Everything posted by JohnMo
UFH balancing and understanding how it works
JohnMo replied to peredelkin's topic in Underfloor Heating
ESBE do a range of controllers that go with their 3 port valves and actuators, not cheap, I bought all mine for peanuts off eBay. Mine is set up to run on pipe flow temp mode. It has two set points (T and T2) I trigger the two different temperatures via thermostat. On a call for heat (T2) I allow it flow up to 36 degs, once thermostat senses house up to temp (T) is set to 22, it moves the 3 port to full recycle and switches off the pump. Early image without insulation. With underfloor heating there is zero advantage having an App controlling anything, run time are too long. If you want to switch your heating on before you leave work, your going to cold all night. -
Wall mounted basic ASHP for workshop
JohnMo replied to Mudmouse's topic in Air Source Heat Pumps (ASHP)
It's all rubbish really when you see how much industry looses per year via small (!) leaks. Doing an improvement project for one offshore site, they lost the equivalent of 300 tonnes of CO2 in a year, through so called small refrigerant leaks. -
How can we make the front elevation look more interesting?
JohnMo replied to LnP's topic in New House & Self Build Design
You have a lot of glazing on the north east elevation, not the best aspect for glazing as zero heat gains, just heat losses. Will you ever get enough sun to make you want to sit out on the balcony areas? Are they all north facing? Internally not sure why you have a plant room and waste upstairs space by having a cylinder up there, put it in the plant room. Both end elevations have miss aligned windows - it look wrong and badly thought out. -
What do you mean? A layer of 9mm ply laid down, second layer on top with joint lines of the first layer overlapped by the second. Once glued and screwed together will become a single piece of ply 18mm thick. With staggered joints there are no weak areas. You make the ply floor smaller than the room so it can move (float) to allow it to expand and contract. Just add it, it's not doing anything as a VCL as there is nothing to protect from moisture. It's just a slip membrane to allow the insulation and ply floor to move independently of each other.
You have a dpm, so not sure the vcl is actually what you are calling it. If you do add a polythene sheet it will effectively become a slip membrane to allow movement of the flooring above - a good thing and cheap to do Either two layers of 9mm ply staggered joints glued and screwed or as specified 18mm. The 2x 9mm with give a single piece floating floor. Both versions the floor should be made 10mm smaller all round than the room walls, so it floats and can expand and contract easily.
Cool energy have various sizes on eBay also, seem well priced.
If the mixer will run on a combi it will work from a cylinder. Assume if you are having a hat pump you will have an unvented cylinder? They like a balanced hot cold water water pressure and that's about it. I went combi to heat pump, just had to adjust the mid point mixing temperature.
Flow rate is set per loop length, there is no need to have the same or similar loop lengths. Salus self balancing a actuators will balance the system for you, on a fixed dT, just add one per loop. I have used both mechanical and electronic mixers and prefer the electronic ones. By electronic I mean 3 way valve and actuator controlled to a set or varying temperature. The reason I like, is that they always provide a good recycle flow back to the boiler and only mix when required not all the time. Is UFH right for you? Home all the time and happy with heating nearly all the time it's great. Away all day and heating off don't expect to warm before you go to bed. UFH in bedrooms is rubbish, either not warm enough or too warm. Avoid. Can you existing boiler do weather compensation? If so S and Y plan should be avoided, consider X plan or priory hot water. Low temp radiators or fan coils, would be my vote doing it all again.
Cyclo electric boiler?
JohnMo replied to Adsibob's topic in Energy Efficient & Sustainable Design Concepts
I found when I was comuting from Elgin to Aberdeen I would just go with the flow of the traffic. But the loony tunes, would fly past at inappropriate dangerous areas in such a rush to get past everyone. 50 miles later you were one or two cars behind them. -
electric boilers are cheaper than heatpumps to run
JohnMo replied to dpmiller's topic in Environmental Building Politics
Brand new in box. -
eBay for heat pump, City Plumbing for cylinder, existing UFH, some pipe and insulation. Existing thermostat controls the ESBE mixer on UFH. All self installed including UVC (did the training). Heat pump does its thing, without any outside controls. System is super simple. -
Plenty of people spend way more on an electric vehicle or diesel etc, with zero returns, just money lost every day and every mile. So no big deal, it's how I want to spend my money. Spent about £3k buying and installing the heat pump and cylinder. Reason is I want small bills, for when I retire. Read the thread title - I am just pointing out heat pumps can be cheap to run. When comparing to indirect electric heating as the MOD is proposing, would be on a similar time of use tariff, but the energy input, would equate in my case, to 3.7 amount. So cost way more to the end user. -
Really depend on what you buy, how you buy and how you install. On a new build it's a no brainer. Some old houses (not all) you must be mad or very rich, unless it's a hybrid install. -
Heat Loss Calculation for ASHP - Air Changes
JohnMo replied to benben5555's topic in Other Heating Systems
As I said you need to compare apples with apples. MCS spreadsheet just take the ACH and uses it in the ventilation heat loss calculation. 1.5 ACH assumes you have a vent fan in that room nothing more or less. The calculation shown is for the ventilation heat loss - cell G05 -
Basics of the maths Heating season SCoP so far is 3.7 for heating including DHW. So around 4p per kWh, compared to 7p to 8p for gas when you factor in efficiency. We batch charge the floor overnight (about 6 hrs) down to an average day temp of about 3 degs and let it run longer on colder days. We generated 9kWh the other day, so that would have been free running for the heat pump - can't get that with gas or oil. -
The only advantage I see is it will flow high temperatures so suitable for normal sized radiators. But charged on E7 or similar. May as well install storage heaters. I will dispute. If you have a battery and UFH it's loads cheaper and you can also cool. I'm just using standard E7. Heating season this year has had a warmer house and a lower bill. Heat pump output much better match for the house heating demand than the gas boiler was. -
All the info you need https://www.heatgeek.com/do-i-need-to-upgrade-my-radiators-for-a-heat-pump/#google_vignette
MCS seem to make up the numbers and are are populated on their spreadsheet - one of the reasons they always oversize, on well built and well insulated houses. But you have to careful that you are comparing apples with apples. There is a difference between building regs air tests, passivhaus air tests (done pressurised to 50Pa) and natural ventilation rate used for heat loss calculations. -
Good weather down south, not so nice up here. This years Dec average is up a couple of degrees (current average is +4), compared to +2 in 2022, but we still managed -9 at the beginning of the month. More rain, so less solar gain. Currently 1 deg with a high of 3 today.
Beware some are coated carbon steel and have an anode to be replaced. Think the Edel is stainless so ok. Some thoughts - A 200L direct UVC was less than £500, so you are paying £1500 for the heat pump part to save upto £1.30 a day, if you get a a CoP of 3, based on 7kWh of hot water a day. So about 4 years to get payback, without the additional installation costs.
Just compared last years December billing with this (used today's rates (pence) at last year's kWh. Last year gas and electric was £70 more expensive than this December is likely to be. This year we have a battery, more solar and ASHP. That reduction includes some high usage days where I was not using the ASHP optimally, plus we always heating the garden room (which we didn't have last year) to above 10 degs and some days up to 21 degs. Taking into account the additional heating going to the summer house, we are closer to £90-100 cheaper than last December. So overall about 23% cheaper running the heat pump compared to gas.
Could be - if red is hotter than blue, if not then the other way round
