Everything posted by ProDave
Well the prices are in. Steel Roof sheets.co.uk quoted £405 including VAT but not carriage with "phone for delivery price" and when I told them where I was they said delivery would be about £500 and they would get a quote for that if I really wanted. Er no thank you. Planwell were £516 including VAT and delivery. Then I tried the two local merchants. Travis Perkins were £342 including VAT and delivery, and Jewsons were £329 including VAT and delivery. so Jewsons have the order. The lesson there seems to be forget the specialist and just go to a builders merchant.
I honestly could not tell you what make my hammer is. I chose it because it has an orange handle and is ever so slightly less hard to find when you have put it down somewhere. The only hammer I have ever broken was an old wooden handled one and I was trying to remove a really stubborn nail and the handle snapped. More modern metal handled hammers don't seem to suffer from that. Otherwise they differ in size and weight.
Very cheap MVHR
ProDave replied to sphannaby's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Each heat exchange unit has two rectangular filters, so 4 in total. They are the sort of plastic mesh stuff that is used for grease filters in cooker hoods. So you can buy it in sheets and cut to size to make your own filters when they need replacing -
piling Piling: Preparing for the Quotes 2 - costing
ProDave commented on ToughButterCup's blog entry in Salamander Cottage
So you need piling because you have made ground. The piling rig can't operate on made ground. So you have to dig it all out and replace with compacted hardcore. (a piling mat) Now you have compacted hardcore do you need piling any more? This sounds like you have just laid the base for a passive slab?- 4 comments
- costing
- project management
I had not heard of Udireco before, but that is very similar to what I have used. My timber frame is clad with 100mm thick Pavatex wood fibre board and then rendered direct onto the wood fibre. The other one I am aware of is Steico, but Pavatex worked out cheaper. Having just googled Udireco, it seems the main difference is it has a soft backing layer to conform to irregular walls if retro fitting to an existing masonry building. you won't need that "feature" if fitting it to a new build timber frame, so have a look at Steico and Pavatex as well. As far as I know I am the only one on this forum to have used this system. There are a number of subtle changes needed to the timber frame system if adopting this sort of cladding, one being the OSB racking layer goes on the inside of the frame (I lost count of how many people told me my frame had been put up inside out) And because i have no blockwork skin, the structural engineer specified some parts of the building need two layers of OSB on the inside to achieve sufficient racking strength. There is lots more about it on my blog, but some of the early stuff still hasn't been copied over from my old blog on ebuild. I did all the wood fibre cladding myself (though not the rendering) and only finished it earlier this year. Because it was a slow process and I knew it was going to take time to get it all clad, parts of the frame were just temporarily clad in a sheet of damp proof membrane to give it temporary protection from the weather.
Floating or Fully Bonded floor over UFH
ProDave replied to Stones's topic in Wood & Laminate Flooring
I am wiring a new build that has exactly this. So they obviously think it's going to work. Check what underlay they supply, in this case it's a "special" one for UFH that is perforated with lots of small holes. I am there again on Friday so I can see if I can find out what underlay they are using. -
Hi and welcome to the forum. That looks like an efficient use of space and quite simple. Why not build in Timber frame which is so popular up here?
A few tips if you are making the frame yourself. Try to design things to be simple to build. For instance a roof pitch of 45 degrees makes everything simple. If you had say chosen a roof pitch of 42 degrees, you would curse that decision at every single angle cut. Make the panels, each one pre covered in it's outer membrane (plus overlap) so when you put the kit together you just have to staple to overlaps and it's almost instantly watertight. Even if not in Scotland, I would suggest using the Scottish approach and clad the roof with solid sarking board (usually OSB or ply) then put the membrane on and almost instantly the roof is pretty watertight. Far better than the English method of flappy membrane or felt stretched across between rafters. The length of time it will take to erect the frame and get it pretty watertight is insignificant in terms of what exposure to water the frame can withstand. If you erect the first flor first and it will be a while before the second floor and roof goes on and you want a working platform, temporarily clad the floor in cheap OSB and regard it as disposable.
