Tom
Everything posted by Tom
^^^ this We went down the Part Q then full planning for knock down and rebuild route, made things a lot easier than they might have been. Especially as the "survey" for the Part Q was a little optimistic, to say the least.
Congrats, sounds exciting! You say a basic structural report states suitable for conversion - I'm guessing this was as part of the application relating to Part Q PD rights, is that correct? Tread carefully, as such structural surveys can be pretty much useless. You pay the structural surveyor to essentially say what you want them to say for the purpose of getting the Part Q. I would prioritise getting your own full survey done. Some pictures would be great if you could post them!
tank museum
Think yourself lucky, our suspended slab ended up with FOUR layers of A393 mesh. No idea re shear links though, sorry, but 100mm cts means 100mm centres, so spaced every 10cm.
Have you thougt of getting sheets with flying ends? Makes overlaps easy.
British Gas computer says no - why??
Tom replied to Tom's topic in General Self Build & DIY Discussion
The issue, I think, is that they are massively oversubscribed for their ASHPs as they are so much cheaper than everyone else - any job that they might actually have to use some brain power and they just seem to want to sack it off. -
Exactly! This is the thing, only one phase will be going to the consumer unit, like every other frigging house in the country, but that fact I had mentioned 3 phase just seemed to turn everyone in to brainless idiots. -
I'm effing livid. I was in the process of getting a quote from British Gas to fit our ASHP - I waited 6 weeks for a site "survey" and was told the actual fitting of it would be a 4 month wait after this. I was prepared to do this as their indicative quote was less than half others. I've even had an electric boiler fitted to get some heat in the interim. They now turn round and say that as we have 3-phase at the property they can't do it, as "none of their engineers can work on 3-phase, mate". WTF? Presumably my electician will be putting our consumer unit in and this will be wired up to one of the three phases (one of the other phases being used for our PV). The BG engineer will surely just be wiring up the ASHP to the consuer unit and so will be downstream of any 3-phase electrics. Is that right? I tried to explain this to the clueless BG guy on the other end of the line but it was just computer says no. Who's right here?
New steel, but a few rust spots coming through the red oxide in places, hence why I rubbed it back gave a spray of Dinitrol and two coats of Hammerite. It would have been fine had the decorators not covered in emulsion. Any tiny spots that would have been invisible are now visible due to leaching out into the emulsion.
I didn't explicitly say not to paint the steels as assumed no one would paint steels in emulsion. I was clearly wrong. The situation remains that I need to rectify it and there is over 50m of steel! Would a coat of zinsser suffice or would it all peel off eventually if there is emulsion on the hammerite?
I didn't ask the decorators to spray the steels with emulsion as I fully intended the hammerite to be the final finish. I specifically went for the satin Hammerite because of this.
What might be more of an issue though is the emulsion flaking off the hammerite later. I am paying a lot for the decoration and seems like this is a major mistake
Definitely rust leaching through, I'll get a pic if I can. Thanks for all that info @Nick Laslett, however these are internal steels in a heated environment, so classed as C1 I think.
Yep, internal. Not being boxed in and doesn't need protection. There were a few rust spots coming through the red oxide so I gave a spray of dinotrol where it was obvious, then two coats of Hammerite over everything. My intention was this would be the finished colour, but the decorators, in their wisdom, have decided to just spray everything with emulsion, which has now caused some rust dicolouration to bleed through. Would have been fine if they'd left it as-is. Don't fancy having to rub it all back as there are a lot of steels and a lot of areas where these spots have come through. Kind of think it's the decorators responsibility to sort TBH! What think you?
As ever two steps forward, one step back. Before the decorators started I coated all our exposed steelwork (already red oxide primed) with two coats of satin hammerite (oil based, 8yrs guarantee). The decorators have gone over everything in emulsion and quite a few rust stains have leatched through, which is annoying. Would another dab of hammerite on these work as an adequate stain block or should I try something else? The main contractor covering the internal works have suggested "rust-oleum or similar", but I need to get this right. Thanks all
Going to box out the reveals in birch ply. All interior joinery in the same. But as with every detail on this build, seems like you go slightly off-piste and everyone seems to struggle.
I agree. Just sticks in the craw a bit. Especially so when some walls are mostly window!
I did think about this but the boards have already been skimmed so I'm guessing theyd just say too late...
So @nod would you say I'm wrong to expect a reduction, albeit small, if they are no longer doing the reveals?
Exactly, so why shouldn't I be entitled to a cost reduction?
This is a bit of a boring topic unfortunately, but I'm hoping for some guidance here if possible. Our dryliners are coming to the end of their work and have added all sorts of additional costs for additional work done - fair enough, but there was one major change early on, in that I did not want then to do the internal sills/window reveals when they were initially expecting to do these. I have queried why the cost for this has not been deducted from the final bill and have been told "it is completed and priced as a block measure, so the openings are never deducted from this measure whether the dryliners complete the reveals or not unfortunately. The additional areas for openings would be used for the wastage percentage. The same applies to bricklayers and renderers". Is that reasonable? Seems every minor ammendment is costing me, but when it comes to a possible saving it's "computer says no". Any thoughts? @nod?
