Everything posted by ProDave
What boiler to go with Solar thermal and wood burner
ProDave replied to geoffdg's topic in Solar Thermal (ST)
It was the week between Friday 1st Feb to Friday 8th Feb. I read my meters and record their readings on a Friday afternoon. So I can't be more specific which days. How can you accurately measure oil consumption by the day or week? Heating bill so far this winter £164- 97 replies
- solar thermal
- wood burner
So £150 per man day, quite reasonable, probably more for the digger driver and less for the others. What about plant hire costs?
If you think your retaining wall is big!
ProDave replied to Moonshine's topic in General Structural Issues
Where I used to work made a car park by reclaiming a steep bank, think of that with the car park at the top of it. I watched them build it. It was just earth. Built up in layers using a former to get the angle right., Reinforcing meshing at the outside edge and turf laid as they went, then the soil compacted before moving up to the next layer. Parking your car for 8 hours a day at the top of that was one thing, I am not so sure I would want to live at the bottom. In particular who is responsible for repairing or maintaining it? It just shows the stupidity of our planning system that land like that, which is not rteally "ideal" for building on gets planning, but I bet an adjacent flat field would not. -
Mine was designed at the outset to be using biscuit mix so the joists were sized for the extra dead load on them. So downstairs we had UFH in biscuit mix. Upstairs, just in the bathroom and en-suite we have UFH with spreader plates. I have to say we are disappointed with the heat output from the upstairs. It may just be because the heat has to get through a layer of chipboard flooring, the tanking membrane, tile adhesive then porcelain tiles that it seems less effective compared to downstairs where it only has to get through 20mm engineered wood flooring?
My worst case heating week has been 95KWh of electricity, the week it was down to -14 one night and not above 0 in the day. So that averages 13.7KWh of electricity per day. Assume a COP of 3 for the heat pump and that's 40KWh of heat per day, or equivalent of 1.7KW of heat into the house continuously. That is a little under the estimated 2KW heating requirement so shows how incidental heat input is helping reduce the real figures.- 97 replies
- solar thermal
- wood burner
Ask him for a breakdown of how he arrived at his price, then start "discussing" it.
You need a box spanner in there. How about just fit a new tap, one of the nice modern quarter turn ones with a ceramic cartridge instead of old fashioned tap washers? It could also be a furred up pipe.
+1 for buying from Build Plumb Plastics, that is where our drainage stuff came from. Make sure you get the treatment plant fitted correctly, i.e. concreted in if you have a high water table. Don't forget a SWA cable to power the treatment plant while you have the man and digger on site.
Stuck plunger inside the tap mechanism. Especially if it is an old design of tap. Turn the water off, remove the tap head and check.
With thermal stores there are many variations some with heat exchangers and some without. My own UFH runs direct from the ASHP. So the primary circuit with inhibitor is from the ASHP to the UFH and to the UVC heat input coil. Some use a buffer tank with UFH in such a situation. I am not sure if that can be combined with an UVC or not.- 97 replies
- solar thermal
- wood burner
An UVC has potable water inside it, so that is the water that comes out of the tap. It is heated by a heat input coil that runs from the sealed primary circuit with inhibitor, To use with a heat pump you should get one with a high capacity large area input coil. You can have more than one input coil for different heat sources. A thermal store has never changing contents, that just gets heated and cooled time and time again. Hot water is delivered by passing cold mains water through he aheat ercchange coil at the top of the tank, or through a plate heat exchanger.- 97 replies
- solar thermal
- wood burner
I am pretty sure (though they don't make it clear) that the Ecodan cylinder in an UVC not a thermal store, so it only has to heat to target temperature not higher. With a 270L tank I am surprised you have not run out of hot water. Obviously the ladies in this house use more water than your household as after 2 "ran out of hot water" incidents, I added an electric modulating water heater as a "reserve"- 97 replies
- solar thermal
- wood burner
The obvious thing is try a new thermostat. I expect you are wanting THEM to change it?
- 186 replies
- sunamp
- energy efficiency
What has he quoted you? Is the drainage field OUT of the treatment plant done yet? That could be more expensive than the pipes to connect IN.
Drainage field / soak away detailing for submission
ProDave replied to Roz's topic in Building Regulations
All you need is your percolation test results, from which you calculate the area of land needed, then a plan showing where on the plot (or off the plot) that soakaway area will be. Allow for minimum distances from the soakaway to buildings, site boundary, highway and any watercourses. You are demonstrating that you have a design that works for the plot. Exact layout of pipework within that area does not matter. -
Where is this "trip"? Are we talking the pop out button on something like an immersion heater thermostat?
- 186 replies
- sunamp
- energy efficiency
That's nearly £1000 per square metre to finish a shell. What are you expecting to pay? What skills do you have to do any of the work yourself? What is your timescale? Obvious savings, they don't need "site facilities" if you offer use of the WC in the main house etc Cleaning, rubbish disposal, landscaping etc can you do any of that yourself?
Thermal store, as soon as you start drawing heat from it, the temperature starts to fall, so to get a sensible capacity of actual usable heat, the temperature in the stoer needs to be a lot hotter than the water temperature you actually want. otherwise you will only get hot enough water for a very short time. On the other hand, an unvented cylinder delivers water at it's stored temperature and continues to deliver that temperature until it is almost empty. So a heat pump works well with an UVC but not very well at all with a thermal store.- 97 replies
- solar thermal
- wood burner
Blown beads is a less good insulator so needs to be thicker, BUT it stands a LOT more chance of being done right and actually working, The big problem with solid boards is detail. It is very easy to cut them a bit under size and have air leakage past the insulation making it very much less effective. Do you really trust the builder to spend the time and care to get it right when your "target" is as cheap as possible?
Or my case hypercheap DIY install 4KW for £1500, I hope it to have paid for itself in 5 years.- 97 replies
- 2
- solar thermal
- wood burner
Not a construction method I have seen. It would not be allowed here but as the post above shows it may be okay where you are.
Is that describing a timber frame? If so you normally have an air cavity between the brick and the timber frame but that says 50mm cel;otex. That is not a wall make up I recognise.
And the report again perpetuated the myth that space heating is the largest household expense. It is NOT. I repeat my claim that Council tax is the largest cost of owning a home, with little chance of ever reducing it. Initial estimates suggest my Council tax will be not far from 10 times my heating bill. I repeat my claim to be in "council tax poverty" and I suspect in reality a lot more people are, than those in "fuel poverty"
That was a poor install then, I have seen several and done the wiring for 2, and in all cases the pump and controller was in the plant room next to the thermal store. The only wiring in the roof was the temperature probe back down to the controller. I believe on the plumbing side there is a bleed valve at the highest point in the sustem but that should be inside the roof and accessible.- 97 replies
- solar thermal
- wood burner
Quick bit of help please: which way round?
ProDave replied to ToughButterCup's topic in General Construction Issues
Another vote for the one on the left, it is designed to bite into the insulation.
