Ferdinand
    41
  1. How many days has that happened to the whole country on? OK. The numbers. If all the nuclear powerstations except Sizewell close, loss of generating capacity = 6 GW. Currently 2 gas fired power stations mothballed = 1.6GW Wind farms under construction due to come on stream between 2021 and 2026, 75% by 2023 = 5GW Wind farms proposed under the current round due to be commissioned by 2025 = 4GW (And I am not sure that is all of them). Plus demand is falling. Plus we have a number of interconnectors to I think France / Netherlands / Norway, which can service around 10% of electricity demand if needed. The situation is radically different to 2 years ago, and I don't see much of a threat now. (https://en.wikipedia.org/wiki/Nuclear_power_in_the_United_Kingdom https://en.wikipedia.org/wiki/List_of_natural_gas_power_stations_in_the_United_Kingdom https://en.wikipedia.org/wiki/List_of_offshore_wind_farms_in_the_United_Kingdom https://en.wikipedia.org/wiki/Wind_power_in_the_United_Kingdom)
  2. The Ikea ones slide neatly under the worktop if you leave a void. Too high for your reduced-height Gran - trim the legs.
  3. On the reduced height kitchen, I thought that most "feet" are adjustable, and these days a new set of plinths for when you sell it would cost very little. Could you perhaps slice them 1/3:2/3 so you can make it more normal-height when you come to sell the place? I bet my Ikea one is a smaller quantity of spondulicks. That plus a new bead of silicon on the wall at the back of the worktop. The old one won't show as it would be hidden. Probably just needs some reasonably careful thinking about detail to make that doable.
  4. Places like Ikea do wooden utility trolleys including drawers and shelves etc which are very good small "islands" on wheels. https://www.ikea.com/gb/en/p/vesken-shelf-unit-white-40307866/ They are called things like FORHOJA !! (which is what small boys shout in Sweden where we shout GERONIMO whilst jumping 4ft down a sand dune) and BROR (which is part of the Swedish for Brer Rabbit, Brer Rabbit being a not very tastefully named Swedish sex-toy.).
  5. You are scoring about 92% in your patience test.
  6. We're avoiding it because it could be a detailed question, but let's chat. It depends on the conditions and what you want to do with it. Do you know what the temperature is in there? Is it like a space under the ground which will have a constant temp give or take (once you are a couple of feet down it will be 5C or so most of the time), or does it fluctuate? What about humidity? is it ventilated to the outside either properly eg air brick or via air leaks? Does it get moisture going through? (Ideally: run a min/max thermometer/humidistat in there for a bit. Useful things - I have about 3 of these at £10. https://www.amazon.co.uk/dp/B017KNQNZA) At present is it adjacent to the outside in any dimension, or is it buried underneath the middle of the house? If you want it eg to put tools in, dryness is important, whilst if you want it for eg wine or jam or plastic things or your drain-rodding kit or bulk household storage, it may be a bit more tolerant. Is it a room above that floor, and do you need to insulate that? Once you have decided what you want it for, then if you need to insulate you either leave it at current temp and insulate the door * and sides adjoining the house, or install an insulated box inside the cupboard and do usual airtiightness things if you want it inside the insulation envelope of the house. If you just want to stand things on the bottom, or install a freestanding shelf-frame in there, then you may be able to get away without a frame and just either glue sheets of insulation together (I did an insulated box for our cat like that), or perhaps glue them to the sides. Imagine using eg large offcuts, or 75mm or 100mm sheets. If you need a frame, then you could potentially glue your battens to the sides and affix to those, and screw to the joists above. Were I doing it, I would want to know it was dry, and I would do it in a dismountable way which lets me get behind the cupboard without destroying it. I hope that is a few points. Spare materials for the house is a good call. Ferdinand * One neat way to do that is with magnetic catches and a panel with two handles that is 'magneted' to the wall.
  7. Point of Order: how does a flayed *corpse* freeze to death?
  8. I think that biodegradable plastics will make a lot of progress for packaging. Plus house construction will work more heavily on dismantle-ability.
