Nestor
    6
Everything posted by Nestor
  1. Did they not supply a schedule for each window to sign off, similar to the example below.
  2. Cheer up "If voting changed anything, they would make it illegal" Emma Goldman 1869-1940.
  3. As long as its a recyclable box.
  4. This was my new build so required for BCO. Did need one for our rental, we replaced all the old sash windows for double glazing and they then downgraded the EPC from a D to an E. After a few stroppy calls they reinstated it back to a D! You do require an EPC if selling a property.
  5. Good point, yes, Last year consumed was 2998kWh and delivered 8581kWh. This is from the Mitsubishi readout which seems quite accurate as have an Elster and Shelly meter with very similar totals. DHW is on 24/7.
  6. As an example our EPC stated below but last 5 years it has been an average of 3000 kWh for both DHW and Heating.
  7. Morning, I would avoid the large drum and belt sanders for the advice already given, noise, dust and knackered sheets if not fixed correctly. If you are prepared to spend a lot of time on your knees I would use good quality sheet sander and a detail sander for the corners and against the skirting. Do a test with different grade sanding sheets / rolls and then proceed. Good quality dust mask and extraction if possible. Lovely view from the window. Do this before others encourage you to rip it all out, fit UFH, ASHP and external wall insulation!! Enjoy the Forum.
  8. To reply to others type the @ symbol then a letter, names will pop up, scroll down to find the poster you wish to reply to. Give it a try. @damspt
  9. 2 options, CPI or temporary freeze until CPI aligns with RPI, mid 2030's. Over 800,000 homes had FiT installations. Email address: [email protected] Payback calculations below, November 2011.
  10. I fitted the same and like you abit disappointed, the trap being plastic, overall does not really match the quality of the Majestic system which is excellent.
  11. And @SteamyTea Thanks for that, will have a read and could replace with rockwool. I read that some type of aluminised vapour control membrane needs to be fitted. I will look for a drawing.
  12. I have a 12m x 6m garage with carport on the end. I have now enclosed a 3m x 3m area to accommodate a sauna, 2m x 1.3m, separate shower +WC, and kitchen sink. Large enough to lie down, 3 seated. I had some 150mm Celotex left over so used that on the base, + 50mm concrete screed with electric UFH. Fitted Celotex in the external walls. External cold shower and above ground plunge bath eventually. Stud work completed, waiting for the electrician..
  13. In 2017, BPC supplied a metal silencer, ASM 150600 with my kit. I fitted it between the Vent Axia unit and supply manifold only. Unit fixed down well? It might help temporarily, disconnecting one of the supply from the manifold to the bedroom as you have a double.
  14. Just had a quick glance at your drawings, looks great. I do like the split level, we have a sloping site and all 4 entrance /exits are flush with the outside. Any doors to separate the hallway from the main living area? Noise might be an issue upstairs. We have 2 pocket doors (Not noisy) and are in use most evenings if others are in the bedrooms. I would spend time and money on soundproofing between bedrooms and bathrooms.
  15. I fitted about 55sqm of Parador Trendtime 5 LVT, rough dimensions 900mm x 450mm x 6mm. Floating on Caberdek. Good quality product but does slightly lift where sited in direct sunlight in front of 4 metre sliding door. Very slight bow between first and second tile now. It just lays flush up against door threshold, I left expansion gaps against walls and under kitchen cabinets. Gaps all hidden. I plan to lift the first row and apply either glue or double sided. No obvious movement issues anywhere else.
  16. I did B, no movement or cracking. Taped and skimmed. Lets ask the boss @nod
  17. I agree with @Mr Punter. Have 2 runs. Not a professional but I exited pipework out of the building to avoid long runs within the slab. Bit of extra external excavation but all accessible.
  18. Please explain why you call it a softwood? Paging @SteamyTea
  19. It has been working fine, been in use for 5 years now, emptied twice as we have a septic tank here as well for another building. Very simple operation, has been redesigned since this model. Air pump housing was basic plastic box which reverberates so needs careful placement sound proofing, etc. No settled sludge, no smells. Much missed Joe90 passed away in February.
  20. Yep, a race to the bottom and we are winning. Their is a lower and standard rate depending on qualifying materials.
  21. Correct, most composite doors have a solid timber / foam core surrounded by uPVC.
  22. You would need to check the lipping amount on each vertical edge. Our internal doors have 6mm lipping. External doors are usually constructed using solid strips / blocks of timber but you would need to check the door spec on each stile. You probably need to move / replace the door stops depending on thickness of replacement.
  23. Rough, you need an architect.
  24. Good question as LVT does require space for expansion especially if in direct sunlight. As SWMBO changed their mind I then laid LVT on top of the tiles up to the legs as I had already installed the kitchen units. Ask the flooring company why.
  25. Not a professional tiler but tiles first, @nod will confirm.
