Everything posted by JohnMo
Any thoughts re stopping moss - new clay tile roof
JohnMo replied to boxrick's topic in Roofing, Tiling & Slating
Just takes about a hundred times longer to form. Our last house 1830 still had original roof - zero moss. House before that moss starting to form after 2 to 3 years - concrete tiles. -
Another option is Sunsynk LifeLynk X - 3.6kW hybrid inverter, 3.6kWh LiFePO4 battery & 4.5kW MPPT - SM3.6KWLL - G98 Approved These are AC coupled inverter battery with PV input. The can be run in parallel configuration with one acting as master and others as slaves. So you can run any number of these and should keep the G98 certification. Each inverter battery will take 4500W PV input. So for around £3k (+VAT) you get 10.8kWh battery storage and more than enough inverter capacity for you PV etc.
Is this for two properties? As you seem to have two plans that are different?
SunSynk 3.6kW AC ECCO, has a 7000W MPPT and a rated AC output of 3.68kW and is G98 approved. So no need to tick the G100 box, you have the G98 box ticked instead. Solar Input - 3.6kW Ecco Hybrid Inverter Max power input – 7000W Max DC input – 500V Max current input - 2 x 13A MPPTS - 2 MPPT range - 150~425V
Here are some numbers comparing PIR and 0.032 mineral wool. Ca vity insulation Underdraw (PIR) Rafter spacing (mm) U-value (W/m²K) A 150 mm PIR + 10 mm foam infill 50 mm 400 0.113 A 150 mm PIR + 10 mm foam infill 50 mm 600 0.110 B 150 mm mineral wool 60 mm 400 0.144 B 150 mm mineral wool 60 mm 600 0.136 B 150 mm mineral wool 70 mm 400 0.134 B 150 mm mineral wool 70 mm 600 0.128
Not really always correct - Frametherm 32 has an R value of 0.032 and PIR 0.022W/mK so 50% difference not 100%. There is no shrinking with mineral wool, and you are not bridging with a lower R value expanding foam.
Unlimited hot water with 4 bathrooms - is it possible?
JohnMo replied to Indy's topic in Boilers & Hot Water Tanks
Just use a heat pump cylinder 400L you easy get a 4-5m² coil in. Even a 3m² would give quick recovery. And possibly stay in condensing mode for most the reheat if you set it up well. But if you have room for 400L cylinder 2x 210L slimline heat pump cylinders would give way more flexibility and faster reheats and you would get 6m² coil out the box. -
I would just do mineral wool something Rockwool Flexi or Frametherm 32. Then under-draw in 60-70mm PIR. Easier life, as good U value on paper and likely quite a bit better in real life. Better decrimant delay.
Slates. A copper strip on the ridge.. -
Help to understand UHF needs and best operation and design
JohnMo replied to Okeb's topic in Underfloor Heating
Sort of Use the heat-loss formula: Q=U×A×ΔT where U = floor U-value (W/m²·K) to the underside/cavity, A = floor area (m²), ΔT = temperature difference between the warm floor (mean UFH floor temperature) and the space below/crawlspace/ground (K). So you need to use your average UFH flow and return temperature. Average winter temp is around 7 degs (void space temp), air is a good insulator if in a closed box, but your void will be ventilated, so not good. Best case U value will be building regs, it can be worse and compensated in other areas. But we will use 0.25. Flow temp likely to be mid 30s so 35 flow and 30 return so 32.5 mean. 0.25x100x(32.5-7), so 640W. 640 x 24 x 220, so about 3400kWh At 8p that's £270. If your flow temp is higher your losses get higher. If you can flow lower well done but I doubt it. The above is based on average temp, so milder days less losses, design day losses double. So on a -3 day your downward losses alone will cost £2.30. -
this a cut and paste out of English permitted development rights Development not permitted B.1 Development is not permitted by Class B if— (a)in the case of the installation of stand-alone solar, the development would result in the presence within the curtilage of more than 1 stand-alone solar; (b)any part of the stand-alone solar— (i)would exceed 4 metres in height [F7or, in the case of stand-alone solar on land in a conservation area which would be installed so that it is nearer to any highway which bounds the curtilage than the part of the dwellinghouse or block of flats which is nearest to that highway, 2 metres in height]; (ii)would, in the case of land F8... which is a World Heritage Site, be installed so that it is nearer to any highway which bounds the curtilage than the part of the dwellinghouse or block of flats which is nearest to that highway; (iii)would be installed within 5 metres of the boundary of the curtilage; (iv)would be installed within the curtilage of a listed building; or (v)would be installed on a site designated as a scheduled monument; or (c)the surface area of the solar panels forming part of the stand-alone solar would exceed 9 square metres or any dimension of its array (including any housing) would exceed 3 metres.
