Nestor
    6
Everything posted by Nestor
  1. I used https://www.howdens.com/joinery/skirting-boards. Consistent quality product, primed and a fair price. Easy to fill and sand, I fit with SticksLike or similar and use ovals pinned through. Tried Gripfill but not worked here. I scribed the internal corners, took a bit of MDF to master but worth a try. Robin Clevett here :
  2. I made some concrete worktops and used https://www.atsdiamondtools.co.uk for polishing pads. Have fun.
  3. +1 for Sigma. I purchased this https://www.protilertools.co.uk/product/montolit-63p5xl-masterpiuma-p5-power-5-manual-tile-cutter-63cm
  4. Similar issues here on local lanes, Permissions and cost will be challenging going under the road. A bit crude but a trench excavated next to and under the hedge, large diameter pipe then fitted. That is 150mm diameter pipe in the photo. Only needs to be below the lowest point of the lane. Does get clogged up a few time a year which creates 50 metres of standing water, then cleared within a day.
  5. No mains gas and used oil in the past. New self build, air tight, MVHR, 3G etc. 275sqm. RHI was available so paid for kit and install. Our personal use for 2025 was 2700kWh for hot water and heating. However, I would not recommend ASHP in average insulated home with mains gas available if cost is a major factor.
  6. Congratulations Russell, looks amazing and do post a few more photos when ready. Similar here, started in 2017 and moved in after 3 years. 6 years later some minor tasks to complete....
  7. I have both the Makita and Milwaukee 18V oil driven impact drivers, the Makita is twice the price though quieter. 12V is probably enough for most tasks.
  8. I had the MAKITA DTS141ZJ, silly money but was a pleasure to use whilst building a house, very quiet. It did develop a fault after 6 years heavy use. Now using a Milwaukee M18 FQID, more torque, cheaper but not as quiet as the Makita.
  9. About to give this ago, DUC150Z for 50 metres of Devon bank medium hedge pruning / cutting back. Will let you know my thoughts in a few days Silky saw, no batteries required.
  10. Looks like hardboard due to the staining but It could be a type of Sundeala board, wood fibre pin board originally. Is it slightly soft if you apply a little pressure to it from inside the loft? Very impressed with your clear up, proper job.
  11. The Makita kit has been great. Just bought some 6.0Ah batteries from Toolden, always worth a search around for best prices. FFX now ITS https://www.lawson-his.co.uk https://its.co.uk https://www.powertoolworld.co.uk https://www.worldofpower.co.uk https://www.toolden.co.uk/tool-brands/makita/?utm_source=Klaviyo&utm_medium=flow&utm_campaign=Makita Cross Sell&utm_id=VXmYPi&_kx=iewy0UUI_HNqAKAOi3JbrAcYoka6HO07az6VLHTOI0U.WVZJJz
  12. @Hastings Great work, love the pulley approach. My parents ,now late octogenarians converted dilapidated flint stone barn late 90's. Tons of work. Only now, due to feeling the cold decided to insulate the walls with Pavatherm and lime plaster. Huge difference in comfort and minimal space lost. They also converted another shed using the approach above, internal timber frame, Pavatherm and lime. Keeps them busy!
  13. War. It's a cult. Let's get back to weather compensation.
  14. I had the ASHP supplied and fitted from one company under the RHI scheme. All the UFH materials supplied by Wunda which I installed.
  15. We hear you Ian, I now try to focus on one task only and do not deviate. (Not easy) January has been to complete the bat roost. Baffles, partitions, F1 bitumen felt, crawl access etc. It will be done. Not been on holiday since 2017 when the build started, though have crossed the Taymar bridge a few times! February's plan is hopefully outside dealing with hedges, fences. A good clear up and sort out, dip in the river or sea helps me.
  16. Morning @Duncan62 Were you expecting the self levelling concrete to be your final flooring or adding another layer? I sense that a concrete surface was / is your desired outcome. If you have the time and energy I would recommend you do a test with a grinder. The grinding discs or pads are the costly part. I made some concrete worktops with fibres, lots of wet grinding and very pleased with the outcome.
  17. I used to regularly clean with a diamond pad and recoat with water proofer but not for 5 years now. I does take on more of a mottled surface visually overtime so not everyones taste. But it works here, a slight relief as most other materials in the build are very uniform, floors, doors, cills, etc. The concrete samples I received were so perfect they could have been moulded plastic. I do like a challenge and did test first.
  18. On my warm flat roof I fitted the VCL after the Rockwool in between the joists, then OSB, Batten, Plasterboard. I fitted 40mm Pavatherm above the joists.
  19. Up for an adventure? Homemade worktops, utility, kitchen and island. Biggest issues were moving from garage to kitchen. More compliments from visitors about the worktops than the rest of the house. Cost was 10% (excluding my time) of the quotes received. It was an enjoyable part of the build.
  20. Does depend a bit on the floor covering. Tiled wet room and the UFH is in use over the winter, the other bathrooms with cork flooring have never required heating.
  21. Recommend in bathrooms, electric UFH and electric towel radiators with accessible timers. We have wet UFH elsewhere but not used in the first floor bedrooms since moving in. Cooling must be considered. I plumbed for independent AC (Not implemented yet). As above keep it simple.
  22. Unfinished? Worth checking.
