Everything posted by Onoff
Makes no difference whatsoever! Appears in good nick too. One pipe in one pipe out, spiral valve with an o-ring that appears in good nick and well greased (silicon grease?). I might pop into Homebase and have a word, I mean I only bought it in 2010 and haven't used it! -
Well we have lights and bubbles! All off a plug top at the mo but I want to check for leaks before closing the bath in. Hot and cold ran out before I could fill above the jet line...it's just about on it. Light on/off works fine but jets are either full whack or off...what I think is the jet control does nothing... Found one snapped wire on a pcb connector, no surprise there seeing how long it's been sat! Going to sit down with a beer now and read the instructions! -
Not acheived much today...too flamin' hot! Each 12V deck around the bath has its own 25mm duct so replacing should be a doddle. All connections are outside the bathroom in an accessible cupboard/ riser: -
Discount Offers of the Week
Onoff replied to Ferdinand's topic in General Self Build & DIY Discussion
I could have done with this: https://www.aldi.co.uk/telescopic-led-drywall-sander/p/095880199818200 -
Pillocks! I had two bottles of Cobra after some barbecue chicken!
Questions about Waste Transfer, Licenses etc
I love it down here, it's been a big problem so the council identified the problem lay-bys, field entrances etc and had a contractor diligently tidy the areas up, dig a hole and concrete in warnings on high metal posts. They now fly tip against the No Fly Tipping signs. Given all that extra space around them it'd be rude not to! In one instance it was so high you could have climbed the pile and nicked the sign. I think that may have happened along with the posts thinking about it. The obligatory pile of tyres is common. One of the oddest was a mountain of 3' lengths of cable insulation about 4" diameter. Took an age for that to go. -
At our tip if you're dumping any form of copper containing cable they have a "special" area away from the designated ones for it. Same place all the too good to throw away kids bikes and garden equipment seems to end up... Amazing how if you ask to take anything that you see; "Not allowed mate, rules you see, Health & Safety.....". I always feel the place is run by an extended family who's primary dwelling is on wheels... -
I should add that once the floor tiles are down and grouted I'll be covering them in some surface protection sheets, duct taped at the joins whilst I do the walls etc. I have a good few Correx boards anyway, site freebies, that I periodically scrub and hose down of whatever plaster, paint, spilt concrete but they're getting a bit tatty. Saved a good few moans by protecting the hallway carpet en route to the bathroom. (In all honesty they're in better nick than the carpet ). If too tatty I'll get 2 or 3 of these: https://www.wickes.co.uk/Proplex-Surface-Protection-Sheet---1200mm-x-2400mm/p/118670
Considered it as I have a Wickes close by. Discounted it after reading here: https://www.tilersforums.co.uk/threads/norcross.79521/ The Laticrete I've got...apparently the biggest brand there is. Soon find out! Think I paid £9 / 20kg.
Floor tiles go down first imo. Wall tiles come down onto them. You then get a horizontal grout line at the base of the wall tiles rather than a face up grout line if you do floor last. Water less likely to penetrate imo especially in the wet room scenario. @Nickfromwales favours this method I believe and he hasn't failed me yet!
MBC slab pour in north Dorset
Onoff replied to vivienz's topic in General Self Build & DIY Discussion
Is it feasible to stick a concrete poker in these mbc slabs upon pouring? I've read a few horror stories of them not coming out level. -
Reservoir Levels rapid Changes
As an aside I see in today's Times that farmers are being granted flexible extraction licences to enable them to take more water from rivers & streams etc. The EA is doing this over fears about food production.- 45 replies
- reservoir levels
- cumbria
(and 2 more)
You know how I rush these things...
As per my earlier post in the other thread the extra tanking kit turned up early! Floor tiles down at the weekend hopefully.
I've only visited one self built passive esque place. (TF, icynene filled I believe). Not a big name TF company either I don't think? The attention to detail imo was second to none. That's down to the tenacity and vision of the self builder in question imo. They're not in it for a quick buck for a start. Maybe it's all about leaving a legacy, self satisfaction, peace of mind etc. Equally it's about the control you excercise over trades that you do use. It exceeds ph standards I believe.
Thought there was still a tiger in the fridge...
Help with kitchen renovation/ 1st house.
Onoff replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
Manoeuvring boards...can't say much really, many of us here have and single handed too. Mine were in fact 2700 x 1200 12.5mm thick. My floor to ceiling height was 2470 and I couldn't be arsed putting in a 70mm strip. (With hindsight I'd have put the ceiling joists in lower). I transported them on my estate roof rack atop a sheet of ply. TP put them on with the forklift. Got them all off on my tod and transported again on my own with the carrier thing with them horizontal. It's a bit of a trick turning them upright for sure and you risk them snapping in the middle. Maybe YouTube "how". -
Not tonight, just dealing with a couple of large cobras after my chicken in the garden...
Cheap foam gun: https://m.ebay.co.uk/itm/Professional-PU-Expanding-Foam-Gun-Grade-Applicator-Chrome-Plated-All-Metal-Body/323051877832? Can't help on cheap low expansion foam. If you want to try with the normal stuff then fill whatever gap with half or less than the gap is big. Gun cleaner is about a fiver a can wherever. So just over £20 for a cheap gun + cleaner + a can of the Soudal Low Expansion Foam. Better? Best I can do! -
Unreal! A message from Amazon yesterday saying the tanking kit had been dispatched by the supplier and would be delivered 8th August. Another email today saying it's been delivered. Wandered down to our post box and somehow they've wedged the rather large tanking kit in there! Even less of an excuse now!
I got the primer, adhesive and grout as "we" have decided on white grout... When I got to the place they didn't do the Larsen extended set stuff (no real call for it, they just do the rapid), I wanted so I got this: With this primer. Slightly more expensive than the Laticrete (same brand as the adhesive) one. Guys there reckon I need to put this primer on the tanking membrane and leave to go off before putting adhesive down? And this grout: Nothing more will happen on the tiling front until the end of next week when I get the rest of the tanking done.
Free veg?- 45 replies
- reservoir levels
- cumbria
(and 2 more)
Link must be in another thread, I did look... Going shortly to get tile adhesive & primer. The place does Larsen products. They do a tanking kit too. Be interesting to get prices / details. Still can't decide on the grout colour! I'll ask when I get to the place whether I should therefore get white or grey adhesive.
Love gun?- 45 replies
- reservoir levels
- cumbria
(and 2 more)
Foam gun? Nail gun?- 45 replies
- reservoir levels
- cumbria
(and 2 more)
