saveasteading
    94
  1. Yes please. Any ideas for swallows/house martins?
  2. Welcome. Lots of advice available here once you have any plot in mind. Most people avoid precise details because it is all public.
  3. Correct. The rules are not that you insulate a building but that you avoid wasting energy. Therefore an unheated room does not need insulation at all, so you can allow whatever you choose. It is also permissible to have heat from infra-red that heats the person rather than the room, but that should not be overdone (ie don't cheat) So it absolutely depends on the purpose now (for regs) and in future (as common sense to save energy). Also you can use more insulation where it is easy, and less where it is not practical. The bco would want a statement on purpose/heating strategy/insulation. You Got It!. that would be space heating and require full insulation. You are going to get waste heat from the boiler anyway, and that doesn't count. The smaller room and doors will reduce heat waste from your boiler to the big space and cold door. I would add some insulation to the walls (and internal stud wall) of the rear portion. You are making changes that potentially alter the energy loss principles, and you are also changing means of access/escape so it is possible that you should apply for regs, ad then that is also available at any future sale. But I have checked my LA page and it says 'conversion to a habitable room'. Perhaps email your LA and explain the purpose of each room and make them decide. If they reply 'no' then that equally satisfies anyone in the future. The following table details the standard charges for certain extensions and alterations. If the work you are undertaking does not fall into any category please contact Administration The fee is higher than I thought! £363 Conversion of garage to habitable room(s) £363.00
  4. About half the price and half as effective.
  5. Building a new one, about 20m away and at about ridge level. Can be any size as we are still designing it. From once having a rainwater harvester I am aware of how easy that was: the pump in it kicked in whenever a tap was turned on, and it was sheer pressure and no tanks.. On the other hand, the pump failed in 2 years, so the tandem idea is good.
  6. Private water supply gurgling slowly to a storage tank. From there a pump, either to a header tank or hard into the system. 4m x 1.5m
  7. You don't get RIBA lightly. 7 years and some rigorous exams that include contract administration and law. Somebody without it could be as experience but you would find out by reference. Re fees try this as a guide. https://www.bparchitecture.co.uk/downloads/arch_fees/RIBA_Fee_guide_Graphs.pdf I suggest probe hard re build budget and ask what is not included. I have known jobs that were double the client's fixed budget at tender. Oh but I didn't include services, other consultants, externals etc. One where I said the job was gong over budget, he relied that the client always finds more money..so I walked away. But yours might be wonderful, good luck.
  8. Correct, thanks for reminding me. The designer remains the designer and nobody can, in theory, copy it. The owner can use the drawings for anything to do with the building, now or future, but can't necessarily build another the same...that would be interesting....or use extracts for another project. In theory designers are entitled to put their name visibly on the project, as seen at the centre of big Victorian bridges. But I have never had a client who would accept this.
  9. A good Architect can see things better in 3d, but surprisingly few can. Yes, I have been called a philistine many a time, for questioning how something is meant to be built...physics or funds not having being considered. Can you do this for 2/3 or half the cost of the quotes we have received? Yes but we have to start from scratch, and we will not work with the previous team who did this for you....pay them off. With Engineers there is more interest and willingness to discuss efficient ways of doing things (my contractor half of brain) BUT it is great working as a proper team with a skilled and interested Engineer and/or Architect. Challenges can become opportunities and still look good, or better.
  10. It is possible that at the end of a long, muddy, winter's walk, they are all used within a short time frame. ProDave has mentioned adding an inline heater for times of extreme use which is perhaps worth a thought. But I think we need generous hot tanks, and efficient shower heads.
  11. Welcome. Sounds like you can tell us a lot from hands-on experience.
  12. 6 en-suites, 2 wc, 2 kitchen , 2 utility.
  13. Interesting. These are new to me. Very tidy. I am guessing that the bulb is in line with the finished ceiling. If set back there will be some shadow. You need to draw this up showing light radiating down at whatever angle the bulbs say is their spread, to ensure even coverage. That would be at just above worktop. They must be over work surfaces not heads, or there will be shadows. Does that work if there are cupboards? You will have a lot of them. 1m centres? so 35 of them!
  14. The design is yours. You commissioned and paid for it. Presumably you eventually got the drawings, but were they any use for the other parties? I (as Engineer and contractor) have had clients' architects erase all dimensions before handing over. Also many errors in both draughting and in being buildable. In any case we would always redraw in 3d as you have little idea if the drawings are correct. This was rightly an issue on our current 'Buildhub self-build'. Our appointed SE would not commit to using our Architect's drawings until seen. As they are Revit 3d he is now happy to do so, but I acknowledge his concerns. The whole point of detailed 3d designs is to share drawings and have one set of common information. The big companies do it and it works. Any consultant should be happy to share their drawings....it is a concern if they don't trust their own work.