  9. Chasing games, or to hold the fondue.
  10. You could get one of those Plasticised Flayed Corpses from Dr Gunther von Hagens, and install it behind @pocster's walk on glazing. Then you can have a hallway like a scare-ride at a funfair, with a light and a siren, and a "bwahahahah" speaker. Absolutely essential if you have children under 10. Squeamishness warning: https://www.standard.co.uk/reveller/attractions/body-worlds-london-piccadilly-circus-a3952486.html
  11. I wouldn't enquire so closely. There is still space...
  12. Do you have some data to support that? It is a factor, but nothing like the total imo. And your other suggestion (better car fuel economy) has not changed in toto. It is a beloved notion as a trump card for people who do not like it being pointed out how well the UK has done on these issues relative to the EU. That's not true in total energy consumption. Total energy consumption by cars is the same as it was 20 years ago (with a switch from petrol to diesel). There is a balance between 20% more cars since 2000, a lower mileage travelled per car, and somewhat improved fuel economy - which all ends up at a total change of around zero energy used. It's correct to say that the energy used per km has reduced. The calorific value of petrol and diesel is with 0.5% of each other. The only thing that will reduce this total energy number may well be a switch to rail / active travel - since electric cars tend to be comparative tanks. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/928350/2020_Energy_Consumption_in_the_UK__ECUK_.pdf I don't buy this. I have already pointed out that we have the best part of 2 GW of gas based generating capacity mothballed. Plus we can flex up imports if necessary. Plus our wind resource is on track to treble by 2030. Plus demand is falling. Given that wind now generates more than nuclear, and is set to treble, I am not very worried about a partial reduction in nuclear. Ferdinand
  13. Reading the above it seems to be an above ground level void (sloping site), so it looks useful as either an insulated space, or uninsulated space (ie insulate the door) depending on your needs.
  14. Ferdinand
    Ouch
    I wonder what the chap said when it happened? "Er .. ooops". If the bod is not already off the premises, there will be some serious ragging. Ferdinand
  15. Why did you not offer her a 1m long hall cupboard? :??? ?
  16. Looks good. And best of luck with the health. I've had so much treatment in the last 2 years that I've just asked for the latest (nasal polyp) to be put on hold for a year.
  17. Is this "overage" - a clause to retain extra value for the seller if the buyer does x, y, or z? The clause is perfectly normal and is a risk /benefit sharing mechanism. Entirely normal to have one. They just need to be written or parsed quite carefully. It will be a jointly appointed RICS, or similar. What does your surveyor say about the final GDV of the project? I don't understand why you can't get a decent estimate of value with PP. That is also normal. You could renegotiate the clause - eg on sale of first barn. I have heard of one where it triggered on the nth house, so they just stopped at n-1 . Just a normal part of the risk mix. If they want all the money they could of course have gone for outline themselves. You can play games as well, of course. If it is "triggered by PP", then you could apply for one - trigger it and pay. Then apply for the other two a bit later. We had a clause on a bungalow (.5 acre plot) we bought next door once, and that was 20 years 50% of value uplift triggered by grant of PP binding on successor owners. That one was vulnerable to this strategy but in the end the people we sold it too did not want to develop, just extend, and they limited it to PD rights so the clause did not apply. ( @Bramco, not a strategy to be used with your own family, unless you want a perma-schism. ? ) TBH 1m sounds a *lot* for *potential* barn conversions. Is it a well-written clause? I might be inclined to try and lance that clause for a smaller amount than it could potentially achieve. Depending on the wording, apply for PP for a shed or garden pond ?. Certainly get legal advice. F
  18. "Pastiche of Local Vernacular".
  19. On avoiding his demand for a fake chimney. "Pastiche" is a useful polite, but contemptuous, word, as it hints at fake.
  20. Yes -all energy demand, not production. If you relate it to all generation, then one missing bit not shown on these total numbers is imports which have grown relatively over say 20 years.
  21. If it only has 3mm of insulation I would take it all off and do it properly.
  22. Pity they didn't hide it in a haystack.
  23. Doesn't seem to work for the Ministry of Defence. ?
  24. Ahem: https://comicvine.gamespot.com/builders/4060-60019/ Just not made the movie, yet? They are behind the creation of the entire Universe from Chaos. But, as the Architect said - who created the Chaos?
