Ferdinand
    41
  1. There are two threads which cover much detail including pics here. read both threads. and here Note that ABB are a distributor not the manufacturer, who are Grant Westfield as described on my thread linked above. The cheapest source I found were Big Kitchen Warehouse, who do free delivery with an order over £750. My 8 ft x 7 ft bathroom used enough panels that I only needed one extra for stock to get the free delivery. http://www.thebigkitchenwarehouse.co.uk/ourshop/cat_975511-Multi-Panel-Wall-Ceiling-Panels.html BKW were about 15-20% cheaper than ABB for my order. My trims were the correct ones but came from elsewhere. Prices are quite variable. If you go for the ones with aqua lock trimless joints there will be a lead time of a couple of weeks, but it will save you £15 to £20 per straight joint and look very swanky. You will need trims for corner joints. High quality sealant is also important. It is also quite variable on price depending on the design, and you can even get them done with a wall size enlargement of a photo you send in. Those are several hundred though spectacular. I have a shower room done throughout with these panels in a rental back in 2010, and they are pristine still. Ferdinand
  2. There is a large conversation somewhere about these panels. Two key items are the core material being marine ply or MDF, and the joints between the panels .. if they have joints that do not need a trim it saves quite a lot of money. Ferdinand
  3. Thanks both. The first one seems to be an exact match. F
  4. @JSHarris Can you give me a steer on how much to buy, and the dilution rate? The cheapest suppliers seem to be to the horse riding community, where they treat paths with a 1kg to 10l dilution and buy sacks of 25kg of copper sulphate for about £75 in order to help keep bugs out of hooves. I have about 25 solar panels to treat and will probably use a floor squeegee for application. Ferdinand
  5. If you rely on sand for colour, make sure that each undivided visual section uses a consistent colour and buy enough in each purchase to cover that ... because they will not necessarily be consistent over time. And buy enough ! My garden wall at the Little brown Bungalow deliberately used red sand from a particular local BM that was redder tan everybody else’s sand, and it caused a problem when we ran out at a weekend when they were closed. The render in this pic is entirely coloured by the sand, and uses normal cement. Ferdinand
  6. Does anyone know where I can get a pair of these for one door? I reckon the chap who did our house had one too few. The result is that we have knobs not levers on the inside of both bathroom doors, and they are awkward to use. I can find equivalents without the 3 grooves, but not identical. They are 7-8 years old. The specs are: length of lever 125mm, diameter 17mm, finish I think is satin nickel, rose cover diameter is about 52mm. I would punt on them being a former B&Q range, but that does not help. Cheers Ferdinand
  7. No, but robust shoes with thick soles have when I stood on a nail. In garden when it was being cleared out. And similarly on a previous occasion 20+ years ago. F
  8. Thanks.
  9. Clip it down. That is the avatar.
  10. Irksome. A wonderful word that I had forgotten. TO be used at every opportunity. WOuld that not be the normal process. PLanning Appeal. Or Planning Officer then Line Manager then Head of Planning then Local and National Procedure and Ombudsman. Or Councillor or MP to try and short circuit it. Or Judicial Review within 3 months (also applicable to each appeal stage within 3 months of that decision?). Or High Court action. ANd much of it is disfunctional from the point of view of solving the presenting problem. AN irksome system. F
  11. Glad all that has been considered . Good to hear. F
  12. I thought there was an Appeal case that had overturned the single source requirement in a National Park several years ago. Lakeland to Wales? Was it mentioned on ebuild?
