Everything posted by JohnMo
boiler behaviour,please let me know your thoughts.
JohnMo replied to Post and beam's topic in Boilers & Hot Water Tanks
No it was the lack of airflow, to cool the brake enough that caused the 2965. -
How to fill / seal gaps between skirting and hard floor?
JohnMo replied to embra's topic in Decorating
The smaller gaps should remain as they are to allow expansion and contraction of the wooden floor boards. If you seal the completely it will look great for a short while and the look rubbish with a few weather changes. -
I would set the ach rate at 0.2 for now. From the looks of it you will have a ventilation issue. Intermittent fans and trickle vents will not give you enough ventilation with everything sealed up. Upgrade the vent fans to dMEV, these run at a very low rate all the time. Greenwood CV2GIP are cheap as chips of eBay, Ulta quite, have smart humidity sensing and boost automatically. You need one of these in each wet room. Your trickle vents will end up closed because standard vents are rubbish. So you need to upgrade to humidity sensing or self regulating. https://brookvent.co.uk/humidity-control/ https://renson.net/en-gb/products/ventilation/window-vents
Basically the same stuff, different trade names. Buy at the best price, shop around I got mine online came direct from the factory. Prices vary daily so you need to do your legwork to find the best price. But was 70% cheaper than I could get locally.
It's unlikely you will have 0.5 ACH unless you are running MVHR, if that's the case add 90% in MVHR efficiency. If not MVHR how are you ventilating? What is your target airtightness?
Are you certain you have filled the spreadsheet in correctly? Sound a huge heat loss for 90m2. What air change figure have you use?
You are just operating the boiler and the heating system all wrong. Running at the highest possible temp, then throttling everything via the trv's leads to the issue you have. Any boiler would suffer just the same, even my very sophisticated Atag boiler, I was using last year. -
Where should the vents be?
JohnMo replied to CalvinHobbes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
There are good advantages As the air enters the house it is slightly cooler than the house air, the warm air, pre heats the air so it cannot be felt. My living room terminals are at about 4m high. -
Nothing unsophisticated, just simple science, if you throw lots of kW of heat at water it will overheat, unless it's moved at a fast enough rate to carry the heat away. You are basically trying to heat up everything too quickly, the trv's shut off the radiators they kill the flow route. You get the blocking alarm. No heating no DHW until lock is released. You would have the same issues with any heating device, even bigger issues with a heat pump. The alarm you get is just a low flow alarm and it locks the boiler until resolved. Our last house was 200 years old most uninsulated thick stone walls and single glazing. We never ran the boiler over 60. The only time I had issues, was when I added timers and electric trv's to the radiators. Undid what I did, never had an issue again. Run a cooler temperature for longer, will fix nearly all your issues. -
Told you that very early in the thread. Obviously got shot down in flames by others, but more water volume needs to stay engaged - remove a couple more trv's or just open them to higher temperatures. -
But most installed will be much lower than that. Gas up to 110% but most installed are probably nearer 80%. Had my gas boiler running at 110% efficiency measured by heat meter. Now got an ASHP and spending around £40 to 60 less in winter per month (electric and gas rates corrected). Only bit with an ASHP that isn't that good is she heating when it's cold outside. Other than that cheaper especially so if you have solar.
In a passivhaus or anything remotely close, absolutely rubbish. Fan coils - flow temp 35. CoP at -2 around 3.5, CoP at 10 deg OAT 5. UFH flow temp 30 or below CoP at -2 around 3.7, CoP at 10 deg OAT 5.7. even if you did all DHW at peak rates, you still cheaper. You can heat off peak with UFH, I currently pay about 13p per kWh. There is almost no servicing to do, look and clean radiator if required. An hour tops. UVC you would do anyway. No more than a gas boiler, possibly less. How the heck are you going to control an oil boiler, and manage heat losses into houses? with virtually no load. You would have to install a thermal store, heat to 70/80 degs for DHW then let the temp down for heating - not in the spirit of Passivhaus.
Does UFH need to be on if laying engineered wood?
JohnMo replied to Tom's topic in Wood & Laminate Flooring
Yep -
You need the floor cool before glueing the floor covering down. Do heating should have been off a day or two before. But you need to check the screed humidity prior to doing the floor, to make sure it's below the allowable limit set by the parquet manufacturer. -
Getting frustrated with heating suppliers.
JohnMo replied to MikeSharp01's topic in Other Heating Systems
Don't you need the grant prior to install. Then they would credit you £7500 against the parts you buy from them. So you never see the grant. They charge you a flat rate for design, commissioning etc. -
Solar PV, Immersion diverter and EV Charging
JohnMo replied to JamesPa's topic in Photovoltaics (PV)
Can't you just put the CT clamps sequential, PV first then car? -
Turn key - less ventilation and any part of the heating system from what I see. Bonkers big house, bonkers big prices as you would expect. Some odd ones are "Construct internal stud wall with insulated plasterboard upto 1800mm maximum height" why insulated plasterboard on internal stud walls, and why only to 1800mm?
A quick read of the manual The B is Fault category B (blocking faults) Blocking faults result in the heating system being shut down temporarily. The heating system restarts automatically as soon as the blocking fault is removed. Not missing point at all. It's a single boiler, that has a blocking code, this will prevent it firing up for any reason. The CH flow fault needs to be resolved with the flow through the boiler, otherwise it will only continue as it is. Would suspect the following occurs Trv's are open, boiler flows no issue, does heating and DHW as normal, trv's close in or fully closed, there is not enough flow through the system left open (2 rads and 15mm pipes), boiler gets blocking code. Boiler does fire for any reason while blocked. Rooms cool, trv's open, heating resumed as pump can now flow enough - repeat -
Agreed, but trying to shove 20kW of heat via a couple of radiators and does not/isn't working, your boiler overshoots and locks you out. Once you are locked out, the boiler does not fire for heating or DHW. Nothing to do with pid controllers - just physics. Basically you have a circulation pump on the boiler it's trying to move a load of hot water, if it cannot flow through the system the boiler overheats. Is your heat system done in micro bore?
