Oz07
Everything posted by Oz07
Cheers does it matter on size of solar or would any of got you an a? I suspect solar would have got my current place to an a too. Assuming the sap system is logical which it sounds like it isnt!? Did you go triple glazed?
Assuming underside of worktop level you can adjust doors all up to a packer beneath worktop
Interesting comments. Atleast you can play around with the design post planning. Altering windows for part O seems a bit arse about tit. Im not interested in cheating the system or getting away with bare bones. Im considering an application in the "countryside" and trying to at least make the physical dwelling be as sustainable as possible even if the location isn't!
This is what i thought under the old scheme you could just load up on pv
Care to share any obvious ones
Was the epc a?
I suppose the assessor can play around with the figures in sap let you know what to aim for?
I seem to remember it being discussed here years ago they did away with this loophole. When was your epc done? Cam DNO restrict size of pv?
How hard is it nowadays to achieve an epc of A with a new build? I seem to remember it being discussed changes were made to stop people incorporating loads of solar pv to offset poor design. What kind of ratings is everyone here achieving? My place built a few years ago came to a B. Im trying to understand if it would be prohibitively expensive nowadays to achieve A or whether it is do able without going full on passive. Cheers
Small water heater discharge point termination (post tundish)
Oz07 replied to Stones's topic in Boilers & Hot Water Tanks
I have a combi discharge into internal drain after a "hotun" branded tundish. Signed off no probs but maybe different with cylinder -
MVHR self install - tips and experience
Oz07 replied to flinn's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Find someone decent with the right kit to commission! -
MVHR balancing - unsure if done correctly?
Oz07 replied to Oz07's topic in Mechanical Ventilation with Heat Recovery (MVHR)
No reply here but just for closure the invoice was cancelled, apparently the certificate was "cancelled" too. No way was i trusting those figures everything was a bit fishy for my liking. -
Be fun cutting the pockets in those boards! Will be worth it though should look good
Yeh ive done that before with void above concrete oversite. Sounds good
Yeh the ties with the condoms that's what i've used with cavitiy ties every joint on the blockwork
Why does a movement joint need wind posts? Isn't there a standard detail with cavity ties either side or over a certain height do you need wind posts?
Hilti gun the timber to the steel web would save drilling the holes. I've had to this before to fix a ledger for a flat roof.
I think pear stairs ask you to sign a disclaimer if the design breaches building regs in any way. Different kettle of fish to a bespoke high cost jobby but I would assume same rules apply?
How will the wall be finished plastered around?
where's the window?
A movement joint would look neater than a crack. I know what i'd do
Depends on invert level surely? If existing low enough then a trench out the ground with the correct amount of pea gravel under and around. It's what happens under a block and beam
I have recently used a contractor to balance a MVHR system and am not entirely convinced it has been done correctly. I am happy to be proved wrong so if anyone could point to any resources which show I am mistaken I will be just as happy as if the opposite is true? So firstly they came out to balance the system. A certificate was sent out with the wrong floor area and missing a supply terminal in the figures. I contacted contractor and they said would sort. New certificate comes out with right floor area and 3rd bedroom supply added on. I have a few issues. The measured airflow on the supply side is higher on low setting than on boost on the initial cert, and dead level on the updated one. Considering the fan speeds on boost are at 50 something % compared to 30 something % on low I find this unlikely? On the initial cert the total of the supply figures was pretty much level with the total of the extract, within .1 l/s. The new cert shows the new room added onto the supply side but now the total l/s of these figures is out by over 10% compared to extract. The property has 3 bedrooms so it doesn't seem to comply with the building regs doc F Table 1.3. Overall i'm not too precious about this as I think the minimum rates have been achieved on wet rooms and kitchens. I am suspicious that on the initial certificate despite missing a supply terminal the overall supply and extract figures were balanced to within .1l/s and on the new certificate they are out. I have contacted contractor and he is insistent the supply & extract figures don't have to match up for the system to be balanced. He says it complies with building regs which I don't doubt (ish, excluding table 1.3) but when I engaged it was for the system to be balanced. Initial cert Updated Cert
Yes tbf they usually spray any ive had done. Suppose thats why ive never seeen the polythene