  15. Based on info on Buildhub I estimated a 15kW ashp, but a local specialist says it is not enough. Also the floor arrangement requires a secondary feed and manifold to reach the distances. The building will be in the form of a main building and an annex (for us old ones and b&b). Plans below shows the layout, with central courtyard. All the GF to be ufh. The upper areas (front and left wings in roof) to be radiator (headroom is tight). Outside is 21 x 19, inside 18 x 16 approx. Insulation will be very good, to new-build targets, although some trading off for practicality (esp headroom at existing doors), so the floor will be 125 to 150 PIR. Our thoughts are as follows. 1. 2 pumps needed so do they both feed the one plant room or 1 for main build and 1 for annex? 2. If the former, do they work in tandem or split to space heating and water heating? 3. Split the load as 2 identical pumps sharing the load, or large and small? 4. Best to have 2 water tanks anyway, for volume and to avoid arguments between the 2 spaces? 270m2 GIA ground floor, 110m2 upper floor. The plant room is shown, to the left next to the stairs. There is a roof void at bottom right that could house more plant. BTW the current favourite installer seems good, but it is early days and I like to understand and question. Any comments welcome, not just as my 1-4.
  16. What do you mean by 'polished floor'. Some people mean a beautifully smooth concrete floor with exposed aggregate. Others simply mean smoothed and polished as in an industrial context, for another floor covering. What is the construction of the floor? Raised or ground-bearing? Your 0.4 PA would be right for a 10m x 10m building. If bigger this will improve, but if less square it will be less good.
  17. Has he listed everything included? If he is Chartered then this is likely to be a standard schedule by RIBA. Plus you would want some explanation of his thoughts on your project. Beware of 1. lots of other consultants he appoints and you pay for. (SE, QS, Planning) 2. choice of contractors, as his favoured ones might be great for him and expensive for you. but that also depends on his/your ability to schedule and manage. But if he is good at all aspects, including value, then the fee might be ok.
  18. I think they want to see the drain runs, ie lines showing the pipes to and from the manholes and gullies.
  19. There is a large section of society who genuinely think they can do what they like to their own building. Some of them see rules and laws as unreasonable if it doesn't suit them. This extends to internal works in listed buildings, where walls are taken out without any permissions. 'My house so I can do what I like'. 'busybodies from the council/ neighbours. Of course some genuinely don't understand the first thing about structures/ heritage. Others understand but don't care. I see myself as the current owner of my house.
  20. You must really hate reading the news then, as there is a lot of poor writing about, especially in the online news sites where they spread the story through the adverts. It is a bit of a technicality here though as he clearly has foundations beyond the wall, and used the cemetery land for scaffolding and work.
  21. It is a few years since I used them. They were wary of blurring the line between trade and customer, and it is best to be straight with them. If you explain the relationship they may then tell you if there is any further discount. Not the sort of thing to shout out to the whole shop though. They used to have 2 different price books, so the professional could hide some margin (or realistically allow a sensible margin and risk). That may have changed. Also I once found that there were sudden changes in the discount structure, for example adding a £20 plinth (that I didn't want) caused a jump in the discount applying to the whole order, and the price dropped a lot.
  22. The current owner, from Oregon, as described in the article. ProDave, do you think someone will buy that with building and negotiate with the council? Or someone will buy the building 'as seen' dismantle and take it away. Do you think £150k represent the value of site and the building ?
  23. What a surprise that must have been The opposite presumption tends to apply re Inverness. The rainfall is "low" at 750mm p/a. Hang on I shouldn't be encouraging people.
  24. There are planning applications and long term outline plans for many thousands of houses around Inverness (population 50,000). I asked who was going to be buying them, and the answer came: 'English'. I don't doubt it as the cash benefit in selling the tired 3 bed semi in the SE and buying the same new is hundreds of thousands. Plus you get to live in a much friendlier area....and the countryside...and.....
  25. I wonder how many people and companies have been involved with this, but who have said nothing. Agents, lawyers, builders. Who sold the land and then 'didn't notice'? It appears to be a kit set on timber baulks so perhaps no founds and can be removed or even sold on. Then nature will reclaim the road. Had a quick look for the sales info but can't find any . Again, didn't the agent ask any questions?
