Russdl
Everything posted by Russdl
Can home batteries help save the climate and save you money?
Russdl replied to SteamyTea's topic in Boffin's Corner
Our DD has just been reduced from £29.17/month to £8.00/month. A more accurate figure for our import over export would be £0.00/month We are only in this position because of solar PV, battery storage and an EV. The EV gives us access to cheap overnight rates that we utilise to run everything when required plus charging the house and car battery. I don’t obsess about RoI and I don’t ask anything else to return the investment (car, kitchen, hi-fi stuff etc etc etc) but on the current trajectory the solar and battery should be paid for in a total of 8 years. -
Ours is less than half of that, similar 'non standard' construction. We used Homeprotect
@marmic if you are going to do shutters do louvered shutters if the primary aim is to keep the sun out. Louvered shutters will still let the light in and you’ll only need to keep the sun out in the summer plus a month or two either side. If hinges are proving difficult to source, how about a rail system, a bit like out door curtains? The shutters won’t need to fit snugly if it’s just the suns UV you’re trying to defend against, so a louvered shutter each side of the window that you can just slide across when needs must would fit the bill, and be easy to open and close.
Not the same materials, however we had a cast iron seat on our porcelain tiles, when I moved it there were little rust marks where it had been stood. Nothing shifted those rust marks, tried everything… …and then I used a Brillo Pad, and that did it. May work for you?
Flextron bonded to standing seam versus 'normal' solar panels
Russdl replied to Bancroft's topic in Photovoltaics (PV)
I reckon it’s identical and as you say the distance from the ground that the photo is taken makes it look different. Not much though, smart set up. -
No, the panels pretty much sit on the standing seams using the S5 clamps that @Mr Blobby mentioned. There is no space underneath for birds. -
Slimline, I guess so. Innocuous, I’d say not. ours look over the back garden and can’t really be seen easily from anywhere. This is from a few years ago when everything was fresh, clean and unfinished. -
We looked at that system, years ago now, and eventually decided against it. If the bonding fails (and it’ll get bloody hot up there) or the panels fail what could you actually do about it with the roof in situ? Do you mean conventional panels? That’s what we went with in the end. Black PV panels mounted on the seams of a dark grey SS roof, looks nice IMO and no room for birds etc to get underneath the panels, but those panels hide a lot of expensive zinc. If you’re going with SS and dead against conventional panels then I’d say @JohnMo’s advice is spot on. Get a big battery and TOU tariff. -
3 months since it was last attended to but it’s time to change the pre filter again, it’s fan noise that alerts me more than any diary considerations. When the fan speed automatically increases in the mornings and evenings it’s generally inaudible but as time goes by it starts to become noticeable. The pre-filter is collecting so much airborne dust! It’s also letting the tiny flies through, but I can see the route they are (involuntarily?) taking so I’ll endeavour to get that sealed up before the refit. (I ran the hoover over the centre section to see how thick the dust and dirt was).
- 100 replies
- 5
- mvhr vents
- filter
I got them from my friendly local steel fabricator but I’m pretty sure they bought them in from a ‘C’ section joist manufacturer. Maybe from a company like this? https://albionsections.co.uk/c-section/
That would do it, or better still a timber ‘ladder’ shape of form work so you end up with serval separate blocks of sand/cement, 1 for each tile, then rain water could run around them and off the cill unhindered.
The still image from the video you posted above shows a mini concrete slab over the cill. You could do that and have the tiles resting on the concrete and then supported by pedestals as you move away from the cill.
Not sure I follow? I’m with @Conor pedestals would be a good way to go. If one or two sides of the patio are against the house, the remaining open sides could butt up to a dwarf wall or similar leaving no way in for them there rodents and leaving you with a patio at FFL and no issues with DPC
It’s very DIY’able Height of what floor? Internal floor? You can adjust the height of the pedestals from ‘not many mm’ to ‘quite a lot of mm’. You could probably cover the manhole with the tiles, hiding it completely, and lift the tiles when access is required. It takes seconds to lift and replace the tiles. For the cill you could make little mini slabs, the size of the pedestal foot, that sit on the cill and hold the front of the tile. Added bonus’s: Free draining round the perimeter of every tile. No grout to fail. No place for weeds to grow If you change your mind re shape/layout it’s very easy to rearrange.
@paro Have you considered a pedestal system for your large format tiles? You could put a French drain under the doors. I reckon that would solve all your issues.
As you’re with MBC I guess you’re going passive-ish? If you are (and you should, especially if you’re using MBC) don't put anything through the roof, even if the soil stack is effectively sealed it’ll be an unnecessary thermal bridge. As @Dunc says: That is the way to do it. That’s the way we did it. MBC will do what you ask, and do it well and the airtightness will be spot on, but if you’re trying to be ‘passive’ don’t have that tube going through the roof. Also, don’t put any ducting through the insulation if you can possibly avoid it (you can). Any large ducts through the insulation will degrade the insulation properties where the ducts are, and that’ll degrade the ‘passive’ aspect, the passive bit is worth fighting for, it pays dividends. There is always a better way so that you can keep everything inside the airtight layer, even if it may compromise a little bit of the interior space.
As above. As soon as outdoor temp exceeds desired indoor temp we shut all doors/windows and turn the MVHR down to its minimum setting. When the outdoor temp drops below indoor temp of an evening, we open all doors/windows and turn the MVHR up to max. Currently 33.7 degrees outside and 22.5 degrees inside. No active cooling but we do have external blinds which are game changers I reckon.
Well, I’m signed up and have my £25 bonus. Strange that there is no password to log in to ‘my account’ I guess yours is the same @JohnMo?
- 22 replies
- virtual power plant
- export tarriff
I should have used a Google search, BuildHub search didn’t find that. Thanks for the offer of a referral code but I’ve got one from my BiL so I’ll use that as he introduced me to this. At first glance I was pretty sceptical (who was going to pay £1/kWh!) and ignored it. After a closer look it seemed liked a good plan, as your experience shows, and decided I’ll give it a go.
- 22 replies
- export tarriff
Any recommendations for tanking this plant room?
Russdl replied to Great_scot_selfbuild's topic in General Flooring
If you were home. If the DHW cylinder sprung a leak why would it only loose 300L, wouldn’t the supply of water be endless until you isolated it? I reckon you are massively over thinking this, get a flood sensor (Shelly do one, I’m sure many others exist) If you spring a leak, unless it is some kind of catastrophic failure, then it’ll take a long time to empty that tank. A flood sensor will tell you the floor is getting wet whilst you’re miles away, you send the neighbours round to isolate the leaking component and continue your holiday. Small leak, dries relatively quickly, zero damage to the timber frame but the plasterboard may need some attention. -
I’m surprised that I can’t find anything on BuildHub regarding Axle Energy. They’ll pay £1/kWh for battery export and you don’t need to change your current supplier or hand over complete control of your battery. It looks a bit far fetched on first glance but digging into it, maybe not. They operate a virtual power plant (VPP) using thousands of domestic batteries and use that to fill generation gaps when the grid is under stress, that’s when energy prices are their highest hence they can pay the £1/kWh. Gary’s in to it. Anyone signed up yet? I think I may just dive in.
- 22 replies
- export tarriff
+1 to the “very” We have acoustic PB, resilient bars, rockwool and then the upper floor, underlay & carpets. Noise doesn’t really get through that.
