Nestor
Everything posted by Nestor
As @Conor Can you confirm the quality of the tile, even thickness at either end and centre. Perfectly flat or any bowing? Can you run a straight edge across the vertical surface for a photo.
I used the In screed cable from here, have a read around. https://flexel.co.uk/product-category/underfloor-heating/ Just check the UFH matting adheres to the board, the self levelling will help bond it all together. Regarding threshold heights, on a new self build it can become a bit obsessive. Just do your best with the materials available. Do another section drawing in mm with the new materials for your own peace of mind including tile and the adhesive. Make a start, hopefully using large format tiles! I had over 1100 hexagonal and small rectangonal tiles to fit in our Wetroom. Never again. I used https://www.protilertools.co.uk as well.
I. agree, you agree. It was really a comment on @ETC contributions. Addressing overbearing and cramped should get this passed.
Progress, Option 1. Huge improvement. Great to see a contemporary new build design instead of rehashing the existing vernacular. Personally, it is a tricky site with minimal parking for both properties, I think a 3 bed with attached garage would be acceptable.
From our window experience it was all such a disappointment, especially the fitting which they do everyday! I think an independent report would be advisable to move forward. Lovely looking home, btw.
Some random thoughts, not a professional but built a house with 4 bathrooms. A level threshold to the bedroom would be very critical for me, within a few mm. I fitted wet UFH in foiled EPS boards under the 6mm Hardie Backer and electric cable in a 50mm sand & cement screed. You could use 18mm P5 or 12mm Hardie Backer above the insulation and slab but would need to be fixed well, no movement. I think fixed battens to the slab would work. Electric, (is it self adhesive matting) fitted to one of the above then apply thin layer of self levelling to encapsulate heating elements. Then tank and tile. What the Boss @Nickfromwales said.
What Nick said, A tiled floating floor wet room does not work for me, I would want it all fixed with zero movement. When I tiled our wet room I fixed Hardie backer board through to the P5 Caberdek which is fixed to the floor joists.
Floating so battens not fixed to the slab?
Clippa plate or similar between joist ufh
Nestor replied to Selfbuildsarah's topic in Underfloor Heating
As above. -
It is all subjective but I would not call this " a prominent corner plot" even though the case officer seems to be on your side. It is overbearing and cramped. All are semis with a driveway between except number 42 with a separate garage at the rear. You have had 19 letters of objection. Upset the Arboricultural Officer and Natural England. No property in the street has had a two storey extension built. All single storey wraparound. Look at no 33 for ideas, looks like garage with a mono pitch roof or imagine no 42 with an attached garage.
Enclosed are the drawings of the application for a 2 storey extension at no 33 back in 2006. Was refused. You have also had 11 objection letters from your neighbours. Also the removal of 2 mature oak trees prior to planning does not go down well with the locals. Not sure your planning consultant is listening. Good luck.
This was your second refusal? Some random grabs from a quick search, 2 have a front facing gable which are probably not suitable and 2 hipped with garage on right hand side. Looking at past planning applications, your neighbours have planning for only single storey extensions, the only 2 storey application was refused in 2006.
Good point and I would switch the garage to the right hand side to create more visual space to no 35. Worth doing a few visuals.
That was a bonus. Your proposal (Double fronted) and the corner home opposite yours, you can understand the comments cramped and overbearing. Difficult design to compromise if wanting the double frontage. You will get there.
Did you purchase the property in September 2024 with the sole purpose of building on the corner plot? You are taking full advantage of the plot size so not surprised with some push back. Another attempt with the planning consultant should get you your result.
Week 28 - Floor tiling, bathrooms, cladding, MVHR, electrics…
Nestor commented on Benpointer's blog entry in Contemporary build in north Dorset
They are doing a great job, I was only being pedantic. It is great seeing the progress through your blog. The local timber is special but quite challenging to work with, shrinkage was inevitable ( air dried in the garage for 3 months but not enough) but the half lap compensated for it. I also used about 150 sqm of local Douglas fir for the garage, no half lap as horizontal shiplap. Quite similar to Cedar, not as knotty, feels a bit denser. Weathering well and might stain it next summer. Onwards......- 25 comments
- floor tiling
- cladding
(and 2 more)
Fantastic build, the Ash is such a premium product and looks great. I purchased about 300sqm of locally cut Red Cedar, 200mm wide and then cut a half lap on each edge, fixed with SS screws. Very knotty compared to Canadian but does not detract. Image below is triggering!! But you do have very good builders, you must so pleased with the progress. Can you tell me what the electrics behind the cladding is, one looks like Cat 5/6?- 25 comments
- floor tiling
- cladding
(and 2 more)
Screen grab from the Kingspan site. Not sure where the 10mm drape on top of the batten would have come from. Is your final roof covering on? I did fit 9 Velux in our roof using the Velux insulation and underfelt collars as well as taping the membrane around the frame. Near waterproof before I fitted flashing kit and metal roof.
What does this architectural symbol mean?
Nestor replied to Tony L's topic in Surveyors & Architects
Sack trolley, clock hands or the image is a standardized symbol (IEC 60417 - 6284) used in technical documentation. No idea. -
stainless steel screws for chestnut cladding / decking etc
Nestor replied to marmic's topic in Building Materials
I am still learning, the molybdenum is the difference. -
I used 1000's of these from Screwfix to fix Cedar and Douglas Fir Cladding. Worked well, good value, a little delicate if you want to keep removing them. Need to be square on. Described as stainless steel construction. -
Advice please: cutting metal down pipe.... without
Nestor replied to ToughButterCup's topic in Rainwater, Guttering & SuDS
I fitted over 90 metres of Lindab Majestic gutters and assorted outlets, brackets, joints etc and thought the quality was very good though a bit surprised the leaf trap was plastic. Obviously looks great but the cost! -
I used a holesaw for the gutters and a 5" grinder for cutting downpipes. I rotate the gutter by hand whilst cutting. I struggle using a hacksaw, the blade is to fine and narrow even using a mitre box. -
Thanks for the update. Would you have a figure for your annual generation you could share?
Windows delivered - wrong internal finish/colour
Nestor replied to AppleDown's topic in Windows & Glazing
As you say a little hazy. The signed contract is a legally binding agreement, unless you are the government but hopefully you have written email evidence confirming your conversations. I would try and keep the suppliers onside for as long as possible before you go medieval on them, perhaps a significant discount would be best. Good luck.