Does a pergola need planning - no generally. Think most of what is posted is for a building. When does a pergola become a building - when you enclose roof and sides. So now the question is does it become a building if you only cover the roof and leave all sides open? That is the question 1 Question 2 is, can I install solar panels at the front of my house that are not on my roof, but on a garden structure. Generally no, without prior planning permission. So can you install a solar pergola at the front of your house without planning - no.
Integrated or Non Integrated, that is the question?
JohnMo replied to Duncan62's topic in Air Source Heat Pumps (ASHP)
Generally you need mains power, supply and return piping, a controller in the house (your sounds like it's wireless which maybe good), cylinder temp probe back to wiring centre, 3 way diverter valve power. But you really need to download your models install manual to get the correct details. -
I would look to keep this all simple. Something like a Sunsynk hybrid inverter, set export to zero. The inverter will allow to charge battery from grid and or PV. Inverter will feed house when there is battery capacity and or PV, otherwise draw from grid. This way you give nothing to the grid, but can charge from grid when no PV. Use a time of use tariff get all your electric on cheap rate or from PV.
Zehnder Q350 + ComfoPost CW12
JohnMo replied to BartW's topic in Mechanical Ventilation with Heat Recovery (MVHR)
LoopCad on a limited time free trial. Save everything to PDF and print before time expires. -
The heat pump monitors cylinder temperature and schedule at a call for heat the heat pump powers the diverter. Would assume the wiring centre is within the ASHP casing. Why limit yourself to one make? -
Hitachi and Hisense both have the same outputs. It's the 4.4kW model. Been doing some digging and Hitachi has or had a joint venture with Hisense for HVAC (including ASHP), so some common parts maybe compressor as outputs are pretty similar. They also both use dip switches for various settings. Hitachi needs an additional on kit for cooling and Hisense doesn't. The Hisense is £2000 including VAT. The heat pump also has the expansion vessel etc in the casing.
A heating system with DHW cylinder will have two expansion vessels, one for heating water (goes CH and for heating DHW) the other is for the contents of the cylinder. The integrated one will cover the heating water only. But only to a given CH water volume. High volume systems may require additional expansion. WiFi should just be access to a portal, shouldn't be required to make system work. -
Sorry just seen this, yes pretty basic boiler. Maybe better spending your money on a better boiler. Can you estimate it's thickness? Your B&B plus screed say 250 to 300mm. If it's suitably insulated it will be closer to 450 to 500mm thick. -
Thanks -
For me you are wasting a load of money and effort doing UFH. Block and beam and thin insulation you will be chucking money down the toilet year on year in increased running costs. I read an article the day about radiators and cold feet. The reason people get cold feet - the heating runs an on off strategy with high temperature radiators. Radiators don't really radiate heat they heat air via convection. The convection current is quite strong with high temperatures. The hot air goes the ceiling and cold drops to your feet. Thermostat stops the radiator the room cools, you still have cold feet the cycling repeats. Solution is low temperature heating, so with radiators you can run weather compensation or load compensation. So the heating is lower temperature and more continuous. Your easiest option is to get your boiler to run opentherm and move to priority domestic water, so you can get two flow temps one for DHW heating and a variable temp for heating. You need to share your boiler details also.
