You can kill a stump. Drill holes into it and pour in what is clearly called 'stump killer'. If it was all accessible you could spray the shoots a couple of times a year until it gives up.
I found a website that gave the formula, but I can't find it again. From memory it is 80mm dia for a 5kW stove with totally external air. Or the size of a 50p coin per kW. It must be a very approximate estimate though, as it will depend on the length and any bends in the pipe. Most kits are of corrugated pipe, further restricting flow, so a bigger diameter like 100mm would be sensible. We put ours in before the floor slab, so used 110 dia drain pipe, then a smaller connection to the stove.
Do I need planning permission for converting my Garrage ?
saveasteading replied to Achu's topic in Introduce Yourself
There may well be planning conditions applying to a property or an area, forbidding conversion of a garage, or at least requiring approval. This would be because the garage is one of a required number of parking spaces, approved with the original permission. ie if the garage is not available for parking, where does the car go? Plus, an extra room potentially requires another vehicle. -
They are used to line basements that are damp, and similar for the rear of retaining walls, to divert water to the base. If the stonework is well done then you are looking at dampness and not liquid, running water. However there are scenarios that could cause issues. More info would help. What purpose, location and structure of the wall. I have never used such a product, but i t is easy to google. I think newton is a well known brand.
To contract or not to contract
saveasteading replied to Jimbo37's topic in New House & Structural Warranties
He has. See link currently 18 hours ago -
I'm not in a position to look into this at present, but they are easy enough to source. You have to consider where any water can go after it runs down the face. Can you drain the bottom?
Is there meant to be an attachment? Many would be interested if you have a blank one, ie no names or location. -
Grey on metal has always been very stable for us. I'm sure it fades slightly but it does so evenly. Putting these mentioned grey colours side by side, especially in shade, there isn't a huge difference. On big panels it is very clear. I agree. Choose the colour you want.
For general info. I recall one project where the local authority desperately needed us to make a project viable. (Tenders well over budget). Their qs was insistent on a highly altered contract that was otherwise industry standard. Every change of course favoured their client, insofar as they even knew why it was altered. So I said that we needed to charge for an expert analysis and probably for the increased risk, and there would be a delay. They gave way and the contract was unaltered. School got the sports hall and the 35% saving. The benefit of proper "design and build". These contracts are intended to be 'fair and equitable' so any change will alter the risk. -
Can we see it? Sounds good. We used to use a 4 page document for very big projects. Clients liked that it was 1. Free. 2 easy to understand. But lawyers and qs reps of bigger companies prefer more words. -
Keeps its colour better though. 15 years ago I had trouble getting this colour, which had many names, but I insisted. So the popularity may be my fault. Although as a sprayed colour on pvc it turned a lovely lilac. I agree that the windows should match the existing for some continuity.
Or cow muck, which filters through. Our ground is pure sand which drains at 17 seconds/mm Except in the covered barn area where there was zero percolation. After 300mm of excavating manure and sand mix, it is clean again. Sheep's feet also make ground impenetrable by puddling clay, just as canals were lined.
warranty - what should I expect/aim for? None. A builder who has a dependable warranty will charge a lot. Common law covers it in theory. Either pay 50% more for a bigger company, or learn up and check build quality as you go. Do make sure the insurance is valid and relevant. Get a copy if it and read the small print. it needs to be for a surprisingly high level of cover.. someone else may know the going rate. -
You pay it. Assuming you have mains the use is a tiny cost. Nothing will spoil relations more than you charging.. Anyway, if you tell the builder you will charge for it, then he will rightly add it to his quotation as a job cost. -
I was very surprised when Nordan said we choose our own straps then showed us some metal offcut from who knows what. What size, how many, what screws, would be better to be specified, or at least suggested.
Never say never. Most of my commercial experience is with steel buildings, so the screw through the frame is simple and very effective. With an ali frame, and glazed on site this is quick and tidy, with the screws hidden.
You can also have a system of running contracts, all written by you. Eg an email saying, dear Dave*, as agreed today, please construct the footings and blockwork up to dpc and backfill. Includes all labour, plant and materials, and details to the drawing I gave you today. To begin on monday and be completed within 2 weeks. Payment in full of £x within a week of completion. There are many gaps in this but it covers enough to prevent a major dispute. * what is the ubiquitous name for builders these days? Stefan perhaps. -
Running water and power sockets..
saveasteading replied to puntloos's topic in Bathrooms, Ensuites & Wetrooms
Correct. I had this clarified. Assume naked, standing in a puddle and not too bright ( or careless , to quote last week's special word.) I can't see any bco allowing any relaxation. But in a utility or kitchen, no problem. Wet hand onto light switch is low risk...maybe a warning tingle and a spark before the cutout trips. -
As AndyS. If you dabble at being clever with the wording then it gives lawyers a lot to argue about. A simple exchange of what you want and what the builder is to do is worthwhile. In very plain English and short sentences. And how payment will be made. I went to a construction talk on contracts where the lawyer said his most constructive work was in setting up contracts, and the most profitable was in arguing clauses meant when surveyors had altered clauses in standard contracts. Moral, use a standard contract or just write your own summary. If you email it to the builder and they start work then that is your contract, signed or not, for better or worse. -
Turfcutter or similar tool - handy for laying slab?
saveasteading replied to Pabbles's topic in Garages & Workshops
If you have garden space it would be a shame to throw away good topsoil. Pile up the top 100mm or so of your site strip, and the grass and roots will die and rot in a few weeks.. You then have valuable soil* to spread on the flower beds, or fill pots or build raised beds. The mini digger mentioned will do that in 2 hours, and can immediately carry on to footings. * 11m3 which you would buy in for at least £500, or pay as much to take away. Look you have saved £1,000. -
Don't assume that the builder or electrician understand all or any if this. I have employed many who may be good at installation, may be qualified to sign it off, but don't know much theory. And I have met some who know how to connect a socket, and have a source of certificates. There are plenty of good ones too. Ask them to explain what 3 phase is. (More power is the wrong answer) Ask them to explain how a 2 way switch doesn't short. Ask them to explain diversity....actually this one might do on its own.
110v versus 240v at start of project
saveasteading replied to Drellingore's topic in Tools & Equipment
Yes, tool hire companies are mostly hiring heavy duty stuff to the industry. 110V is the norm. I would always buy a transformer and cabling, as it is about 6 weeks hire cost. When it gets damaged of stolen, you'd be amazed what hire companies say it costs to replace. -
Probably already said above, I haven't reread. If you need a new cable, an option is to put in an oversized one now. If you don't eventually need it, you haven't unnecessarily committed to higher fees for ever. Then you can upgrade to 3 phase when it suits, if ever. All you need to do is tell your sparks that one car charging us enough. I can't remember the term, for not all machines and appliances being used at once....is it divergence? It is a significant proportion.
Land ownership must be deep in our psyche. I had a neighbour remove a line of Leylandi, then plant more on my side. This despite remnants of an old fence showing the line. Fortunately his wife told him to shift them, and then out tiny child decided to watch him til he was finished. If you want the fence shifted or removed you must tell them now, or forget and relax. If you have proof of the boundary (+/_ 1m on some title deeds), then get it recorded. Or relax. Re the wall, most people don't understand structures, or physics. It might not be sinister.
