ProDave
    424
ProDave last won the day on April 2
ProDave had the most liked content!
About ProDave
  • Birthday 03/09/1963
Personal Information
  • About Me
    Self builder in the Highlands, see my blog here <a href="http://www.willowburn.net" rel="external nofollow">http://www.willowburn.net</a> Heading for retirement, our "Adventure before Dementia"
  • Location
    Scottish Highlands
34693 profile views
ProDave's Achievements
Advanced Member
Advanced Member (5/5)
9.2k
  1. I briefly did some work for a passive house building company here. I was not allowed to drill a hole through the external wall of the building (i.e. through the air tight layer) If I needed a hole, I had to discuss it, and one of the joiners would drill the hole in the agreed place (not always where I wanted it) and they would then seal the cable penetration afterwards.
  2. How did you even get that past Building Control? Means of escape?
  3. It is supposed to make the build more precise and more controlled. But the price. £800K for the build, not including the plot (another £650K) Eye watering figures for me, both of them. And I don't recall them saying how many square metres. Also no details of insulation levels, heating system etc. And in spite of it being built in a factory, it appears the plumbers got no thought in the design and they still had to work out pipe routes and drill all the holes just as they would in any other build.
  4. And this is why I dislike "plastered on the hard" forcing cables to be chased in. Much better with a timber batten service void and plasterboard.
  5. When I have been wiring a new house for the client, the first thing I do is go round with a tape measure, a big black marker pen and put a cross on the wall where all the sockets etc will be according to whatever drawings I have been provided with. Then I walk round with the client and discuss their needs, wants and preferences. Invariable most of the socket positions get changed as do lighting positions. As to kitchens. I have yet to see a new house built with the kitchen layout shown on the plans, another thing that gets changes as things evolve so don't even start the wiring for that until the kitchen is on order. What I am saying is don't get over excited about drawing plans. Unless you are the unusual client where nothing changes when you see the building for real.
  6. Electric cables in a wall must run in a safe zone. Broadly speaking a safe zone is horizontally or vertically from an electrical accessory, e.g. a socket, or within 100mm of the corner of a room or ceiling. If you want to run electric cables around a room then do so at socket height, and ensure each wall has at least one socket to create that safe zone, and that is where all your mains cables can correctly run around a room.
  7. BUT electric cables must tin in safe zones. So to ensure this the electric cable tray must be within 100mm of the ceiling all the way across the room. The data cable tray can be at any height you want.
  8. Call that a Beech? Nah,
  9. https://www.toolstation.com/universal-top-fix-seat-bung-kit/p46310
  10. Post a picture of the other nut. It will be possible to buy another one (probably sold as a pair)
  11. Yes LPG gas. Turn off at the bottles. Back to the subject of isolator switches for kitchen stuff. I put mine in the back of the cupboard above the ovens. I can inform our learned readers, it is an absolute mare terminating cooker sized cables in a switch box at the back of a cupboard when you are working on a step ladder reaching into the back of a cupboard so working at arms length. I do question is it really necessary, particularly for an oven. If there was a fault is is probably quicker to go the consumer unit and turn off the clearly labelled Oven rcbo than pull the stuff out of the cupboard to get to the switch.
  12. Water and gas off when we go away. Leccy stays on for the fridge, and for the PVR to record stuff while away.
  13. Make the plywood a very snug fit and glue the edges to the walls of the cabinet frame as well.
  14. Good call. My neighbour had a huge tree right next to his bungalow, it would have flattened the bungalow if it had fallen onto it, and if you were in the bedroom next to it, it might be your last nights sleep. But also across the road was the 11KV overhead line. SSEN removed it for free when he pointed out if it fell down it would break their overhead line.
  15. I would cut a sheet of 10mm ply to be a snug fit in the recess behind the cabinet, fixed there with your favourite gap filling adhesive. Fix the cabinet with the official fixings into plasterboard fixings, then two screws through into the studs one top one bottom, going through the flimsy back and your 10mm ply
