Bonner
Everything posted by Bonner
I’ve got less than 200mm cover albeit close to the house. I would be concerned by a concrete mixer, cars exert relatively low ground pressure, and that is distributed significantly even 200mm depth. Also more confident about PVC pipe which will flex, than a rigid pipe.
Also with EON, looks like that rate applies only on standard import tariffs, 6p/kWh if you are on their EV tariff?
Just show that on a drawing. I don’t know any specific requirements, maybe they vary between each LA. As long as they are not blocking any access or parking provisions, double they are interested in what they look like considering they keep giving us more of them.
Advice required on Polished concrete floor alternatives
Bonner replied to Jakekibb's topic in General Flooring
Porcelain tiles? I considered polished concrete but couldn’t stomach the cost for something I thought less durable. -
Has anyone got experience with Hyline aluminium sliders?
Bonner replied to lookseehear's topic in Windows & Glazing
@craig, may know them -
No personal experience of them but found their website https://hbdsystems.co.uk/hyline-sliding-doors/ Would be surprised if they manufacture themselves, maybe rebranding something from Eastern Europe? -
Removing broken cast stone window cill
Bonner replied to Lincolnshire Ian's topic in Bricklaying, Blockwork & Mortar
Another vote for glue, two part epoxy and dowel (stainless or brass) -
Doesn’t look right to me, I would expect to see at least 1m above the gutter level. This is what AI says https://share.google/aimode/7iJ9jUTYOfNaOr9Mf so, no it isn’t correct. Should have a HETAS installers certificate.
Welcome, can’t help you with ICF but I am sure someone will be along in due course. If you search the forum, there are many who have done it.
CIL applicable?
Bonner replied to Jammy5's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Nothing to do with building control, call your planning department and follow up by email for written confirmation -
CIL applicable?
They will serve you a liability notice at some point but you can check on their website. -
Doesn’t matter where you buy them from, more important is who fits them. It’s just a case of trawling the net to find the best price, delivered, which maybe a significant factor where you are! Might be worth ringing your builder merchants as well as their best prices won’t be on the web.
I think it’s a bit more predictable than gambling. TOU tariffs are based around market prices which are linked to supply and demand. We know there will be oversupply on windy nights and sunny days and, more predictably, large steam turbines which have to keep spinning all night.
Fabric and ventilation heat loss calculator
Bonner replied to Jeremy Harris's topic in Heat Insulation
In theory there was no need so I wasn’t going to put any heat emitters in the bedrooms but decided to err on the side of caution and had (not oversized) radiators installed. Wet towel rails in bathrooms as well. Partly it was to satisfy the installer’s MCS calculators, partly to avoid domestic complaints! Glad I did because we do feel the need during cold snaps.- 204 replies
- heat loss
- ventilation
(and 4 more)
Very difficult to say without making your own samples, not just the mortar but panels with the chosen bricks. I was going for lime but switched to white cement which achieved a very similar result, albeit a completely different colour scheme to what you are trying to achieve. I used the brick manufacturers tool as a starting point, was surprised how different the bricks look even with slight changes in joint colour https://nsxpwebapp.nelissen.be/publicconfigurator/?_gl=1*1fxpchc*_gcl_au*MzcxNDA4OTIwLjE3Njc2ODI0NDE.#
Real world feel of MVHR +heat system
Bonner replied to MPx's topic in Energy Efficient & Sustainable Design Concepts
Follow your gut feel, I think you will find tiled floors cool without UFH. We have UFH heating set at 21degC, when it doesn’t come on in the shoulder months, the floors suck the heat from my feet. -
MVHR installers or alternatives?
Bonner replied to Swampy's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Please see another post here, note the unit was 20% cheaper when I bought it. I agree the heat saving is not huge, however you would still need the fan(s), distribution system and method of preheating the incoming air to avoid cold drafts. -
Don’t disagree but maybe depends on the roller, as well as the spray pressure and paint dilution etc, etc. I have recoated bottom half of some walls (because I can’t reach the top without scaffold and it doesn’t need doing!), anyway it has blended really well with a medium pile roller.
Impossible to calculate payback on MVHR, it’s about health and comfort which are priceless IMO! I I self installed a simple system for less than £2k, one of the best things about the house. Fresh clean air, without drafts and low heat loss. Trickle vents are uncontrolled ventilation, too much in high winds and also admit a surprising level of noise. -
Welcome. Presume you have seen the episode of Grand Designs on the Wirral? One of my favourite episodes
I got mine done by professional painters, two men three days (at least one day masking). Would have taken me weeks, and weeks … Not worth buying the kit to do a one off job IMO.
I tiled first, then installed the staircase. Made the tiling easier and neater (did not consider location of the UFH pipes, it’s not screwed to the floor)
We used Protek (3-4 years ago) which was reasonable cost compared to others. Not claimed so can’t vouch for them.
I have a warranty from CMLC, was lower cost than most alternatives (think @nod has the same). Can’t vouch for it because I haven’t claimed and until then, who knows if it’s any use!
Electrical meter box location
Bonner replied to Kevan Marshall's topic in Networks, AV, Security & Automation
No, you don’t need to build a structure, just a weather proof kiosk/cabinet to your DNO requirements https://exelgrp.ltd/product/model-d2/
