Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. >>> In areas that have got the issue sorted you have to buy "credits". Is that related to RAMS 'Recreational Avoidance Mitigation Contribution Payment' or is that different? >>> if you drop down dead you can't live in the house for the 3 years needed to keep the exemption. I guess 'not your problem' at that point
  2. There are some automatic fire extinguishers which might be worth investigating too.
  3. Traditional oak framing joints + dowels or A4 stainless coach bolts if you want it to look more contemporary. Your design looks like it's halfway to traditional joints already. They don't have to be millimeter perfect - this is rustic green oak right. Robin Clevett has a video or two on YT showing a little bit of green oak work he did.
  4. >>> nutrient neutrality issue Well that's a new one on me. Bats, newts, archaeology, contamination, heritage, flooding, SUDS, access, materials, sustainability, trees, ecology, design, overlooking, noise, solar gain, ventilation etc etc etc ... but nutrients ?
  5. Swings and roundabouts - materials are expensive but coming down in price a bit, contractors are getting a bit more reasonable and more available. Maybe the major factor is availability of good plots in the area you have in mind. It can take an age to find the right plot, and then an age to get planning for the thing you want - anywhere from a year to say 5 years, depending. Also, you have to balance the normal value of your time against the cost of contractors. It's unlikely you will have enough time and energy to make much of a difference if you have a full time job at the same time. Some basic calcs may help you decide - typical cost of plot in your area plus, say, £1.5 - 2.5K per m^2 build cost, depending. Are you in the right ballpark?
  6. >>> Would you wait for the current plans to be approved, then make a new app? Would the answer be any different if the design was identical? <<< You might ask your LPA informally - they may accept as a non-material change once the original is approved. Also the answer might change if they think they might approve or refuse the original application. Planning approval is really about the eternal look and feel, size, style etc so if the rebuild is going to look the same as the renovation then pretty much the same plans will be involved. You don't say how much longer you expect it to take for your original application to get a result - that would be an important factor, of course. If you're 100% decided to do the rebuild and you only just submitted the original application, then you might as well submit a new application in parallel. They run independently - at least in principle.
  7. The beauty of oak is that it weathers to a silver colour and doesn't need any treatment. It's quite acidic - you need to use stainless fixings, A4 rather than A2 if it's not too expensive. I like to do things only once - so I used oak for our raised beds etc. If you paint then you'll be painting every few years, but if you insist then I would use Bedec 'Barn Paint'.
  8. OK just to report back - for anyone else needing these kind of services. I used these guys: https://www.fiverr.com/quark_visuals - and they we're professional and reasonably priced. I was careful to write a 8-page brief specifying my objectives and the exact viewpoints and another 7-page brief on materials (lots of images in both of these). They were careful to do quick mock-up images to verify the content / viewpoints etc which I thought was professional. I supplied the CAD models from Fusion (actually in sketch-up format) and the block plan drawings for positioning. The objective wasn't to make the whole thing 100% photo realistic (actually better so the split between what is rendered and what is original image is clear) but to demonstrate what the casual viewer would see looking at our proposed build in relation to the farmhouse 'heritage asset'. There was a bit of flexibility on both sides - I asked them to add a driveway and adjust some colours and I put up with some small image artifacts (which are inevitable with this kind of image manipulation). I chose to build on top of Google street view images (which were fortunate as they were taken on a sunny day). These are not the best quality, but it does allows the LPA to verify the images. Here's the kind of thing - our proposed building is on the left:
  9. >>> or just put in some simple plans for pre-app discussion. Of course, if these look graphically attractive, that helps - everyone's human after all. Maybe a discussion/pre-app about the principle with the LPA with a simple plan (i.e. from above) plus 3D elevation made as an outline only shown with a white line. You can probably draw on top of Google street view images. (Not just a squiggle as above, a reasonable accurate outline.) Listen carefully, if they'll talk to you (some LPAs won't). Then if they don't hate the idea, submit a good quality render / plans taking care to observe any guidelines they give. Probably as a full application.
  10. I was going to say I thought it looked good as it is
  11. Yeah, maybe as you're not building in front of the front elevation. Depending on your LPA, you might be able to get informal advice, or just put in some simple plans for pre-app discussion.
  12. >>> Because of this feedback (and time constraints on the sale of our house) I was thinking about submitting two planning applications but a few weeks apart. Actually if you submit them on the same day, there's a discount on the 2nd application. I did that, and I think it's fine. I think there's even a little bit of 'which one do we prefer' thinking at the LPA, which usefully assumes one will get through.
  13. >>> Not sure if I’m dealing with two separate departments that aren’t communicating with each other. I believe this is the same department for most DNOs, sometimes called 'wayleaves dept' - maybe two different people though. Offer to connect them up ?
  14. Maybe argue your case politely, with humour and as best you can (examples of other buildings etc) and negotiate to-and-fro over stuff that doesn't matter that much to you. That's up to the point they say they will refuse for these reasons. ... then decide whether the features you want are important enough to go to an appeal over.
