Everything posted by ToughButterCup
PMSL, full-on, tea through my nose, dropped the cup, smashed it, still laughing Welcome indeed VoH. Or may I guess, dude? I dare ya! A photo would do us all a power of good. @Onoff will be along shortly with soothing words of procrastination and electro-babble. He specialises in wet fingered dabbling in plastic wires that contain smoke. Ian
No. Make sure you use an RCD (Residual Current Device like this ) and use this sort of cable: Arctic Blue 240 Volt 3 Core 13 Amp to 16 Amp, commonly referred to as 16amp arctic. A few meters of this stuff never goes amiss either : mine got nicked after a month.
Welcome! We won't be able to judge the price until you give us a few more details, but as @Russell griffiths says, why worry? Tupperware valleys are fine
And while I think like of it @Hecateh, try and arrange for a safe temporary electricity supply from your house for the duration of the build. Doing that takes the pressure off getting the main supply to the new house.....
Yes. And yes
I spend quite a bit of time planning to put important infrastructure bits and pieces in ready for future expenditure, as well as practising sensible levels of mean-ness thus; unused (blind) piles in the ground for an eventual extension (cost £120 instead of a several thousand) MVHR ducting in the ceiling but no MVHR unit for the first year until I have calculated how much heat the house really needs We'd love a Geberit loo (well 2 really) The (isolated) electricity supply for their control system will be in the services void ready for when we can afford them. Until then...... Supply to an eventual car charging point put in, but blanked off at the CU recycling as many 8mm roofing screws as I can (and other screws if I think of it at the time) recycling as much wood as I can - de-nailing de-screwing (when I have the courage) planning not to have carpets (but I bet we end up with rugs) where possible recycling stone found on site
I would be very surprised if they couldn't. Keep asking . And get a supply map first ....!
Steeling the Show. And an attack of wind
ToughButterCup replied to ToughButterCup's topic in RSJs, Lintels & Steelwork
My only focus is the support of things like windows, doors and steels attached to the outer skin of the house. Normally the odd empty bit of Durisol block is irrelevant and never noticed because people don't look for it. The problems I face are not new or unique to Durisol: many others will have faced the problems and solved it before. It's just a matter of plugging away and having the courage and humility to ask for advice. -
Hold on a mo @Hecateh, why aren't they connecting to the existing supply? By that I mean, the supply that connects the bungalow? (if I have read your diagram correctly)
Evidence, evidence, evidence. Exactly @PeterStarck. Camera on order, arriving tomorrow. Now that I think of it, there are lots of little jobs I have for such an implement. -
Always up for a challenge old chap. Keeps me off the streets. -
Nick, all the steelwork is outside the heated envelope, and so there is no need to insulate it. Nothing goes through the Durisol insulation, except the M16 threaded bar, but that terminates within the concrete. So there is a small cold-bridge, mitigated by the internal insulation. -
Hmmm, @ProDave and @jamiehamy It's Germanic-Me that's thinking of the BCO.... message understood No, @jamiehamy, both structures are said to be independent. I know from experience that the house has stood many (named) storms so far with no ill effect - a few trades people have commented that any other build system (they know about) would have blown down by now. But the steels need to be rock solid too; and given this hiccup (thank God I found it!) I'm proceeding with caution. Thanks very much for your help. Ian -
Steels are up! After a fashion: with our build, there's always a twist so read on! First have a look at this....... We finished late last night SWMBO is really happy, and, to an extent so am I. The L shaped steel structure is secured to the floor with Thunder bolts, and will be secured to the wall with 16mm threaded bar embedded in the Durisol block. So far so simple. There was a gale last night , and attack of wind if you like : a useful gale, because it made me think hard. The purpose of this post is to ask you to check my thinking and offer relevant comments before I talk to the SE and Durisol. Many of you will remember the hiccup we had recently with the wall collapse (If not read this) And I am quite prepared to accept that that experience is colouring my thinking too much; but here goes. For those of you who are unfamiliar with Durisol block, here is a brief introduction - to understand the rest of this, it's worth a quick look (Links to an image search for Durisol: you only need to understand what it looks like) The vertical columns (steels) are attached to walls with threaded bar. It's that 16mm threaded bar connection that concern me. Because I cannot guarantee the continuity of the concrete within the Durisol blocks: it is that concrete into which I drill and attach the threaded bar and secure with Fischer Resin mortar One of the holes I drilled through the blocks showed that there was no concrete there at all. (The drill went straight through and out the other side of the block) Normally that lack of continuity will not not matter one little bit. But it does matter when the integrity of another structure depends in part on the attachment to the wall. Proposed Strategy Talk the issue with the architect (already done - strategy agreed) Talk to you all Think it through again on the light of the above and Ring Tanners (our SE) Ring Dursiol - maybe ask them to visit Agree problem solution : Talk to BC and ask for a visit before doing the following - Proposed problem solution Examine each of the current drilled holes with an inspection camera: checking to see 100% concrete continuity Attach the steel columns to those holes which 'pass' the test Create another series of attachment points by; identifying 5 further attachment points and exposing the concrete behind the insulation by cutting out that insulation entirely verifying the quality of the concrete drilling into it to create five more attachment points (one per hole) replacing some of the insulation and backfilling with cements and PVA mix. Bit of a faff, but I have realised that technical reassurance that (in this case) the structure is self-supporting is not enough. I need to know deep down in my gut that the structure is rock solid. The psychology is as important as the technical stuff.
Slating a simple, small roof. Planning 1
ToughButterCup replied to ToughButterCup's topic in Roofing, Tiling & Slating
Well, if you put it like that...... I was thinking of just leaving the green felt there and putting counter battens on top of it, and then proper membrane on top, followed by battens and tiles in the normal way. Why? Lazy. (Normal? Ha! Exceptional i.e. once only - ever - for me)- 27 replies
Get thee behind me Satan......... Give me fifteen good reasons why.- 27 replies
No @Declan52: I wish Soudal would do, but it won't. I need to anchor a stainless threaded bar in the wal.....
Oh no - another excited newbee.
ToughButterCup replied to epsilonGreedy's topic in Introduce Yourself
And everyone else is jealous of you being on fire, and watch your every move for signs of your bum being on fire too. -
...in more ways than one. Its OK, I'll get my coat.
Yes. I drilled into a Durisol block hoping to fix a stainless threaded bar in the concrete. And found fresh air. The cure is to make a thin mix of cement and PVA and, using a mortar gun, pour it into the 16mm hole I made (for the threaded bar), and wait. I love trowel work, and won't be using the mortar gun unless I have a good reason not to use a trowel. Ian
I need a mortar gun: never used one, I know what they look like, and they are widely available. I bet, though, there are those I should avoid. Recommendations, please. Thanks Ian
First of all, welcome. In relation to every single one of your points, you'll have many happy fire-side hours reading the relevant stuff on this site. It's yet another job in addition to the ones you already have. We'll try and make it easier for you: it's often a good idea to tell us about the work you have done towards answering the questions you pose - it helps us give more focused responses. BTW, what's epsilon got to do with greed? Ian -
Demolition
ToughButterCup replied to Russell griffiths's topic in General Self Build & DIY Discussion
Spill some paraffin.
