
Agreed. It is much easier to detail and reduces your condensation risk to near zero. You then have the option of a vaulted ceiling should you so wish. You also don’t need to worry too much about ceiling penetrations etc Why are thinking of doing it this way anyway? -
Congratulations. Looks great. Shall watch GD, I don’t normally. GD draws a mixed but mostly negative view on here. It’s an entertainment programme about building houses not a house building programme. Consequently we don’t really learn very much about building houses. If it was actually about building houses it would be boring for most. Plus there needs to be a little bit of drama albeit their staple diet of ran out of money family and friends rallied round and stumped up £300,000, had 4 kids, bought windows from Chechnya but they didn’t turn up fortunately my sister runs a window company, etc gets a bit samey. It's bit like Top Gear was. Back in the early days it was actually about cars but few folk were interested in that so it was reinvented as an entertainment programme involving cars and driving. Interestingly Clarkson’s farm is the other way around, a farming programme that is also entertaining. -
Water installation quote. Seems excessive.
Kelvin replied to flanagaj's topic in General Self Build & DIY Discussion
I would ask if it really is a road closure. I had some work done at a previous property and it said the same (traffic mgt/road closure) but they didn’t intend closing the road. -
MVHR Design: Feedback & Mythbusting
Kelvin replied to joshwk's topic in Mechanical Ventilation with Heat Recovery (MVHR)
One of the things that has surprised me is the number of self-builders that don’t care that much about air tightness. This seems to correlate with how involved they are with the build with the less involved being less interested. I’ve met half a dozen people who live in houses built for them that couldn’t tell you what their air tightness was nor particularly care. I’ve met two who actively made their air tightness worse to save putting MVHR in. As Ian says, it’s a fundamental decision you need to make right at the start.
