Tom
Everything posted by Tom
EPS 70 doesn't have the same compressive strength as PIR, so be careful if you hope to use it under a ground-bearing slab.
hot/cold water supply to taps - manifold going to secondary manifold?
Tom replied to Tom's topic in General Plumbing
Thanks Conor, would certainly make sense, I guess I'll keep the 10mm individual runs to the hot outlets? -
I plan to have continuous runs of Hep2o running from hot and cold manifolds in the plant room to all the outlets, but wonder if it would make sense, for the cold at least, to have a secondary manifold in the kitchen. The kitchen will be a good 10m away from the plant room, so should I run say a single 15mm pipe to a secondary manifold here, and then 15mm runs to taps, appliances etc, or 15mm runs continuous from the plant room to each of the planned outlets? If the latter, should this be a dedicated pipe for dishwasher, kitchen sink, utility sink, toilet cistern, hand basin etc? Thanks all!
Qiuick question: do I need to use a rest bend (https://www.toolstation.com/rest-bend-110mm/p12565?utm_source=Rakuten&utm_medium=affiliates&utm_campaign=4639012565&utm_content=Redbrain&ranMID=46390&ranEAID=pfxNKSnglIM&ranSiteID=pfxNKSnglIM-d6AfLPKasIssE3m68p_otA ) at the bottom of an internal soil stack, or just a standard bend (https://www.toolstation.com/single-socket-bend-110mm/p43723 )? Also, does it matter if the bend is a double socket, so or should it ideally be a "male" end on the bend, going in to the "female" socket on the pipe run. Thanks all
Just For Men group buy?
No external finish on the Nudura yet, but we plan a mixture of metal sheets and vertical timber cladding. No sills either, apparently can't go on until walls clad. By the way @Conor, assume your build is Nudura, did you find the odd drip of water making it's way through the blocks? Certain areas seem to let water in, particularly where there is a concentration of water falling down the external walls (no gutters yet). On the SW aspect in the prevailing wind I even find the sill EPS closers get completely waterlogged, guess water making it's way to the vertical closers and then tracking down. I'm keeping my fingers crossed it will all stop when the gutters are on and the walls felted and clad... It's certainly been a long winter walking around a deserted site looking at drips coming down the walls.
Sigh.... So, the slow motion car crash of our glazing seems to finally be coming to some sort of climax. Firstly, Internorm windows and doors supply and fit by local (large) firm. Started badly as they fitted into the Nudura opening without any of the recommended Illbruck tape/trays, just a bead of silicone. Cue them having to take them all out and redo. Since then the two doors with large sidelights have continued to leak - firstly around the door sash itself, and also also between the frame and the tray (they cut the tray at the back for some reason, then tried to fill the gap with a wodge of silicone). They have been back multiple times to try and readjust the doors - now they are very hard to open/close as everything is so tight, and they still leak. In addition, they didn't like the idea of fitting on to the horizontal Nudura EPS cavity closer, so unilaterally took the decision to remove this and replace with a length of 6x2. This has spent the whole winter getting wet because of the various leaks, and is now looking decidedly green in places. At the time I suggested using compacfoam, but they were adamant they weren't fitting "on to foam, mate". Secondly, the large triple glazed sliders (total 6m and 4m runs meeting at a moving corner). For these we agreed a price with a London-based suppplier at the back end of 2021. We paid a deposit, best part of 6k - they don't take credit cards, of course. Due to all the delays etc we are only now anywhere near getting the site survey and the things fitted and they, I guess reasonably, said they would have to reprice it due to the time elapsed etc. They have now come back and they are 65% (!) more. I just got a revised quote back from the firm they were originally bidding against (but that we didn't go with), same doors etc and only a 24% increase. I just had it out with them on the phone, asking how they can possibly justify a 65% increase. Usual guff about glass and aluminium costs going up - though I pointed out that if the increase was based on this, then it would be over a 100% mark-up on these costs. I said we would have to ask for our deposit back and walk away, and of course they say non-refunable etc. I said they have a moral and likely legal obligation to refund, and that if it went to law I was very confident it would come down in our favour. They have now gone back to their estimator and will get back to me. So, basically, I am feeling absolutely shafted at the moment and thoroughly pissed off. I feel that the door company are blatantly profiteering as we are on the hook with the deposit. (65% FFS!) Has anyone any experience of small claims in these circumstances? Would we be in a good position to claim our deposit back if push came to shove? Also, the Internorm doors. I have tried to reach the installation manager multiple times over the last few days and he isn't picking up and when I leave messages at the office he isn't returning the calls. At what stage can I tell them I will get another firm to rectify and present them with the bill? I kind of want the units to come out, compac foam (or at the least concrete) to replace the soggy timber, and eveything back in as it should. On top of all that, my beard seems to be going grey with all this stress. Gaaaghh!
