Bonner
Everything posted by Bonner
Another vote for 4 however it could look very different on a large area. I used this tool https://nsxpwebapp.nelissen.be/publicconfigurator/?l=en-gb&_gl=1*kft2zi*_gcl_au*MTk2NjIxOTc5OC4xNzg1MTM1NjUy to visualise the difference but still built a few square metre panels before deciding. Went for the natural look in the lower half of the picture to blend in with the older buildings in my location. The upper part (unplanned/feckup) shows how it different it looks with a lighter joint, same bricks, sand and white cement.
DIY installed and self certified a MVHR for less than £1500 four years ago, so more like £2k now. No need to spend £10k on a simple system, like everything we get carried away with specifying equipment. The only thing I would do differently is fit noise attenuation, there is some ‘cross talk’ between rooms although only noticeable when it is dead quiet in the middle of the night. Rather than looking at the most sophisticated system, start from trickle vents and think what would be better than that? DM me if you want details of equipment.
VAT Reclaim journey
Bonner replied to Benpointer's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Doesn’t matter really, at least in England. We declared occupation over a year before completion. We also claimed for expenditure after completion (allowable decoration and landscaping etc.) Again doesn’t matter as long as it is an individual dwelling, it’s the planning permission which meets the criteria not the number of rooms. -
Fan Coil Units for use with a (cooling) ASHP
Bonner replied to ProDave's topic in Air Source Heat Pumps (ASHP)
Likewise, it is not a priority for me until it gets too warm and the boss reminds me that I told her ‘a heat pump can do cooling as well you know’. I want to try it with the UFH so don’t need to do any plumbing. Just need the confidence to play around with the settings, guess I am unlikely to break it or change anything which isn’t reversible … -
@Ommm, before I dive in to switching my HP to cooling, did you manage to get this running properly? Any further lessons learned? -
That’s me fiddling with the inverter settings during World Cup matches. Only installed a few weeks ago, I am sure the novelty will wear off.
I don’t recognise the top hat seal so pretty sure it was two separate seals
Yes, not an issue. Mine was like that, the waste seals on the top but plumbers put loads of silicone on the underside as well.
it’s the parrots!! https://www.bbc.co.uk/news/articles/c232dnkkd3po
I used stainless brads for larch cladding. Got a Dewalt second fix, as @Super_Paulie said it’s quite big but works well.
We get through one bulk bag a month, bought four bags last summer @ £90 each. I used to get most firewood free from work and neighbouring woodland but only getting a few scraps now.
Plucking pheasants here! Seriously, pecking the bottoms of our glazed doors at four in the morning
Habitation Certificate (England) - house insurance
Bonner replied to Lincolnshire Ian's topic in Self Build Insurance
Same here, they did ask if there was any major structural work. We declared decorating, landscaping etc. and made sure it was confirmed in writing. (We didn’t have or ask for any BC documentation) -
Difficult to visualise without a drawing but you are better off DIY as it’s too small a job for many companies. SE not required nor BC approval.
Building control visits are normally focused on checking as-built versus approved plans so they can look at any details, ie. level thresholds, smoke detectors, escape windows etc, etc. They wouldn’t have time to look through documents but for final submission, I would add; SE calcs/drawing, roof truss calcs, any MCS certs, Gas Safe certs, planning approvals, window and door specs …
I used a local branch of national chain, handy to get additional supplies as the installation progresses and take back what you don’t use. I mail ordered a lot of other stuff but electrical components need to be available to avoid holding up electrician, or losing him to another job. Do check prices are reasonably competitive but availability is sometimes more important.
My experience was that neither planning or building control check or seem to care about this. I have a gravel drive but large patio at the back was supposed to be ‘permeable surface’. I laid sandstone slabs which slope away from the house to the lawn, so I would argue that all rainwater soaks away on site. If your drive is impervious and slopes to a road, someone may challenge it.
Why do you want to move the bathroom to a corner, will need a corridor and take up window space on the front and rear aspects. Bathrooms are in the best place IMO, create a utility in the back of the garage.
I think you need to size for a 10 year historical storm with a climate change rainfall intensity factor (40% in my case) so 3m³ soakaway seems a bit small. I have 10m³ for about 200 sq.m roof, good infiltration rate. You don’t need to have it all in one place, I have four, roughly one at each corner of the property. I am convinced this is a better solution anyway, more surface area for infiltration and shorter drain runs. My drainage engineer has retired unfortunately but I found him (and other ideas!) by looking through local planning applications.
Normally the works must be done by an approved contractor, whoever is doing it should have a suitable drawing.
MVHR. For sign off.
Bonner replied to Russell griffiths's topic in General Self Build & DIY Discussion
My BCO noticed the lack of trickle vents so I showed him the MVHR, ooh that’ll do the job he said. I self installed and did fill out a commissioning sheet but never submitted it and it wasn’t requested. -
Glad you got good advice. We were building through COVID lockdown and it’s after effects. Many times I wanted someone to talk details on site or in a workshop but couldn’t.
I used TK, everything done off their design tool with at least 5 revisions. Phoned them a few times, not visited but they might be open for a chat in their office. Who is fitting it for you, probably more important to check the measurements on site.
Don’t know any rule for this but I tend to find a picture or drawing that looks right and measure the proportions with a scale rule.
