Everything posted by ToughButterCup
Genvex purchase
ToughButterCup replied to Gone West's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If you want to know why I joined this forum, here's the answer. -
Building a simple car park
ToughButterCup replied to ToughButterCup's topic in General Construction Issues
Must go to AngularRus then... -
This will be a small car park. So far I have put some drainage piping under it, covered it with what was left over from our MOT 1 pile and levelled it with our digger. I'd like to prettify it as cheaply as is sensible. My thoughts are to roll it as flat as I can get it, put some of that black membrane down to suppress weeds, and then tip some 40 to dust on top of that. Roll that to with a mm of it's life and then wait for the rain to 'tighten things up' And then put some pretty gravel on it. I know gravel isn't ideal : it moves..... But it's always the same old story: how do I do just enough to make it look a million dollars with only a hundred in my bank account? I'm sure someone has faced this challenge before. May I plagiarise your ideas please?
Do low energy houses really need heating controls?
ToughButterCup replied to pdf27's topic in Boffin's Corner
You'll make a scientist out of me yet. ....And I can even explain (at the right time to the right audience) how that trope 'thermal mass' benefits from a small tweak. Who's a clever boy then? I am. Even my esteemed architect trots (used to) it out occasionally . -
This is a meaty read... Perfect for a lazy Sunday morning. The answer is 'yes', then? -
Cornwall, dahling, Cornwall as @pudding says.
Nudura One series variation
ToughButterCup replied to LadyBuilder's topic in Insulated Concrete Formwork (ICF)
The ICF Durisol has the insulation in the outer half of the block and concrete on the inside of it. Both those materials are 'shuttered' within a wooden form held together by cement. -
Plumbing 101: the absolute basics
ToughButterCup replied to ToughButterCup's topic in General Plumbing
I had thought that a 'silly' idea . Not anymore. Dunno why .It was Pete who first mentioned it. I'll give it a try. -
I am not going to be able to replace all the copper with anything else, no matter how good the replacement is. So I have to acquire some copper skills. Probably no bad thing. Essential, as in cannot do without tools - a sort of Plumbers Starter Kit ? Ideas please. -
Trying to get our current house ready for spring 2018. The plumbing is dire. SWMBO and I spent so much time when we were at home after formal working hours preparing for the next bit of work, that we simply ignored all sorts of DIY stuff. But now we (what do I mean 'we' - I ) need to get a grip of it all. A clanking heating system, weeping this that and the other. The end in mind? Bring the house plumbing up to a standard which would allow us to rent it out. And to do that in an affordable, and safe way. My plumbing skills are sub-prime. Nugatory. Negative. As usual I turn to YooChube for help. And, then I realise that I need to practice. A bit like @jamiehamy did here. So I need to get some bits and bobs together on which to practice I think I can guess some of the things I'll need to work on Hep2O and copper systems. And I think I'll start with joining bits of copper pipe. Any advice? Dos don'ts? Any good YT resources you've used? All help welcomed.....
Anyone know how much sway Parish Council has?
ToughButterCup replied to nubbins's topic in Planning Permission
That is a core skill. Holding your nerve, and developing more than normal levels of resilience. Most self builders are expert, or near experts in their own field of work. And suddenly through our self build, we are exposed to systems and people who are -nominally at least - far more expert than we are. And thats very jangling. It leads to all sorts of difficult challenges - and since many of those hit you right in the bank balance, it what the experts call a 'high stakes' sector. That's why we (BH) exist, and why you will find a highly committed audience here ready to listen to what you have to say. In my case on BH and its predecessor (2 or three years) I have already been given far more than I can ever give back (two posts saved me £17k, but I have saved much more than that overall). In holding your nerve, you might like to think about creative and wholesome ways in which you can distract yourself from the almost perma-worry. For me, I am learning (re-learning) how to fly drones and I use the BBC Radio iPlayer last thing at night to help me, through distraction, to switch off. Keep us posted, and or PM me if you need a private word. If I don't know, I'll know someone who does. Ian -
Close to none if - as is the case locally - the PC persist in submitting invalid objections. Like these The Head of Planning has (reportedly) told our PC that their feedback will no longer be routinely considered This is the most concise list of valid objections that I have found Exactly - to the word - that was said of ours. And the Planners rejected that 'consideration' (that's all it is) out of hand. That said, there is no point in annoying the locals, but there is every good reason to stand your ground if the reasons given for objection are trivial, unevidenced or impressionistic. We were determined to build to a high standard in terms of current design trends - passive, to a degree, and use materials like wood rather than stone where possible. It takes a hundred years to 'turn a tree round' and a few million to make a stone. Hold your ground and your nerve. Your case feels very similar indeed to ours. Welcome by the way Ian -
I recon we have a case of sludge flake - and this isn't the breakfast cereal type of flake either. Help us sort it out, please. We've drained the system down twice now, and radiator performance is at best patchy. So next weekend, we're determined to Drain down Take the rads off and flush them and do our best to flush the 'tubes'.... and that's where we'd like some help When the system is heated by the fire, and the pump is circulating hot water, you can feel the change (drop) in temperature where the wider pipe meets the narrow one. We can hear little pairs of castanets rattling in the pipe (together with entrained air from a leaky valve). Once you take the rads off and clean them out, how do you clean out the small bore pipe?
Now that the roof is on the piggery, and there's power in the building, its time to move my tools to their new home. I want ot make a set of sliding shelves, each holding a Bosch L-Boxx with its tool. Maximum weight - 25 kg The question is which sliding runner should I use for the shelves? The research I have done shows a wide range of price and complexity. I'm willing to bet you can tell me what to avoid.... And perhaps be willing to recommend one or two makes.
Devices dropping out of WiFi
ToughButterCup replied to ToughButterCup's topic in General Self Build & DIY Discussion
All part of the service mate..... -
Right folks, thanks. Recommendations for dual band router? -
And now that I have returned home, the sodding Chromebook and my phone connects just fine. Time for a new router? -
The only recent updates have been the (massive) Windows update. All on, all off, many times, all hardware inspected for continuity and eejit errors. What's most curious is that the Chromebook and the phones simply spit the password out of their prams. And I'm writing this post from Debbie's office in Lancaster University on the Chromebook - the very same one that spits out the password for our WiFi at home. WiFi works perfectly on our phones at Lancaster University as well. Cant take a joke? Shouldn'a installed WiFi at home should I? -
Auto Both our PCs are fine, its just the 2 Android's and a chromebook -
We have two PCs, two phones and a couple of laptops. The PCs manage to keep their connection with our WiFi. But both our phones and a Chromebook lose their WiFi connections. Trying to re-establish the connection, the connection dialogue box asks for the (long-saved) password. We enter it and the dialogue box immediately rejects it. Not much hair left at the moment. Ideas?
So, how do I know it's you - or at least the owner of the bath? You are in the bath with no shoes. How often have we seen trades in a bath with shoes on ("Dinna worry, hen, it'll be reet!")
Welcome And welcome to perma-worry, perma-change, perma-you're-charging-how-much? Get lost!
funding to build two houses on one plot
ToughButterCup replied to Moonshine's topic in Self Build Mortgages
I am almost sure you will not be refunded your VAT. -
Is that what the orange smudge is.... Commonly seen on slow flowing water courses ?
