Chanmenie
Everything posted by Chanmenie
R Wall ICF pretty common around those parts I believe
I think I’ve decided on the Zehnder Q350 with enthalpy exchanger, however the unit has 160mm duct spigots, whereas the most cost effective silencers and manifolds are 150mm I’ve also found some nice streamlined roof vents in 150mm. Has anyone used a Zehnder unit and reduced the pipes down to 150mm, I’m assuming 10mm smaller won’t make much difference but I’m an MVHR virgin so would appreciate feedback for you more experienced guys
Yeah I worked in the insurance industry for 30 years and know of a lot of happy customers because the insurance paid out on claims, I also know where claims were not paid because the claimants were dishonest not that they would ever admit it. You would not believe the bogus and dishonest motor claims the companies deal with on a daily basis.
Have a look at EWI Store they do external insulation and the silicone render to match and can recommend an installer in your area which would then give the warranty. I believe their render is up market from K Rend https://ewistore.co.uk/?gclid=Cj0KCQjwn_OlBhDhARIsAG2y6zNNjisDZYjLv_qO1YE5UXtv1ZiLnyev9BmOg76A-zZaeuGcMcuWIDoaAgtZEALw_wcB
Yeah I went direct to local Eurocell branch and got a great price
I have a south and west facing conservatory with solar glass and can use it comfortably on the hottest of days, so yes solar glass really works
I got a much better quote from Eurocell
I might actually use 6x1 as the fascia’s will be 200mm, or I’ll fit 150mm fascia with the large over facia vents on the top which I think are 50mm
Can I ask the name of the online retailer please
I’ll be using the over fascia continuous vents yeah I won’t use the thin capping boards, had good quote for the Eurocel 16mm fascia. Certainly makes sense re affixing the gutters
My roof trusses should be craned on tomorrow so I’m looking ahead at the detail of soffits and fascia’s. l’ve watched a couple of videos by Skill Builder and the Tall carpenter, both very informative videos. The tall carpenter advocates fitting a 4x1 sub fascia then the PVC fascia, Robin Clevit just nails the PVC direct to the rafter ends. I guess it’s just personal preference but I’d be interested in your thoughts, on the best way to go about it.
I have one of those, works great 👍
2 years and a bit after breaking ground....
Chanmenie replied to Moonshine's topic in General Self Build & DIY Discussion
That’s impressive 👍 -
I'm in the process of blocking up my internal walls with Durox aircrete blocks, so i got to researching about screwing in the door linings and read lots of horrors stories about the blocks splitting. So I was thinking would it be feasible to substitute some of the aircrete blocks for something a bit stronger say a whole block or half a block on every third course. If so what blocks would be most suitable, which will take a concrete screw or plug and screw without the fear of splitting.
I’d use option 2 The only thing I did different was instead of 150mm concrete with rebar mesh, I used 100mm fibre reinforced concrete, much cheaper and easier than laying rebar mesh. Plus it works better with UFH as the aggregate max is 10mm so it’s more like a screed than concrete and is poured very wet so is self compacting
Yeah that’s not great hence the BnB But yes I’m pretty sure you need a slip membrane, 500g polythene much thinner than DPM. Celotex or Mannok is usually much cheaper than Kingspan, how thick can you go with the PIR
Do you have bad ground (clay) ? if not why have block and beam, ground bearing slab is more efficient. I put a DPM under the PIR and a slip membrane ontop of the PIR, but I had concrete not screed. The slip membrane prevents the concrete from damaging the foil face of the PIR, I assume screed would do the same
Opinions on best way to drop a ceiling
Chanmenie replied to Thorfun's topic in General Construction Issues
Hi @nod when is a deflection head needed. My chalet bungalow will have attic trusses with a clear 9m span so there will be deflection, however I will have non load bearing block walls below which can reduce some of the deflection but not take the load of the trusses, so should I have a deflection head ? -
Interesting as the ESP is thicker steel at 0.6mm I think the Gyproc is 0.55 mm