  15. Gardening: FBN49 leather gloves from eBay - surprisingly thorn proof. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2510209.m570.l1313&_nkw=FBN49&_sacat=0 General: https://www.amazon.co.uk/dp/B08QSHHT4Z?ref_=pe_27063361_487360311_302_E_DDE_dt_1 In both cases, much cheaper if you buy a bunch (the correct collective noun for gloves) at one time. Proper protection but not cheap: Mechanix Gloves https://www.amazon.co.uk/s?k=mechanix&i=industrial&crid=71M0EV3R27PS&sprefix=mechanix%2Cindustrial%2C77&ref=nb_sb_noss_2 For painting / glueing / oily machinery / keeping c..p off your hands - Screwfix 807HY nitrile
  16. >>> The inspector forces the council to respond to the application. >>> I was advised not to go to a non determination appeal as it stops the clock, effectively refuses planning and even if you win the appeal you have to resubmit and they ‘guarantee’ an 8 week response. Ah this is interesting .... are you suggesting that the inspector will just twist the LPA's arm? This is what 'Planning Aid England' thinks: The Secretary of State appoints an Inspector from the Planning Inspectorate to consider the application. As part of the appeal process the LPA will be asked to explain why the application was not determined within the specified time and what their decision would have been if they had determined the application. An Inspector when assessing this type of appeal will ultimately also be determining the application. ... suggesting the the inspector becomes the decision maker instead of the LPA?
  17. I did just issue a complaint to the ASA. I think playing dumb about the smart tariffs they advertise while claiming at the same time to be "The only energy firm we’ve awarded Which? Recommended Provider status to more than twice" ... is definitely not "legal, decent, honest or truthful".
  18. My LPA (East Suffolk) seems to just ignore the '8-week or agree timescale' rule ... amongst others. Yeah you can do the non-determination appeal thing but (a) that's probably 6 months delay, (b) also probably as capricious as the standard LPA process and (c) you have to make an educated guess of the LPA's objections in the appeal statement (FFS). "Where the appeal is against non-determination, it must address the areas that you consider most likely to comprise the local planning authority’s objections to the development proposed;" I'm sure my LPA is very familiar with the territory and that's why they simply ignore the 8-week rule. My questions are: (a) how normal is this? (b) am I right in thinking that the LPA's behaviour will be simply ignored by the Inspector (as isn't actually relevant to the planning decision)?
  19. Hmm, I just moved two properties (on two separate accounts FWIW) to Octopus so I could use some of the smart-meter tariffs that they advertise. Each location showed (and still shows) about 10 options for variable domestic tariffs on Octopus's quotes page. One property had a smart meter already and was switched to Octopus on 1st July, one was switched to Octopus 23rd March and has had a smart meter installed by Octopus 3 weeks ago. Octopus is picking up meter data from both properties and showing it on both their app and account web page. Now I'm signed up, under the 'change my tariff' button, both accounts show only 'Local Octopus 12M Fixed' and 'Flexible Octopus' i.e. no smart meter tariffs. I actually wanted the 'Tracker' tariff for both properties. I have been onto Octopus support many times now, and they have no idea (or are not saying) what is going on. One one account I'm getting this kind of thing: "We do offer a range of tariffs, but availability can vary depending on your location and meter type. I understand that this may be frustrating, but we always aim to offer the best possible tariffs to our customers based on their specific circumstances." They are, of course, still advertising 10 domestic variable rate tariffs at this post code. O n the other account, I specifically asked to be moved to the 'Tracker' tariff. The response was: "Unfortunately, only 50000 members could go on this tariff these spaces have been filled so we cannot put you automatically on this tariff." They are, of course, still advertising 10 domestic variable rate tariffs, including 'Tracker', at this post code. Now that's just blatant bait-and-switch, false advertising stuff. So: (1) Is Octopus BS? Fodder for Martin Lewis / Which / Advertising Standards etc? (2) Are their systems just screwed up and their support people too dumb or misinformed to tell? (3) Will their systems eventually catch up, and make the smart meter tariffs available? (3) Something else? TIA, Alan
  20. I think that on another thread here, it's been pointed out that it's the neighbours who police the planning conditions... If they're happy, then you'll have no problem.
  21. Yeah I would have the pipes running downhill . Sorry, couldn't resist. Some more knowledgeable and serious people will be along shortly...
  22. I found: https://www.renderedimage.uk/ https://offplan3d.com/architectural-visualization/verified-views-and-architectural-photomontage/ etc. Canski offered up https://www.whitechalk.co.uk/ (thanks) as people who regularly spammed him. I'm currently using a guy on fiverr who seems to be professional and very reasonable. I'll put a link up on here when I receive the results, assuming they're good.
  23. A bit of an update for anyone doing this in future... The search term to use is 'architectural photomontage services'. There are 2/3/4 separate graphics tasks, not all graphics people can/will do all: + Model in 3D model to get 3D shape, probably with no or c..p materials/textures on. + Paint some decent materials/textures onto the model. + Adjust lighting / white balance etc etc to approximately match the donor images. + Tweak the chosen images for lens distortion etc and remove any unwanted artifacts, objects etc. + Position the painted 3D models on the chosen images, in the right place/orientation. + Cut out from the tweaked images any bits of the foreground that need to be super-imposed and place over. Voila.
