Alan Ambrose
Everything posted by Alan Ambrose
Hi Mike, That was a very interesting post. Is their an intuitive way to think about how the pull force measurement relates to a downwards load requirement? Or am I missing something? Alan
This is a personal thing, but I hate OSB and any other boards made with wood dust, wood chips etc. Ply I somehow put in the 'proper wood' category. The price difference on 1 sheet of good quality exterior grade ply vs. 1 sheet of OSB3 won't be much in the great scheme of things. The 1mm won't be an issue - you'll be lucky if the roof doesn't have +-10mm dips and humps in it - maybe more depending on the age of the building.
I would pay up for the pump - that way they can concentrate on getting a good level pour, not crushing the pipes etc rather than spending their time and energy muscling in the heavy stuff.
>>> Isolator on the inside - which you should have anyway along with a non-return valve. Just turn it off when you go away. +1 also you can shut off and then drain the tap during the winter to avoid pipe bursts.
I think it depends a lot on your construction - but they effectively are the engineering design (the planning drawings are the aesthetic design) - so they need to be right (and then you need to get your builders to follow them). If very standard brick and block, then you can probably find examples to copy. I think if you're asking then you probably need to get someone to draw them - but then someone needs to be across the detailed engineering design. Maybe that's your builder or your SE, but I think you need to be clear who that is - because that's the person you sue if the engineering design isn't right. I'll probably do my own, but I'm an engineer and I want to make sure the detail is right. And I'm prepared to take on the risk.
Raised bed from 2.4m 'sleepers'
Alan Ambrose replied to Radian's topic in Landscaping, Decking & Patios
Very nice. -
expansion vessel supported by two copper pipes only?
Alan Ambrose replied to Question's topic in General Plumbing
Yeah agree, looks easy to get to, so probably only 10 minutes work - even if you do it carefully -
Double PB is a bit hard work for typical PB back boxes as they're only designed for one layer. You can make them work if you really want.
OK apologies for the diversion...
I just received this from the East Suffolk portal: "Outline application (some matters reserved) - Outline application with all matters reserved apart from access. A phased development, including the erection of up to 35 custom/self-build homes (plots), with the development to include 12 affordable homes, public open space that will include equipped play and multi-use games area, landscaping, and other associated infrastructure. - Land At Victoria Mill Road Framlingham Suffolk" https://publicaccess.eastsuffolk.gov.uk/online-applications/centralDistribution.do?caseType=Application&keyVal=RF1V8HQXME800
Can I check, am I in the right place for the grumpy old men meeting?
No seal at stove pipe to logburner collar
Alan Ambrose replied to Hunter7's topic in Stoves, Fires & Fireplaces
While I'm all in favour of getting contractors to do a good job and addressing directly with them any problems - I think you need to determine first whether there actually is a problem. Tell him you're concerned about the issues you are concerned about and ask for an explanation - make this by polite letter by recorded post because that makes it sound like you're treating it more seriously than might be assumed from a quick text / call / email exchange. Send this to his home address / or registered company address if a company (get that from companies house). Also you can check rather easily what sealing requirement there is for the stove you have - either by looking at the manual or calling the manufacturer. Do the smoke pellet test yourself and get a CO reading. If you are still sure you have a problem ask him to explain / fix it - again politely but with a firm deadline. Use the final options if you have no other alternative. -
>>> I believe you can get fast-tracked if it's holding up a property sale My understanding too. >>> it was processed in a couple of days. I had a freehold transaction close in January and the LR only took a few days to register it - I was pleasantly surprised.
PV on a flat roof, how far from the edge?
Alan Ambrose replied to Smallholder's topic in Photovoltaics (PV)
Doing the calcs for ours, I see I allowed 30cm margin all round. I'm not sure where I got that from, but I bet I found it in some BCO rule somewhere. The margins will likely end up bigger than that of course as you'll need to fit an integer number of panels. -
Gap for washing machine, is 600mm ok
Alan Ambrose replied to cwr's topic in Kitchen & Household Appliances
>>> we found that the new one hit against the batten at the back Yeah agree, the last kitchen I designed had 650mm deep counter tops to avoid this problem. -
I sealed ours with the RAIS-recommended combination of high temp rope and special sealant. Of course, you will use caution until you know it's sealed properly. It's probably completely obvious if it's not sealed. You can get some test smoke cartridges which you're meant to use to verify. He's a HETAS guy? -
>>> Plus ground and weather risks, so avoid doing it in winter. Yeah, good point - this is on clay so choosing the right weather / water table will be important.
>>> What stops you making the ground floor bigger? As I said, the LPA heritage man is very resistant. Loads of writing about 'modest and low profile design' and 'subservience' - as though we are still C16 serfs and need to touch our forelocks every time we pass 'the main house'. On a practical note, the two designs have been in to planning for a couple of months and are coming up to the end of their 8-week period. Yes, I could file another design or two, but ... The original planning was only obtained at appeal so maybe there's some LPA sour grapes there.
A ballpark for you - a new pole and stays, de-rigging a single phase overhead about 50m long, and replacing with about the same length of underground including digging was £16.2K. It's less if you organise the trench digging yourself. This was UKPN, but I think they're all similar - although there are some tales on BH of people getting sympathetic treatment from their DNO. >>> NPower regs needs to be 5 M away from buildings I think there are some provisions for temporary moves and also temporary protection of cables during the build process if that helps any. >>> the woman who lived in the rikkety house had signed a deal with the devil for a few quid to have a pole in the garden and comes with an easement. It's worth double checking whether this binds you to this same arrangement. My understanding is that if it's a simple contract (rather a deed registered with the Land Registry) it probably doesn't. However, making the DNO aware of their lack of rights and then getting them to do something about it may take years. OTOH if you have a sympathetic DNO, it may not. I guess in all circumstances, asking the DNO for costs and timescale (and the best way to reduce both) won't hurt any.
>>> I ask because the cost of a basenent is about 3, maybe 4, times that of an enlargement of the area at ground level. To this you add the in life risks of drainage problems. The LPA are being a challenge - they've gone a bit loopy over our 1.5 storey design, so we may need to go with a single storey design. They are obsessed with 'subservience' to the fairly dull grade II 50m away. It seems every farmhouse is listed in Suffolk - there's 4,120 of them. So the basement seems a fairly easy way of getting some extra floor area. We can dump all the plant down there and have all the storage and workshop space we want. As long as it comes in at less than 4.5K per m^2 - which is the rough cost of quality housing around here, then we're ahead, believe it or not. I'm confident we can address the drainage problems with a bit of careful design - we'll probably do something very similar to @Bitpipe - which is why his post is very helpful to me. Actually I have a question for him re: "the pit was a separately cast open box which butted up to the insulated main structure". How was the joint to the main basement done - was it thoroughly watertight, or maybe it didn't need to be if the water table is always fairly low?
Thanks for writing that up in detail - very interesting. Your door opening was cast in the main basement part as it was done? Any chance of an anonymised copy of your GI spec for comparison - that is the bit given to the GI guys for them to quote on?
Best silicone for uptaped glazing units?
Alan Ambrose replied to Alan Ambrose's topic in Windows & Glazing
>>> Soudal Silirub 2 Thanks Craig - I used this silicone and like it . It flows fairly easily which I liked.
