ETC
Everything posted by ETC
Getting house signed off - Northern Ireland
ETC replied to DG77's topic in General Self Build & DIY Discussion
It’s not. Not yet anyway. Give it a few years. -
FYI slightly different here in NI. No private BC company only the local council. Also Water and electrical certificates not required. Fire alarm certificate only if a full fire alarm system was installed. All other stuff pretty similar. -
Which internal doors have to be fire doors? if any
ETC replied to Post and beam's topic in Doors & Door Frames
No. -
Nice plant.
As others have said your builder’s QS is only interested in his employer - not you. Get your own QS to look at EVERYTHING. He will charge you a few hundred pounds for the privilege but he will fight for every penny of your money and go through the “contract” with a fine toothed comb. Your contractor will have to justify all costs to your QS and will have to produce invoices.
Clerestorey.
Reinforcing a 1st floor timber floor by adding additional joists
ETC replied to TimL's topic in Floor Structures
A bit drastic.- 13 replies
- floor joists
- joist hangers
Yes. Trimmers between the existing joists and supported on the existing joists with joist hangers as tight as you can get them against the wall at each end. Then new joists supported on the trimmers with joist hangers half way between the existing joists. You might need to double up the trimmers between the existing joists and you should see if your SE is ok with this. Saves having to bolt anything to the existing walls.- 13 replies
- 2
- floor joists
- joist hangers
Trimmers between the existing joists against the walls. New joists supported on the trimmers between the existing joists.- 13 replies
- floor joists
- joist hangers
Timber Frame Soleplate overhanging cavity
ETC replied to john0wingnut's topic in General Structural Issues
Fill the cavity with concrete. -
Christ on a bike! Tomato tomato.
SAA=smoke alarm. HAA=heat alarm.
...............................also - have you been asked for EEWs from the Study and Bedroom 1 on the GF? You should also: Change the SAA in the Laundry to a HAA. Put an SAA in the Boot Room (circulation space). Put another HAA in the Kitchen/Family (a HAA has an effective radius of 5.3m).
Make the roof light in Bedroom 2 a compliant EEW.
I really think you need professional advice. You should really speak to a civil engineer who specialises in basement construction.
They won’t. With a roof conversion you will need EEW from each first floor habitable room plus an interlinked SAA no more than 3.0m from each bedroom door.
Side Return Extension Victorian House advice needed
ETC replied to Sam odell's topic in House Extensions & Conservatories
Bricks or dense block at this point?
ETC replied to Post and beam's topic in Bricklaying, Blockwork & Mortar
