TonyT
Everything posted by TonyT
What business have to do to comply with HSE and what home owners do are 2 different things. every grand design I’ve seen, domestic steps on site, grinding away with no dust suppression, etc etc…. It’s can be taken too far but rather that than some bamboo lashed together
I just did an netgear access point, fits inside a wiska waterproof junction box, data cable and 5v power supply cabling to it. provide Wi-Fi to Shelly for car charger, ring front door bell and ring camera.
Positioning new CU, best CU, connecting CU to meter
TonyT replied to Del-inquent's topic in Consumer Units, RCDs, MCBOs
Best check your building control documents online, there are maximum vertical and horizontal chases for walls, like 1/3 thickness can’t remember -
Send the builder an invoice for delays,leaks, stolen items or advise happy to let him utilise another plumber instead of payment
Why have it on display! at least get a recessed version and then hide it with a picture frame https://www.edwardes.co.uk/products/hager-vmlf-112-spd-12-way-100-a-m-s-flush-c-unit-spd?gad_source=1&gclid=EAIaIQobChMI5p7P2vaKhQMVQY9QBh3nqw4TEAQYAiABEgLSYfD_BwE -
You could have a an essential consumer unit fed from the UPS circuit?
Anyone had a good British Gas heat pump install?
TonyT replied to eros_poli's topic in Other Heating Systems
Do you get a good British Gas- gas boiler install? -
Not a good job. can you get access underneath?
- 45 replies
- suspended floor
- ufh
Which heating and hot water solution(s) in 2024?
TonyT replied to Jane W's topic in Other Heating Systems
Who know if you will go down the heat pump route, but either system can be designed for low temp radiators, appropriate pipework diameter. plan pipework routes to make any change over in the future easier -
Or plumb for a heat pump, size radiators for a heat pump, fot UV cylinder as normal and get a viesmann boiler with weather comp, -
best UVC/diverter set-up to maximise PV use
TonyT replied to Tom's topic in Boilers & Hot Water Tanks
I have 10 years experience running my ASHP at work, broken down twice, didn’t get a break, does now… agree with everything you say though. -
Using a PV diverter gives the ASHP a break to rest it’s weary mechanical bones, stuff breaks. no moving parts in PV diverter set up. -
Think they industry has a 7% failure rate on RCD/RCBO I remember from BEAMA documentation
Hep2O if it’s threaded through web joists etc, changing to copper where visible
That’s not an adaptable box! that’s a rough job
Trips what? rcd ? rcbo? what else is plugged into the circuit?
Option 3 is a no no. unless you want to fit a switched spur first and feed the 2 sockets from a fused switched spur.
best do a heat loss calculation to see how much heat is required. look at faulty down pipes rainwater goods, external ground levels for damp. consider additional ventilation in areas that generate moisture?
Help designing our home network
TonyT replied to MechanicalBuilder's topic in Networks, AV, Security & Automation
I follow what’s generally done in commercial installs that there is never a single point run it’s a double data point with 2 data cables. I have 48 data cables that I run in 20 years ago, not all used but I was putting rewiring at the time, maybe 8 or 9 used but glad it was done keeps the Wi-Fi for Wi-Fi only devices. good luck -
Can you not oversheet the timber frame with another layer of board?
You haven’t had much luck with this refurb. clear delegation of work is always required when there is multi or disciplines installed.
2 penetrations drilled once ASHP has been positioned to get level holes if possible to make it ‘cleaner’ outside. likewise for rotary isolator, too many installs it looks like a complete after thought with no thought to visually looking appealing
Do you also need an arbor to drill a hole with this?
TonyT replied to Adsibob's topic in General Construction Issues
Remember to get some cutting liquid, squirt of WD40 easier if someone else sprays the the saw while you hold on with 2 hands!! if the drill has a clutch use it
