Problems with Baumit.com thin coat render system - part 3.
saveasteading replied to ProDave's topic in Plastering & Rendering
I have limited experience of render but some. When my choice we never spec'd render, because I have seen so much failed or grotty stuff. But some projects came with it written in. There is some crazily expensive Swiss stuff we had to use on a Mercedes dealership. This was applied direct to plywood externally, and it stayed put. Then our choice of render on a block wall (flats). This was high up and very exposed. The difference to yours is that the mesh was tacked to the wall first, and a base course applied. Then the finish coat went on. Again it has performed well. The 'mesh first' ensures that any local loss of adhesion does not cause the render to bulge. So I am guessing about your product and circumstances. I agree that it is not coming from above or below,: it is failing where the water is getting in. That is likeliest to be due to microcracking, and driven rain will get in there, then freeze and pop off. It may be a local problem due to drying issues when applied, or may be everywhere.....we will hear. On the other hand perhaps it is simply a poor bond locally, due to the finish of the board...dirt or oil, or too smooth. I am surprised it has gone back to place..it must be very flexible. How exposed is the site? From my studies your area doesn't look too severe. Anyway, how do they define severity? -
If the site arrangement and topography and all other circumstances allow, I would favour having a settlement tank at source, filling by natural flow from the burn. This can be constructed to take in the best flowing water with minimum floating bits. The tank allows the water to still and bits to settle and float, and your outlet pipe then takes water from near the bottom. this then provides free and low-maintenance first stage cleaning, and a holding tank for quantity/backup. Then gravity flow to the house. If it comes from high up it may fill to the attic without a pump. After that you may need more filtering or pumping. You can decide if you welcome the colour or want to filter it out. BTW, (and no need to read on) I had a summer job very long ago, to build exactly one such. The existing intake tank had a tiny trout living in it, and somehow getting a living in the closed dark place. The water was not chemically treated so we must have been drinking some element of the trout's excretions. You could say the fish was pre-treating the water, taking out organic matter. Nobody cared as long as they didn't know! (A controlled spillway would prevent this happening in your tank.) It looked good on my CV as I didn't mention the size and scope, and got me a job saving the Netherlands from flooding.
You are getting sensible suggestions based on the limited information provided. Airtightness/vapour barrier purposes are rather fundamental, so please explain what you don't understand. Likewise sloping roof. What is your concern?
Timber in a wall doesn't burn unless flame reaches it. Therefore if you delete the external cladding, and then skin the timber structure in masonry or cement board (and render) does that not resolve the issue? The absence of a neighbour isn't the issue, as they might want to build close to the boundary in future. The rule can be relaxed if there is little possibility of that happening eg there is a river , pond, road etc.
More information needed. The avoidance of fire spreading from your house to another is the main concern, and the likeliest cause is through a window. Have you any on that wall? Then there is the spread of flame on the outside of your wall....if you have proposed timber cladding can't you just delete it? Plasterboard internally works perfectly well and there is no need to get complicated. Being 1m or less makes it more onerous but it should be easily resolved I feel. Anything that is not sold as vapour-proof will likely be porous and breathable, so I suggest moving away from niche products towards traditional. With 1m gap it is not as if it will be visible and a feature of the building.
That sounds like a small area of internal wall. The internal wall could be (wiIl be) covered in plastic, so an area of bitumen spray sounds ok to me, and much better than nothing. It will depend on what else you are doing to the wall, and where your general barrier will be going, but you can probably work out a lapping detail to keep the joists 'inside'. I have always found that bitumen on block requires at least 2 coats as the first doesn't enter all the dimples. if you can get a brush in all the better, but still at least 2 coats.
The warrant application response says that our building 'goes beyond Minor Works Structures Guidance'. I know that a storey over 200m2 needs special attention for fire. However I can't see any such guidance for structures, which is what he is saying. We are proposing a 95m2 (GEA) area of replacement timber structure, and no rebuild to the remainder which is about another 155m2 GEA. GIA is 270m2 total. It matters as he is rejecting the calculation of the timber structure using the 'Minor Works' design guides, which I have done. I am not registered in Scotland so he is requiring a registered Engineer to be engaged that we don't need , or want to pay for. Also choose any 2 Engineers (or of anything) and get different interpretations. The intention of the 'minor works' process is to reduce unnecessary bureaucracy. Any pointers? Is there such a ruling?
It appears to cost a plumber £100 per annum, and to be an amalgamation of several trade lists.
I think this is a subscription register that plumbers pay to be in. Not statutory. I searched their website for evidence of training and standards but cant see any mention. I can see that some standards are desirable and not all 'plumbers' are really plumbers. I suggest you just write n/a in the box.
Notification of Statutory Undertakers?
saveasteading replied to Tracey Gardner's topic in Party Wall & Property Legal Issues
Agreed this is nothing to do with the planners or building inspectors,. Entirely the landowner unless they are paying someone else to advise them. For a single domestic supply the diversion will be a yellow plastic pipe in a trench round the building. £1,000 at a guess. Just possible that gas co may be sympathetic and give a discount. But if nobody made enquiries to them this is unlikely. -
Some swallows will be disappointed when they return from South Africa in the spring, as their temporary home will be closed up for housing humans. From research there is no point in bird boxes on trees as 1. they won't use them because: 2 squirrels will get in. I can't find any info on alternative locations, but was thinking perhaps a substantial box fixed to the outside of an outbuilding, with a swallow slot and some shelves inside. Comments and suggestions please?
