JohnMo
    200
Everything posted by JohnMo
  1. This is a couple of trends of house and summer house. The house is MVHR (but not enthalpy). The second is a heated summer house with dMEV. The trends run from January and you can see when the heating was switched off there is a jump in RH humidity. But it does show an almost flat line in the house. Reducing ventilation rates would fix this. Something like Fresh-R ventilation will do this automatically as it does MVHR based on demand of humidity and CO2 sensed from the extract. House - MVHR Summer house with dMEV.
  2. You really should be getting a structural design done for the decking and the balustrade structure. Didn't realise the fall was quite that much. You have several issues Decking lift in the wind Balustrade wind and protection loadings Decking collapse due to loading or pulling away from the ledger board To name a few
  3. A snippet of our drawings for our deck structure, we moved the hill about instead of a big support structure. Fairy simple steel, galvanised and wood between.
  4. Not sure that is correct From Passivhaus The Passive House criteria allow buildings to go by either criterion - the 15 kWh/(m²yr) heat demand OR the 10W/m² heating load. So heat source doesn't really matter, the actual energy delivered to house that matters.
  5. FYI a twin frame, is a Larson truss. A structural element and non structural to hold the additional insulation.
  6. I would go UFH, which tends to radiate heat unlike radiators. However any heated house will lower the relative humidity. But a little fine tuning of ventilation rates should assist with that and maybe an enthalpy heat exchanger in the MVHR.
  7. Flat steel plates embedded in concrete or on concrete pads. The sandwich in wooden framework
  8. It is here is one supplier and installer, plenty of people on here seem to have used them. There are are others also, but I will leave you to investigate. You wanted to know how to use block and beam with passivhaus, have provided your starter for ten. Foundation details and wall system.
  9. Rather than guess, work out pressure drops and compare to fan curves. Smaller duct equals fan having to do more work, more noise, and no warranty from the sounds of it. 125mm sounds small for anything bigger than a small flat. Anywhere else to route to?
  10. Not sure why it wouldn't, pretty standard arrangement. Do a stick build? Have a read up on Larson strut! Behind the load bearing frame and the airtight membrane would be stuck to it.
  11. Difficulty getting PH loss may be down to form factor. The closer you get to a cube the better the form factor. A good form factor needs less insulation to achieve a good heat loss figure. Our house is long and thin single storey, all ceilings are vaulted, we have a poor form factor and would stand no chance being PH, with all U values well below 0.1. But generally our heat loss is good.
  12. Yep heat input into the house. Not the net gain via a heat pump etc. the spreadsheet does over read the actual input required a little, as no account is taken from human inputs or other equipment in the house or solar gains etc.
  13. No, remember air test is completed at 50Pa, this is like a gale force wind in all directions, which isn't possible in reality.
  14. It's not your airtightness figure, it's your ventilation flow. Hence asking for it's efficiency.
  15. I would want it tucked out the way, say in a small junction box. It may be safe, but just looks wrong.
  16. ACH is well high. Reduce to something realistic, your MVHR will be set to 0.3 to 0.5 they are better figures. -10 OAT, short event, what is the design temperature for your area? 85m2 glazing in your living room - check your figures, 2m high and 40+m wide? Big front door also 4m tall and 2m wide.
  17. I would worry about leaks with the details above. You really need an upstand, then the roof light. Then you take the roof covering up the upstand. We formed our upstands from Compacfoam, not the cheapest, but cold bridge free, super quick to install so very low labour charge.
  18. Could quite easily work. The Durisol block takes all the structural loads on the inside of the block. A timber frame with a structural wall inside and Larson strut on outside to carry insulation. So this type of construction above for the block and beam as detailed above and timber frame as below.
  19. @cheekmonkey All good info above.
  20. First loft insulation looks poor, improve that first. Lag all pipes to and from cylinder, doesn't look to be inside heated envelope, so insulation should ideally be 25mm thick. Interim immersion timer, just look on Screwfix or similar, plenty available. But you have an oil boiler why do you need to run the immersion? If your looking to change to ASHP, just get something basic to do programming.
  21. If your bouncing of the thermostat your WC curve is set too high. Believe your have a mitsubishi ASHP, there is a setting to take room temperature compensation, to change the flue temperature automatically. You should set your curve to get the coldest room up to temp, the use the thermostatic valves to modulate flow to radiators in the warmer rooms. With WC the thermostat is really a secondary control not the prime controller.
  22. See my post above, block and beam drawing thermal bridge free - by durisol (carbonplan drawing) giving all the details.
  23. You may actually be better heating the whole house and not leaving rooms cold. They will just be sucking heat from the rest of the house, requiring other room to have more heat added to compensate, require a higher flow temp to compensate and lower the CoP. We have a summer house connected to our heating system and it gets used in the mornings throughout the year, I was using a setback temperature (afternoon and night), but ended up using more energy as the heat pump ran flat out trying to heat up after the setback period. Ended setting at the same temperature all the time electric consumption dropped. The less complicated it is, usually the better it is.
  24. This is what my boiler manual said about weather compensation and how to set up the house and it's heating system. Note: system is operated as a single zone, the thermostat valves should modulate individual room radiators instead of switching on/off as a zone valve would do. So the heat pump just sees a small change in return temperature and then modulates it's output as required.
