Everything posted by JohnMo
These work great, designed for the job. When you install, one turn in, half back, a further turn in etc. until fully screwed in. https://www.screwfix.com/p/dewalt-aerated-concrete-anchor-nylon-60mm-50-pack/454HT?kpid=454HT&cm_mmc=Google-_-Datafeed-_-Screws%2C Nails and Fixings?kpid=KINASEKPID&cm_mmc=Google-_-TOKEN1-_-TOKEN2&gad_source=1&gclid=CjwKCAjwte-vBhBFEiwAQSv_xSPJizrRNcYEjQuP7ZUJI4VyVx8cKj8RcKlyx5vZJCAQXNT_FOFBqRoC80MQAvD_BwE&gclsrc=aw.ds
How to certify unvented cylinder if plumber lacks G3 ?
JohnMo replied to Spinny's topic in Boilers & Hot Water Tanks
You would possibly have to pay another plumber to inspect and certify another's work - good luck with that. Or get building control to sign it off - at the plumbers expense But bottom line is the plumber should know better and not be installing, or should have lined another or building control up to certify. I suspect there are lots of un-certified cylinders in the UK. -
Our cylinder is in an upstairs plant room, the pipes go along in the ceiling and down into the utility to the hot manifold and then back up and down to the wet rooms, never seen an issue.
You really need to complete a heat loss calculations, we have 0.14 walls, 0.09 floor and between 0.11 and 0.14 roof, and pretty airtight - we defiantly need heating in NE Scotland. Your form factor makes a huge difference to heat load, ours is rubbish (long thin building and all vaulted ceilings), but suits the location and views. No matter what you decide, put UFH pipes in all down stairs rooms. We put ours in a 300mm centres - very small cost and nothing lost. You could connect to a heat pump or heat on a cheap rate via a Willis heater or two.
Yes choose one system or the other. Not all dMEV units are equal. The Greenwood mentioned above was my second make, the first was quite noisy. Always seem to be plenty of Greenwood units on eBay for good prices. I looked when I was designing my house quite liked the Duco system https://www.duco.eu/uk-ie/products/mechanical-ventilation
You would be surprised how little a condition based system does. trickle rate for bathrooms/WC/utility is 5l/sec (21.6m3/h) and kitchen at 8l/s (28.8m3/h). Boost is only in the rooms requiring it So house 3 bathroom, utility and kitchen, trickle rate 115.2m3/h Ventilation heat loss = Qv = 0.33 × Air volume x ΔT 0.33 * 115.2 * 24 = 0.9kW at -3 OAT 90% efficiency MVHR at Scottish Building regs rates would, be 0.23kW at -3 OAT. So 670W difference dMEV advantages - No filters, heat exchangers and duct to pump through (supply and extract, only extract fans not supply fans. No filters to replace. Cheap to install, I paid £35 for my fan, used in my summer house.
dMEV units run all the time at a low rate.
No, do one or the other not both. Wouldn't bother with PIV. dMEV would be my choice or MEV. But you want to make sure it extracts the minimum amount of air - based on internal conditions. You need the following for it perform as required. 1. All internal doors need to be undercut (around 10mm clearance to floor covering). This allows cross ventilation. 2. You need inlets in dry rooms, trickle vents or otherwise - but you need these to automatic open and closed based humidity 3. Your dMEV or MEV unit needs to automatically boost based on humidity. Greenwood CV2GIP are silent, draw next to no power, can by connected and controlled by a 3 core cable only. You can get heat recovery bathroom fans, but they just ventilate the room they are in. You also get reversing fans with heat recovery but start to get expensive, as you need them in every room. Heat losses is minimised by only ventilating at minimal rates as required.
Beefy ridge beam check and plan to reduce size
JohnMo replied to NandM's topic in RSJs, Lintels & Steelwork
We didn't -
Ask why not a glulam beam (or similar), at least you don't get a massive thermal bridge. This is mine being lifted in with a pretty small tele handler, think that beam is about 11-12m long. -
boiler behaviour,please let me know your thoughts.
JohnMo replied to Post and beam's topic in Boilers & Hot Water Tanks
A combi boiler uses a flow switch on the DHW to startup the boiler. It either isn't seeing enough flow or is a defective flow switch. Do you have a combi save devise installed, if you don't know you probably haven't. Is it the same for all taps or outlets, i.e. it never starts up? I would go around each outlet and log what happens to the boiler. Also your flow temp for the central heating seems very high. -
Only referencing the actual hardware install, not the utility side of things.
I just make mine run at near to full chat for heating the house, set point of 35, knowing that the heat pump will only achieve 33 before the thermostat thermostat trips it. Depending on house temperature and heat loss due to outside temperature, I will have an hour and half run or 12 hours run time. Now all at 13p per kWh, with battery. Even if you want to run for long periods at low temp modulation helps, but as long as the water capacity engaged is there you get runs over about 10 minutes and power consumption doesn't really take a hit. Example I run a single fan coil in our garden room, it puts out about 500 to 1000W. My wife wants it warm in there until lunch time. So although the house is satisfied for heating, I keep the house UFH pump running and use the thermostat for the house to move the set point of the UFH electronic mixer from 35 to 28. This almost closes the mixing valve, but give me a working water capacity to enable the ASHP to run for about 20 minutes at a time, while only providing around 500W to the fan coil from a 6kW heat pump (min output 3.5kW), the house buffering the rest. This gives an almost constant temperature in the summer house. All done without a buffer, the volumiser I installed is now isolated, as it bought no advanced.
Gee you are all being taken for a ride. An ASHP install on a new build should cost no more than a £1000 more, than a decent gas boiler install on PDHW. And that's without any grants. Plus there is is no such thing a permitted development arguments, that seem to go on, with most threads on here, as permitted development does not apply while under planning permission.
Why would you need an MCS certificate? Got my prices from City plumbing
You could do without the grant for that or less. Full price ASHP £2.5k, cylinder £1k, bits and bobs £500. I ran my cables the electrician charged me 2 hours for termination and testing. I did the plumbing, but a plumber for two days max
Are you getting quotes bigger than £10k for a new build?
Supporting the insulation rather than the pipe?
JohnMo replied to garrymartin's topic in General Plumbing
Sorry for life is way to short for that. First hit on google search - multiple sizes are available https://www.bes.co.uk/rubber-lined-mild-steel-zinc-plated-clip-47-to-51mm-16770/ -
If you take the typical MCS install, they take the £7500, charge full retail for the heat pump, new cylinder, a bunch new radiators, a couple of mile of 28mm copper and then about 20 man days labour. Soon get to £10k. Typical boiler installation, take old boiler off wall, clip a new one one, couple pipe mods and any you go. 1 to 2 days
To get most advantage of ToU tariff you really need UFH and use as a storage heater. So a thick screed is good 100mm +/-. It takes a long time to heat and cool down.
ASHP with underfloor heating project question
JohnMo replied to Trojan's topic in Air Source Heat Pumps (ASHP)
The downward heat loss is a function of the floor U value, the delta temperature of the floor and the space below multipled by the area. So space below assume 20 degs, your flat temp assume 20 degs. Area 40m2. So UFH assume mean flow temp is 35. Your 0.75 R value, and U value is 1/0.75 so is 1.34 Downwards heat loss UFH 1.34 x (35-20) x 40. Is 804W, then multiple by 24 to loss per day and by 0.27 to get cost per day £5. With a heat the CoP will be around 3, £1.70 Radiator, fan coil etc. Temp Delta between your flat and downstairs zero so zero downward heat loss. Having UFH will cost you you around £1.70 per heating day. So about £320 a year.
