Everything posted by JohnMo
To me your wall build up makes no sense. Your current plans have both options punching holes in vapour tight membrane to get services through, be it electric or plumbing. I would working from inside, plasterboard, service void, then your vapour and airtight layer. Run an OSB strip along the top of the wall to attach cables to.
Sizing ASHP according to heat loss calcs
JohnMo replied to flanagaj's topic in Air Source Heat Pumps (ASHP)
Which almost impossible to find out from datasheets. -
A thermal store is usually a large cylinder and the boiler feeds it with hot water. The store makes DHW via a coil or external heat exchanger. All heating water is taken from store. Is an easy way to stop the boiler from cycling. Do you have a system layout sketch?
Not really complicated, just new. Simple rules 1 zone 1x 3 port diverter valve With a decent screed thickness the floor will act as a buffer, so no need for volumiser or buffer cylinder. Cycling isn't bad as long as it's controlled. The more the heat pump is oversized the flatter the WC curve becomes, mine is almost flat for heat and is flat for cooling. If you are going for a grant, all you need to do is a reality check on system design and make sure heat pump isn't stupidly over sized. Low flow temperature design, each 1 Deg lower represents approx 3% in system efficiency. -
So are you just pulling water from a thermal store? More out of interest. As you say, keeping bedrooms at 19, is the heating system just ticking away, so not really a reaction time thing. Do you have UFH downstairs?
Some cycling is possibly more correct. Short cycling really refers to very short run times and short off times. If you are getting short cycling your system design is poor, no matter what size heat source company to heat needed. You size system volume to ensure you get 10 to 12 minutes of run time no matter what. Then you have controlled cycles, which yield a great cop as well. Our ASHP is huge compared to heat demand, 6kW output from plus 30 to minus 15 degs with a minimum output closer to 4kW. Heat demand closer to 3kW at -9. Will happily supply house with sub 1kW heat demand, with very controlled cycles, just using floor as a buffer. -
Looking to heat DHW takes around 1 hour each time. So say doing 2x heats per day. So you have 22 hours to provide 24 hrs of heating. (2142*24)/22, adds a couple of hundred watts only. Small heat loads need some thinking about, because too small an ASHP, DHW can take an age to heat. You really cannot or have zones, even if you wanted. As heat pump would cycle to much. Your heat pump is going to be oversized, but you can live with that with a simple simple system. -
Multipipe Maxima FM 16-port manifold (..and 13, 14, & 15)
JohnMo replied to mikeysoft's topic in Underfloor Heating
Is this a new build - What's the needs or wishes for 100mm centres -
£400+ bonkers. Why do you need that many loops are you building a hotel? Either why would you not just do 2x manifolds in a appropriate places in the house. -
Could this be the cause of our noisy heating system?
JohnMo replied to Beau's topic in Air Source Heat Pumps (ASHP)
This may or may not make useful reading https://community.openenergymonitor.org/t/vaillant-arotherm-owners-thread/21891/30 -
As said above, by @SimonD. But my only comment is on volumiser, there are two camps, flow and return side of the system - I see both with issues, without correct placement of volumiser and that issue revolves around DHW. So placement of volumiser has to out of the flow path of any hot water directed towards or returning from DHW heating duty. So either downstream of 3 port diverter on central heating side or downstream of central heating, but upstream of tee where DHW returns to system. Reason I say all the above, if not followed you needlessly heat a volume of water while doing DHW heating AND that volume of water with be pumped in to you UFH system, which isn't good.
Leak coming in around roof light EPDM issue
JohnMo replied to nmh's topic in Roofing, Tiling & Slating
Isn't the correct way with EPDM to take a skirt up from horizontal to vertical and up and under any drip ring around roof light? All seams either heat welded or correctly bonded. Difficult to tell from images what they did. My roof is all mechanical fixed and heat welded seams. No mastic or glues. What the roofer is proposing is a bodge at best. -
You generally calc at -3 for England and -5 for most of Scotland some bits down to lower. We generally never go above 6kW load for the whole house (our battery inverter size), 6kW ASHP, MVHR, borehole pump, two ovens, induction hobe, microwave , kettle, everything does does demand electricity at the same time. Our largest draw from the grid is battery charging and that rarely even at 6kW. So you can also charge two cars at the same time if you wanted. -
What is your heat source? Why wouldn't you be running weather compensation no matter what the heat source - so on 24/7 ticking away? If gas assume you are going priority domestic hot water, not S or Y plan?
Think it's whatever your boiler installation manual says and or whatever the plastic pipe manufacturer says. Unless they say nothing. This what Hep2O says Just looked at my old boiler instructions and it makes no mention of special distances from the boiler for copper pipe with plastic pipe allowed. Original equipment manufacturer instructions will normally trump building regs
But isn't the point of you as the property owner checking documents and having them corrected, by your so called consultant? Maybe my engineering background and the obligatory nature of documents reviews and sign off, be it bythe contractor or by client, both have equal responsibility to get stuff done correctly. I never hung back with feedback for all design and as built documentation and made sure it represented what I had paid for or what had been built - not what someone thought they could fob me off with.
Advice on bathroom heat strategy
JohnMo replied to SomethingSensible's topic in Air Source Heat Pumps (ASHP)
That number is defrost support only - not for cycling. Mine is a similar distance from house, it would be worth doing the actual calculations yourself to double check. I get around 1.2m³/h flow through the UFH, without additional pumps, longest loop is 110m. But having limited flow rate doesn't require a buffer in the system, you just add a fixed speed pump to the return piping and run at the lowest speed to achieve the flow you require (it's there to make up for a fixed amount head loss only). -
I just use UFH in coop and heat mode, keeps house a more stable temp and cools quicker after getting solar gain. When house is hotter than outside we open windows and doors also. Bedroom window is most nights.
Possibly not, as the travel slot comes to an abrupt end with door just over 90 degs. That abrupt end breaks all the plastic bits inside and bends the metal parts as door slams open. Very poorly thought out design. Should really have a hydraulic ram to slow door down (similar to that linked by @Beau), then self latch.
I am down to about 300-400W (it fluctuates a bit), 2x MVHR units, heat pump always on, treatment plant, UV steriliser for borehole water treatment. Removed 75W by changing the settings on heat pump for the circulation pump, which by default is always on, to on when requested by heat pump internal controller.
Our doors have these, but, if someone opens door a bit and wanders off, and then the wind catches the door, the mechanism get ripped apart. Now have two doors with mechanisms that don't work because of this.
They look good. Just did an image search and they are listed on Amazon UK site also https://amzn.eu/d/6z1PyQy
A photo or drawing always helps. Way better than many words. But you need the EPDM to lap over the fascia boards so you don't get water entering the gap between the fascia boards and OSB. Assume this is what you are asking?
