Everything posted by Onoff
What some (most?) sparks baulk at with "signing off" other people's work is they generally won't have a clue as to your FiL's competency. Has he run the cables you can't see properly, are they of the right current carrying capacity throughout, has he tested properly or even fudged the written results. Are his terminations done properly etc. It's to do with 3rd party liability. They can do an EICR but an Electrical Installation Certificate can be a different matter. However as money talks I guarantee you'll find somebody who'll sign it off. I'd be surprised if he hasn't got a mate still in the trade who knows his work and is a scheme member. Some people take that route 😉
Replacing Hyundai Brush cutter. Is Stihl the only option.
Onoff replied to flanagaj's topic in Tools & Equipment
I had two 3Ah clones (Floureon make?) back when clone batteries were first a thing and they were spot on. Lasted for years. One still going I think. Bought two 5Ah clones from elsewhere and they died inside a month with no comeback on the waste of space eBay seller. Genuine all the way now. I print Lidl to Makita battery adapters and vice versa. -
You need to talk to your particular LA / look on their website. It does vary in how they do things. If your FiL is not a member of a competent persons scheme you will still likely end up paying the full fee. Even if he is qualified and competent as in has the necessary training, qualifications and experience he needs to be in one of the schemes to make it plain sailing. In my case they would accept my electrical qualifications, even then my Part P qualification, my schedules of tests etc. Still wanted to send out someone they sub electrical inspections out to. The fee would have been the same as if I'd had none of the above. They did not, at the time have their own in house electrically qualified building inspectors. Thus they subbed to the council's favoured leccy contractor and gave them a building inspector's badge for the day. I have a long email from them on it somewhere from the then head of building control who I knew from a previous life. My LA's fee page, see D19: https://www.sevenoaks.gov.uk/info/20069135/building_control/439/building_control_fees/4
Steel upright in inner block work
Onoff replied to Super_Paulie's topic in House Extensions & Conservatories
Good idea that Aerogel 👍 -
BiL just had a fake 5Ah one go bang in the, again fake Makita charger. He was out and had left it charging on the carpeted stairs landing. Came in to the smell of burnt plastic etc. It had spewed out solder and molten plastic over the carpet but luckily hadn't caught fire. Just had the modern, presumably fireproof carpet fitted. -
+1. Go battery and save the petrol for cars. -
Mine: https://www.howetools.co.uk/makita-dur368az-twin-18v-brush-cutter -
Makita 36V here. Well pleased. -
Lines across middle pane of triple glazed Internorm Slider
Onoff replied to Meabh's topic in Windows & Glazing
"Roller wave" possible. Caused when it's floated. -
The plus points stack up for good old black bitumen paint. Cheap, it'll fill pin holes and round the roofing screws. Easily to reapply too. On rusty steel it also has a protective effect as the oil seeps out. Probably the best chance of sticking if there's remnants of paint on there. You can get a white bitumen. A flexible acrylic like Acrypol, Chromapol, Evercryl etc is sort of made for the job but expensive. Easy to reapply but I'd worry about rust carrying on under the paint. Whatever I'd jet wash first. If you can, get the worst rust off and paint with a phosphoric acid solution before painting. It'll turn the rust to a stable black/grey. As in iron oxide to iron phosphate like Jenolite rust converter.
A strip of Aerogel insulation perhaps? -
You're too kind. Up close you could hang your coat on the walls. Boy did I learn a lot doing it though.
I cast my floor to falls in the wet room corner and it's stayed perfect. Took some working out along with the Geberit wall drain. I'd do it again in a heartbeat but next time use a tile levelling system.
If you do floor first then the wall tiles come down onto them. A much better detail in terms of waterproofing and no horrible grout line at the edge where the floor and wall meet.
I did floor first then protected the floor with Correx. I then used a homemade tile levelling system to place the second tile up. For the bottom tile I turned it over, placed it on 1mm packers and marked the cut line with the laser. When you turn it back it's bang on: (I should add I can't tile to save my life! Up until then the wall boarding was all perfectly square 😂).
That's b***ocks. Floor first, right up to the wall. Then bring the wall tiles down onto them with a 1mm gap. Seal with CT1, wipe flush. When set put a silicone bead on which you can periodically replace. A Welsh wizard once told me that.
https://www.saxtonblades.co.uk/
It's reassuringly expensive too. First coat covers bare wood. Give it 3 like it says on the tin and it just lasts.
Black, satin, Bedec barn paint, to do the rest of that wood 👌
Yep, top bolt will fail first I'll bet. Ask the next chubster family that rocks up to try a "good" bench with the offer of free doughnuts. Maybe set up a wildlife camera to look at the bolts...
Edge distance issue that imo.
What can I use to fill huge hole Garden?
Onoff replied to Hussein Nurbhai's topic in Landscaping, Decking & Patios
You could go smashed hardcore, then a bag of Type 1 or 2, a weed fabric to retain the soil then the soil. -
If intent on filling it then there's very likely to be an offer of free hardcore local to you. Are all those slabs around it being scrapped? If so, smash or drill drainage holes in the bottom then heave any unwanted slabs, bricks, tiles etc in. Smash with a club hammer.