My guess is it's a single phase supply. Most of the run done in large cable because of the length (they used wavecon 95 for the run down the road from our transformer) And then a junction to convert down probably to 35mm concentric for the run under the road and into the house. I saved about £1000 on my connection by digging a trench and digging the connection pit (so they didn't need to bring their own digger) which in my case halved the connection fee. I still think paying £1000 for them to pull a cable through a duct in a trench already prepared and just connect both ends was a lot of money. I then filled it all in after they were done.
- 22 replies
- electricity
- new connection
(and 2 more)
Log burner stove for large open plan room but MVHR
ProDave replied to readiescards's topic in Stoves, Fires & Fireplaces
I am planning to draw the air for my stove from the ventilated under floor space. It's on the drawings and building control have approved them so it must be okay. -
I was going to ask about the S106. Aren't self builders exempt from that now? And welcome to the forum.
Virtually all that trenching and the road crossing should be contestable work. The road crossing has to be dione by an approved contractor or they may even be able to mole under the road. As above, are there any services that need to cross that road? get ducts in at the same time for all of them so you only have to have the road up once. The trench across the 3rd party land can be done by anyone, even you if you had your own digger (a number of us here have or had our own machines) Get independent quotes for that part of the job and the price may come down a lot.
- 22 replies
- electricity
- new connection
(and 2 more)
I have always managed to get Aico RF bases for about £20-£30 each on ebay. That's a couple of hours of a sparky's time trying to fish a cable through a long impossible route. Sometimes it is the cheapest option.
Check manufacturers instructions. some are happy to be on a vertical or sloping wall, some not. Keep at least 300mm from a corner or a light fitting. If you can't get a link cable from the old to new part of the house, use radio link bases to link them. Then you only need power to the alarm in the old part of the house. Not the cheapest, but Aico are my favourite make.
That is something I have wondered about and will investigate when I get a system running. My thought if your heating demand is low, and you have all day to heat a tank of water, is in such conditions run the heat pump for say 20 minutes then off for say 40. That would have to be by an external timer. If doing that, and giving it time to defrost on it's own would avoid a defrost cycle then it would be worth doing. The other efficiency related thing i want to look at is separate the heating of the DHW tank and the heating of the buffer tank, so it only ever heats one at a time. When it is heating the buffer tank for the UFH then I would want to set point temperature of the heat pump set very much lower, than when it is heating the DHW tank. Again that will need some custom controls.
piling Piling: Preparing for the Quotes 1 -piling method
But now for us lesser mortals, you need to explain what "Stone columns (ground improvement)" actually is. (with a pretty diagram)- 10 comments
- due diligence
- spons
What a different climate you live in. A couple of weeks in winter when the daytime temperature does not get above -10 is not unusual here. Re number of showers. Is that "man showers" or "woman showers" It takes me about 5 minutes to have a shower and wash everywhere and wash my hair (granted I don't have a lot of that left so that bit doesn't take long) It would be a "short" shower if SWMBO is out in less than 20 minutes.
I believe all unvented cylinders have pressure and temperature relief valves so there is no problem.
Whats normal practice for protecting Rockwool during build?
ProDave replied to readiescards's topic in Heat Insulation
A previous rental property, when we got it back from the tenant, I found there was a leak in the roof above the bathroom (would have been nice if the tenant had told us the roof was leaking and dripping into the bath) I emptied that bit of the loft of the sodden insulation and just laid it out in a bedroom, expecting it to be scrap. But in the couple of weeks it took me to fix the leak and re board the bathroom ceiling, the insulation had all dried out, so i put the old insulation back. -
I joined the "poked them with a stick" club. Our previous house had a wasp nest in the roof void above a bay window. I put on all my motorcycle leathers, gloves, helmet, boots. Got SWMBO to tape up all the joints with masking tape. Then I squirted half a can of Raid into the void, before poking the nest with said stick to really stir things up, then emptying the rest of the can. Sure they swarmed around me, but then never got in. I nearly suffocated and sweated like a pig though.