Does Class Q mean residential status is granted
Tom replied to ChrisF8's topic in Planning Permission
..and also if you do get full planning for knock down and rebuild it will often be granted with normal PD rights removed. -
Have a look here Jamie: https://www.panelsandprofiles.co.uk/ Think we'll probably go with these guys for the folded gutter as well as the profiled panels for roof/cladding.
Aaaghh! There's a total of about 60 linear meters to do! I'm thinking that where the membrane comes up the end of the composite panel I could just chase it in - a cut along here with a circular saw and tick the membrane in?
The composite panels sit on steel rafters and Z-purlins We're too far down the road with the hidden gutter to turn back now! My drawing does look complicated, but it looks a bit simpler in real life... I can easily lower the front lip of the gutter to encourage any overflow out the front - and likewise the "tail" going up the roof is a good 200mm.
Sorry @DC5, only just saw your reply. The Alutrix looks like it might do the trick, but is considerably more expensive than a simple membrane and tin of contact adhesive and I'm not sure if it would be overkill. The wall/roof junction is a bit of a pain to detail right, not least as we are going to fit a hidden gutter, the build-up goes something like this: 1. Gap between composite roof panels and top of nudura walls filled in with PIR, the membrane in question then bonded over this to make as weather tight as possible. 2. The composite roof panels then have battens fixed to them, the folded gutter profile fixed to the ends of these, a counter batten over the top and then corrugated steel roofing sheet to finish. 3. Finally, batten - which also supports the outer edge of the gutter, counter batten and vertical timber cladding to the wall. Simple, eh? The membrane bonded to the PIR shouldn't be doing much work, the void should be totally covered by the gutter profile and if the gutter blocks and overflows it should go over the front lip and down the wall (I'll be putting another membrane up the vertical batten and under the front lip of the gutter). Any thoughts?
😟 Any ideas? Are any specific adhesives to be avoided with PIR?
Hello all. Woke up in the small hours pondering this, I plan to cap our nudura walls with PIR laid flat and cut at an angle and want to stick a waterproof roofing membrane (eg https://www.toolstation.com/sark-it-non-breathable-membrane/p26933?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dc&pcrid=&pkw=&pmt=&gclid=EAIaIQobChMI15f627vO_QIVd4BQBh0j8gwcEAQYASABEgKkJ_D_BwE&gclsrc=aw.ds) on to this - what adhesive would work on both the foil face and the cut edges of the PIR? Would a solvent-based impact adhesive do the trick?
Lath and plaster cavity a significant cause of heat loss?
Tom replied to BarumMike's topic in Heat Insulation
Hi Mike - welcome to the forum. Sounds like whatever you can do to reduce convection currents would help. Perhaps some rockwool pushed in from the top? This would still be vapour permeable which is always a good idea with old houses. Tom -
Thanks Dave, looking at those I think they are going to be a bit big, only got 100mm depth to play with and a distance of a few meters to the stack. Would a shower trap not do the same job?
Trouble is I don't think a smallholding is agricultural either. There is a minimum size, and I don't think 2 acres is it.
It doesn't matter what the land is classified as, it's all down to the buildings themselves - and if they are stables that have been used for horses, then as above I'm pretty sure you can't go down the class Q route. I would forget the structural engineer now too - whether or not they are structurally capable of being converted is kinda moot. Get an opinion from a planning consultant - if they believe that they are worth pursuing then you find a "friendly" structural engineer to write a very carefully worded report to go along with the application. When you have the part Q, apply for full planning to knock down and rebuild (planners often take the Class Q as a fallback position so are then inclined to grant full planning - at least in some areas, search your local planning portal).
While I'm STILL waiting for our roof to be finished, I've been busy thinking how I can make our build more complicated and expensive, and have started to think about the plant room and whether it might be an idea to have a drain in the middle of the floor. The room won't just be for the plant but it's also a boot room etc, so it might be useful to have a drain and would also be useful if any pipes in there sprung a leak. There is already a 110mm stack coming up through the floor that I could T in to, and the screed is yet to go down, so have about 100mm height to play with. Should I forget the idea? Are there proprietry "floor drains" for this sort of thing, or could I just use a wet-room shower trap? Thanks all
If they are stables, and have been used as such, then as far as I'm aware they aren't agricultural so aren't eligible for part Q Happy to be proven wrong though, and agree with Temp that getting the opinion of a planning consultant would be the first step. Different planning departments seem to interpret the rules slightly differently so local knowledge would be key.
Are you not thinking of taped foil-backed insulation boards?
