Everything posted by joe90
How does your garden grow?
joe90 replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Comfrey is supposed to be very good but stinks so I have heard! -
Welding with gussets would be much stronger I guess š¤Yes pallets are a good idea (and you keep the steel š
floor plans - ideas/feedback
joe90 replied to thetinothproject's topic in New House & Self Build Design
A bit like mine thenš¤£š¤£š¤£š¤£š¤£š¤£a rectangle orientated South to the long section is the most efficient relative to solar gain. A āpyramid roofā is also the most cost effective.- 38 replies
- layout plan
- newbuild selfbuild
(and 2 more)
But as I have no PV (yet) and I only heat DHW to 48ā i would end up with Luke warm water š¤
Bung all off cuts in stud walls to absorb sound!
But if you did this then someone halfway through a shower would get warm water not hot š¤. What we need is a āfuel gauge ā like on a petrol tank, come on bods design us something (thatās not complicated because I am a Luddite š¤·āāļø)
Well, the downpipe on the house is a smaller diameter than the underground pipe so if you put your overflow into the drain in the ground itās not a problem.
I would keep the barrels for watering the plants etc and fit an overflow to your house drains, nothing to say you canāt.
Brick acid ? https://www.ebay.co.uk/itm/313562295784
Definitely š, you have proved yourself that with a little advise you are quite capable. I would fix the wall timber with threaded rod epoxied into the ātop of the hillsā, and if needed pack out a low bit. I suggest you draw a plan up, post it here and you will get advise on whether it needs amending or not. Crack on sunshine š
Tarps are a nightmare, short term only IMO, the only way to keep it completely dry is scaffolding top hat (temporary tin roof) but these are expensive. Depends how much of existing is being kept and needs to be kept dry. A new build (like mine) got very wet but will dry out.
Let us know how you get on, if we donāt hear from you we know the worst has happened š¤£
Weāre not the YMCA š®āāļø
Hot tub? Used in summer when the sun shines the most š¤·āāļø
Moving swiftly onā¦.. I agree with Dave, option 1 IMO. If you are not happy with your architect then find one you are happy with ( if you need one š¤·āāļø)- 38 replies
- layout plan
(and 2 more)
Welcome Paul, lots of knowledge here, ask away.
@CharlieKLP why are you more interested in discrediting people than helping the OP?- 38 replies
- layout plan
(and 2 more)
Evidence? Nothing on the drawings above.- 38 replies
- layout plan
(and 2 more)
And?- 38 replies
- layout plan
(and 2 more)
No, @thetinothproject stated he WAS an architect, why do you question this? Why donāt you give us some insight as a professional on the original question rather than question other peopleās qualifications!- 38 replies
- layout plan
(and 2 more)
@thetinothproject states he is an architect, as per the other thread on architects itās about what the OP wants, not what āprofessionalsā thinks he should have. I turned our build round 90ā to face the drive, not the road which also gave us a South facing lounge, diner and conservatory š- 38 replies
- layout plan
(and 2 more)
Make sure you have someone else with you to haul you out if it gets sticky, harness and rope might be good.
I totally agree, I had four applications, gone to committee and appeal to the Secretary of State (which I won), the build was a doddle.
With my build I refused to get stressed because of health issues linked to stress in the past. I told my builder I understood shit happened in life and any problems we come across we will deal with, because of this our site was a stress free zone, perhaps I was lucky but stress only causes bad health and does not actually deal with the problem s you encounter, take a deep breath and count to ten!
What is your hedge ? Leylandi, privet? If privet you could cut it back to the centre and put up chain link fence then the privet will grow back through it but you will be secure. Unfortunately leylandi wonāt āgreen upā if you cut it back to the brown core. Personally I donāt like panel fences, they donāt last very long and tend to blow down, if you donāt mind trimming a couple of times a year a hedge looks better and lasts longer IMO.