Where are smoke alarms REQUIRED
saveasteading replied to MortarThePoint's topic in Electrics - Other
sorry if not clear: I am agreeing with you. The radio units have to be mains connected so there is no saving on that , and they are much more expensive than your £16 so the interlink wiring is not a cost concern. -
Great news on simplicity and cost. Yes I am used to central panels, break glass, etc, even in tiny units where the fire would be immediately obvious by sight, smell or sound. Just got some thorough responses for an Ei wireless system. It would need the upgraded units that are connected to the mains, so the price has become average £75 each to buy instead of £35, and needs mains connection. Saves on interlinking wire and would be very easy to adapt if necessary. But if we have £60 change for wiring then that seems to be the way. To complete my report. CO2 detector also about £75 and CO (not linked ) is £16 but is only an alarm, and does not keep a record, as i think is required. I will relax and assume all wired for now. Thanks. -
In my experience of education and commercial installations, ie not housing, fire alarm systems are very expensive. Maybe it is much less for domestic and my concerns are unnecessary. I liked the idea of £40 a room, installed and working. Do you have any guidance? As you say, it is like new-build so wire fixing is easy. -
Thanks. Had not thought about that. We have a response from our warrant application, and the requirement is for an LD2 system. The one supplier I have asked about wireless has not come back to my query about satisfying the reg's yet. Maybe they can't? Will keep you informed. -
Patience please. We are none of us required to help you at all, and yet we are trying. As above, it is the owner's responsibility unless this is formally delegated to a designer or the builder. I have experience of this, when a client told us (as designer and contractor) that there were no services and we stupidly accepted this. Then we found a gas main and had to divert it around the new building at some cost. otherwise gas could leak in to the building and boom! -
But won't these prices plummet and/or quality improve as the market gets more competitive? There is a lot of business in this. If diy proves easy then there will likely also be objections/ scare stories from the established market. This for example? No wires and will be as easy to fit as standalone smoke alarm units. £160 the lot , so average £32 each. expandable to 15 units. It would appear that a 'lifetime battery' applies to the life of the battery! Radio-Interlink Sealed Battery 3 Smoke, 1 Heat Alarm and CO Alarm Kit - Firehawk W Series Detector Battery: 10 year sealed lithium battery Wireless Base Battery: 7 year sealed lithium Warranty: 7 year manufacturer's warranty Easy expansion – Interlink up to 15 alarms Suitable for the 2022 Scottish legislation Do smoke alarms need to be hardwired in Scotland? No, there are alternatives to hardwired smoke alarms that comply with the new regulations. To comply with the new Scottish law from February 2022, all smoke alarms in Scotland should be either hardwired to a circuit (mains-powered) with a back-up battery or powered by a lifetime tamper-proof battery. -
As we have several months before having to start the fire /gas alarm installation I am keeping my eye on the wireless market. Had a targeted ad on facebook with lots of kits from £150 to £300, which looked very promising. 'No wiring' has to be a big cost and time advantage. -
If you are short of space then try all means to get a sewer connection, using storage, flow controller and whatever pumps it needs. Bottom line though is that rain currently falls on this site. If you can make it no worse then you don't need to connect to a sewer. 1. soak way, however bad will probably have some sort of flow. If you can make this into a long french drain, it will have a bigger surface area and might find some fissure where trees are or used to be. 2. A pond or lagoon or swale. as well as having some soakage into the ground you will have evaporation, especially if the site is exposed. 3. Some more storage if possible. In its simplest form this is a barrel with the tap set to dribble out over a couple of days. 4. More storage in open texture stone or crates under the parking area and anywhere else. If all that combines to contain all the water on site then everybody will be happy. BUT proving it could be tricky. I suggest giving it a go and proposing it. If it ever fails and floods onto neighbours or rods you could be in some trouble though.
Without knowing all the details this is tricky to resolve. However I assume that the authorities want to restrict more storm water into the drains, which is normal and understandable. They will normally allow about 5 litres/ second, but perhaps less, hence the suggestion of storage and a hydrobrake. Then do you still have to pump it up to the uphill drains? Perhaps not. Do you have space for a pond?
Cost per sqm - what doesn’t it include
saveasteading replied to Kelvin's topic in Costing & Estimating
Just occasionally a good idea may occur during construction, often a suggestion from a contractor. However it may be too late without disrupting other details. Therefore it is very important to do all this discussion before you start, including detailed discussion with all parties. Contractors do not like changes as it disrupts their plans , material ordering and resources, and so it either costs you more, or doesn't make the savings you hoped for. it might also require redesign. At some stage you have to trust designers/contractors and get into detailed discussion. As a contractor I was always wary about giving away commercial ideas, but there comes a time for trust in that direction too....or not. -
Libel/defamatory comments on planning application
saveasteading replied to Omnibuswoman's topic in Planning Permission
I have found some objectors to be shocked to find that their names are published and it was clear they would not have said the same thing publicly. Yes tell the council and they will remove them. -
Help Needed Brick and Block Quantities
saveasteading replied to Natasha's topic in Bricklaying, Blockwork & Mortar
The comments about waste are correct. You will have to go round the site and collect the dropped bricks and halfs, as they will not. Some bricks are very consistent while others (the characterful ones) may have 'bananas' Re blocks you can often order precisely but ask the mechamt if you can have any more at the same price. For bricks you can only do this if they set aside a batch, as otherwise they won't match. Then be prepared to collect them yourself to keep the bricky going. Better than a big pile of unused, or expensive hardcore. -
When last I used it (reluctantly) it added 30kg/m2 to the roof, but that varies and can be up to 80kg which is a lot (allow for saturated earth). Please let us know how you get on.