  13. Wishing you well with this, and particularly wishing you cooperative neighbours. Ferdinand
  14. Bumping this thread. A few of my solar panels have now suffered serious attention from lichen and algae. They are under a tree and have got quite a lot worse over the winter. Now that we are nearly back in the serious generation season, they need some attention. There are a couple of photos. The bottom of the array is at about 2.3m from the ground, so access is not that difficult. I may be able to reach most of them by hand with care. Questions: 1 - Is there a cleaning agent I can add to my long hose-connected solar panel cleaning pole (see start of thread)? Mild bleach? Vinegar? 2 - Is there any kind of copper tape that I can add to each panel to help keep then clean in future? I am wondering about either adhesive tape (eg the sort to control slugs) or perhaps copper wire as used on roofs. Thanks
  15. One more question. Are there complications with a shower bath type setup, due to the branched cold supply? I guess it depends on the exact layout. Ferdinand
  16. I was interested that the capacity is to assemble 2500 units per week, which is approx 5000 kitchens per year or a turnover of up to 5m+ per year. GIve or take that is 1% of Howdens. 2:20 in the vid. F
  17. SO that looks to be complication-free using this with gas, then? PRovided the shower is thermostatic. F
  18. That is inexpensive enough that I might try one in a house that is going to struggle on its EPC in a few years. Can anyone advise on what features are required in the gas or electric shower if any, and the practical difference for the user when controlling the shower? Does it make the water warmer at a lower setting on the dial compared to a system without a HR device installed? SO that the experience is the same but the shower is just turned down a little lower on the dial ? Presumably on a thermostatic controller the shower just modulates down the input power required. Assuming showers costing 28p each and a 25% energy saving the simple payback period is about 2000 showers on a cost of £140, or 3000 showers if you pay £70 to fit it. From Romania and 40ukp charge. Hmmm. Thanks for any comments. Ferdinand
  19. I will get a quote from there next time. British, Northern, and decent quality / customer service. What is not to like? Though iirc Howdens are based in Yorkshire, so also qualify.
  20. Taurelilómëa-tumbalemorna Tumbaletaurëa Lómëanor. Quite.
  21. Never heard any complaining...
  22. Given that it the Indy, I predict that the Maths is probably wrong.
  23. My first reaction to "fill a 2 fence panel" gap was "2 new fence panels, perhaps screwed to a knocker post" but I am guessing that is not what you want. I think the challenge is "what will establish and thrive in year 1" *and* grow thickly enough to be a visual block, and TBH I do not know anything that will unless it is a reasonably big plant in a big pot, and you plan to discard or transplant within a year or two, or a climber in a big pot that will go up a framework (eg trellis or even chainlink). The 2 possible ideas I have are to use in a coppice form. I have Common Bhuddlea, which goes 2m high in a year, or Eucalyptus, which can be grown as a coppice. The latter may need more time to start. I have a screening bamboo (Gigantica, I think) for next door's bathroom window, which should get to 5+ metres, but after 4 years reaches 3m+ in the summer then goes back smaller in the winter (currently at about 2.5m) whilst going a bit higher each year and thickening. Our soil is not rich, but it is in a former asparagus raised bed with lots of compost from the start so should be well fed. The other thought I have is to use a fabric backdrop and plants in front. I saw very convincing use of astroturf over site fencing around building compounds in Istanbul. Made it all look much greener. The other Other thought is to find someone with a big bush they need to move and have that with much labour. "Wants" on freecycle? Local gardening club? Ferdinand
  24. 1 My grandparents used to have Myrtle in a hedge right on the beach road in Prestatyn, which worked. The soil was almost sand. 2 Might Aucuba be better than Laurel? 3 For salt tolerance I would suggest a small tree such as Tamarisk, or Holm (Evergreen) Oak. The latter can be cut into a good hedge. Or various sorts of evergreen (eg Juniper). Tamarisk can be a bit of a bully. Ferdinand
  25. @Barney12 I wonder about the less expensive Everbuild product in their ASBO range eg https://www.amazon.co.uk/Everbuild-Anti-Graffiti-Coating-Protect-Concrete/dp/B01N902A0J/ I think that is a sacrificial one that you repaint with the same stuff after spraying off the graffiti. My wall has only had 2 lots of graffiti that I can remember,and the current one has been there a year or so with no further additions, so I perhaps do not need a top top top product. The other question is how breathable are these ... this is a house wall, though I will be improving ventilation there this summer anyway. Ferdinand
