dpmiller
    4
Everything posted by dpmiller
  1. how long does a domestic fridge last for, it's the same basic tech.
  2. ^ wot he said. The coated board is amazing stuff, ours was exposed for quite some time with no ill effects. But if you can get scaff up handily, I'd do it...
  3. supply and fit would be zero-rated to begin with surely?
  4. so they aren't brittle in shear. Nails are comparatively ductile
  5. https://www.carryduffbuildingsupplies.com/small-chimney-coping-27-x-60-686mmx1524mm.html
  6. might get a chimney cap the size you're looking?
  7. Solido Smart- compressor, sitting on a foam pad, is in a sealed "bucket" which sits atop the airlift tube. This is in free air under the double-skinned plastic manhole cover. Intake pipe is 30ft away in the hedgeline. Zero noise from the inlet, you can't hear the compressor from more than about 10ft from the manhole. Only real noise is splashing water when it's doing it's twice-daily pumpout
  8. are the grub screws on the sides not for locking the pivot, which is eccentric and adjusts the clamping?
  9. cat6 with the separator in the middle I think. Not that it matters. / but surely this is criminal damage? Someone needs a slap for it...
  10. Are you sure about this for your chosen unit? Our Solido runs as an SBR plant and only discharges twice per 24hrs, immediately after a settling period. It pumps (well, airlifts) down to a fixed level each time so up to a few hundred litres in 20mins.
  11. https://www.bbc.co.uk/news/articles/c9w2wyw9x09o "The Competition and Markets Authority (CMA) has been investigating the heating oil market in Northern Ireland and other parts of the UK. It found that the huge spike in prices at the start of the Iran conflict largely reflected rising wholesale costs and that the market is generally competitive. However, it concluded that oil consumers were not as well protected as those connected to the gas and electricity grids. The CMA has not recommended the sort of price controls applied to the gas and electricity markets. Instead it has suggested a "new, proportionate regulatory regime" which largely involves giving consumers clearer information." Anything that promotes national independence and offers some kind of stability here in the hinterlands would be a Good Thing.
  12. freestanding appliances are so much more forgiving
  13. a bead of gripfil around some of the feet, if you must...
  14. if the MVHR is only taking a couple of hundred watts can the relay base not do it directly? I'm on Radiolink and use their alarm interface to switch the MVHR and EM lights
  15. or will the leveller etch the copper and cause an early failure?
  16. could a 5-foot-nothing lady see and reach said isolators? Wheelchair user?
  17. you can generally calibrate cheapo dial thermometers easily enough to match them at your chosen temp. On some the dial can be rotated, you can pull the bezel, pull the needle and reposition on others, or you might even be lucky and find a wee setting screw...
  18. hung from a ceiling- are you doing cooling and have you got a condensate drain?
  19. does your system control on flow or return temp tho?
  20. ... a wee bit more than £60, that.
  21. are concrete chimney tops not a thing where you are? https://www.carryduffbuildingsupplies.com/small-chimney-coping-27-x-60-686mmx1524mm.html
  22. I'd do without a few beers, get the £60 wonder and just set it on top of your table saw...
  23. Kineticos are great.
  24. is the structure up/ can you build in block off the existing floor? That might rule out some options...