Finally started de-construction
ProDave replied to dogman's topic in General Self Build & DIY Discussion
In a previous employment, we imported a lot of stuff from Brazil. What lovely packing crated that came in. For a while it was all just burned on site on a bonfire every week, and employees could help themselves. I still have my trailer planked in that lovely hardwood, and a lot of the stu walls of the extension in a previous house were made of the frames of the packing crates. Sadly this scrap wood became "registered waste" and it was no longer allowed to burn it, or even give it away, and they had to start paying a contractor with an appropriate waste licence to remove it and dispose of it. -
My thoughts on the Thermals store Vs Unvented hot water tank. An unvented tank heated to 45 degrees, will deliver hot water at pretty much 45 degrees until the tank is empty, when it will go cold very quickly. A thermal store heated to 45 degrees will initially deliver water at 45 degrees but the delivered water temperature will start to fall off unless heat input can keep up with the rate of delivery. So for practical purposes, to achieve the same useful hot water delivery, a thermal store needs to run at a hotter temperature than an unvented cylinder. I did an experiment recently, I ran a kitchen sink full of water that was as hot as I could tolerate. It was on the verge of burning to keep your hands in it for more than a few seconds. I then measured the water temperature, and it was 45 degrees. So that indicates 45 degrees is plenty hot enough for dishwashing, hand washing etc (mixed with cold water) About the only "need" for water hotter than 45 degrees might be for thermal mixing showers. That is only because to achieve say a 40 degree operating temperature, they might not be abler to blend so far towards hot and maintain stability, so it may be necessary to have hot water for a shower hotter than 45 degrees, just so the mixer can blend it back down properly. That will only be found by experiment and is likely to vary from one shower mixer to another. Therefore my plan is deliver raw 45 degree tank water to all sinks and basins, and just have the in line boost heater for showers, if it proves necessary. Some experimenting will be needed. An obvious disadvantage of storing hot water at a lower temperature is there is less energy stored in the tank. So you will probably want a larger tank than would ordinarily be recommended for the usage. Re unvented tanks and sign off. I installed the last one myself. Building control were happy with that though they did check the discharge arrangements. There is also a guidance note from nhbc that explains how to use a waterless trap to take the discharge into a drain stack to avoid a vent pipe to the outside. that is what I will be doing, and referring building control to that document if the disagree. then arguing it up the chain if they still disagree. I have attached the nhbc waterless trap discharge note. NHBC_discharge_guidance.pdf
Hurry up... and wait
ProDave commented on curlewhouse's blog entry in Sips and stones may break my bones...
It might be a "time of year" thing. Every year is exactly the same for me, November and December goes completely mental, always my busiest time of year. Everyone's project MUST be finished by Christmas (and for me that's two new builds at the moment) All building trades I meet at this time of year are also running around like headless chickens. Come January, all will be calm, and tumbleweed will be blowing across the roads. You might have better luck then. I would always say stick with builders who have been recommended word of mouth. -
Bathroom worksurfaces v Kitchen worksurfaces
ProDave replied to Fallingditch's topic in Bathrooms, Ensuites & Wetrooms
I have only just read this thread. My immediate question is why use a "packaged" solution for a pocket door? all i have ever done (and seen done) is to hang a standard door on a sliding mechanism, and the joiner to construct the "pocket" for it so slide into. With Worldwidewebs question about a light switch, the answer is no problem. I just did one like this where there was a socket within the pocket area. The joiner framed the pocket in 2" by 2" timber each side of the door. So the "challenge" is to get a socket, or switch, within that 2". No problem at all with a standard 25mm switch box, and the wiring within the pocket area enclosed in pvc conduit so it can't stray and get tangled with the door.
