Chanmenie
Everything posted by Chanmenie
Finishing window reveal around brackets?
Chanmenie replied to BadgerBadger's topic in Windows & Glazing
The weight is on the floor. My build is ICF so I inserted 4 x2 timber into the EPS bolted to the concrete core then used brackets to fix the doors -
You can fit door frames with brackets same as those window pictures -
best type of SDS chisel for backboxes
Chanmenie replied to crispy_wafer's topic in General Self Build & DIY Discussion
I use a carbide tipped blade, but my blocks are pretty soft -
Multitool is good for this, much quicker than drilling, plus you don’t need to chisel out -
I used the BUS Grant and got a Veismann system installed for a total cost to me of £1800, the retail on the system alone would be in the region of £10k so I was well happy. The best advice I can give is to design your house so the ASHP is just the other side of the wall from the plant room. My installer said mine was the simplest install he’d done, hence the labour cost was low, and he only charged me cost on the system
Well fortunately for me my floor is concrete so won’t be moving, and it is very level, I was thinking of doing floor first and covering it with Protec sheets as I agree with the possibility of it getting damaged
Why’s that ? it seems most tile the floor first
We keep it like that to deter visitors 😃
Welcome from another Norfolk member
Also consider Keylite
Yes it’s very sticky
Can you lap the new DPM up the sides to meet the old one and tape it with double sided DPM tape
I think I’ll come in at around £1000 a meter maybe a little over with the landscaping and drive way, but I’ve done most of the build myself. like Nod that’s including a German kitchen and other quality stuff, so it is doable but bloody hard work
MVHR New Install advice - Ducting in cold loft space insulation requirements
Chanmenie replied to Olu's topic in Foundations
Totally agree with John, there are too many terminals- 6 replies
- mvhr
- mvhr ducting
You are correct below DPC recommended is 1:3 thats what I used and you’d struggle to scrape it with a chisel, even when wet. being that strong it also looks dark grey even though the sand was very light in colour, but I did use Mannok Cement which is quite dark, but even with normal Portland I’d expect it to look more grey in colour than in your pictures
Even 1:6 mortar should not crumble, so it might be even weaker or there’s another issue causing the crumbling
That’s a lot of money, £120 an hour daylight robbery I’m not paying anywhere near that for my install. I considered doing my own install, but as I’m only paying £1800 for having a Veismann Vitocal 151 installed why would I. I suggest you get some more quotes
Crikey, I’ve had my hot knife glowing red hot but the EPS did not catch light. I do find it really easy to use and it makes very little mess as the cut bits come out in large pieces. Not looking forward to rasping the outside ready for render, that’ll be messy and the neighbours won’t be happy 😃
I bought the big sled as well, I used it for letting in 4 x 2 timbers and cutting out socket boxes https://hilltop-products.co.uk/kd-7x-kd-dc100-sled-and-12-blade-kit.html
Best electrical back box for ICF
Chanmenie replied to freshy's topic in Insulated Concrete Formwork (ICF)
I fitted grommets in the boxes and used 25mm oval conduit, as per the electrician’s instructions -
Yeah the hilltop one is expensive but it’s very good I’ll sell it on when I’ve finished with it
Chase out with an electric foam cutter https://hilltop-products.co.uk/tools-cutters-machinery/hot-knife-rope-cutters/hand-held-hot-knife-rope-cutters/hand-held-kd-7x-premium-hot-knife-foam-cutter-groover-kit-with-case-accessories-230v.html
