Russdl
Everything posted by Russdl
Just butted up to the architraves. Yep, good point. Our tiles are cut in half length ways and the factory edge faces up for exactly that reason. We have MDF in all the carpeted rooms, no problems whatsoever, no damage on external corners. No knots to prime. If done properly I see absolutely no issue with MDF (apart from the dust 😷)
Where we have tiled floors we used the same tile as the skirting. Looks good and hard as nails (obviously depends on the size of your tiles for this option to be considered).
Heat pump quote. What a joke.
Russdl replied to Selfbuildsarah's topic in New House & Self Build Design
I couldn’t agree more. But, if you do Heatpumps except you can’t do Heatpumps in new builds, that is pretty damn suspect. -
Good grief! Well, at least you found out in good time how professional those professionals are. -
Find metal studs behind metalised foil plasterboard?
Russdl replied to agbp55's topic in General Self Build & DIY Discussion
@Conor good point, I wrap the magnet in a dried out wet wipe to prevent marking the wall. -
Use a strong magnet (search Amazon) it will find all the screws attaching the plasterboard to the studwork and, if strong enough, the metal stud work itself. -
Octopus are reducing the feed in tariff is there an alternative?
Russdl replied to MikeSharp01's topic in Photovoltaics (PV)
I suspect this will be merged with another thread. I had the same email yesterday. -
Hmmmm. Why ceiling? Not the best way to hear stereo, plus, when the ceiling speaker is kapput the replacement probably won’t fit the hole. Personal choice obviously but there are some amazing shelf mounted wireless speakers that will link room to room and blow your socks off with the sonic quality. And when they die, just plug a replacement in.
There is a fair bit on the forum going back a good while regarding instant water heaters, I don’t know if you’ve searched yet but something there may answer your question. I have an instant water heater in the garage, puny little thing but produces nice tepid water at the end of a 20m cold run. As for the Willis heater option, that won’t automatically switch on when you run the tap so I’d suggest it would not be a straight forward solution for your problem (great for UFH though!)
What is this made of? Ceiling wood fibre board type stuff
Russdl replied to paro's topic in Building Materials
Don’t really know. If it’s definitely a wood fibre board it’s unlikely to contain asbestos but if there is any doubt you should get it tested. Asbestos was used in so many building products mid 20th century. -
Loft hatch or no loft hatch
That’s my point. That’s what we did. -
I was dead set against not making good use of the loft from a ‘wasting so much space’ point of view. Why go to so much effort to build a quality, individual house and then have a loft space that’s kind of part of the house and kind of not, and largely useless… …until the next owner spends multi thousands doing a loft conversion and finally bringing the loft into the fold. Christmas decorations (you may have a point). Some gym equipment and a couple of SUP’s (you may have a point again). Suitcases. MVHR. House battery. Kids LEGO and train sets in storage for grandkids (I’m back in the lead). -
Is it too late to incorporate it in to the thermal envelope and make it a proper useable loft? Ours is (MBC). Proper staircase going up to it, carpets etc. It is the loft, no windows but most definitely the loft but also a very useable part of the house and that’s where the Christmas decorations are. Along with lots of other stuff. It meant we had to have FD30 internal doors but it was worth that. -
Whistling through expensive Norrsken front door - Driving me crazy
Russdl replied to boxrick's topic in Doors & Door Frames
Cor that’s weird! Have you got a thermal camera you can point at the door to see if it’s a uniform temperature (thus uniformly filled)? -
I suspect they are all much of a muchness, I think I got all mine from Wickes who don’t seem to stock them anymore. Perfect for that level access with no drainage problems. Perfect for when you change your mind about the patio shape. Perfect for when you drop something really heavy on to a tile and damage it, 2 seconds to lift the tile and replace it.
Recommended Prodject Manager North Dorset
Russdl replied to Garry's topic in General Self Build & DIY Discussion
If my experience is anything to go by then mistakes will be made - nothing major, though every small mistake seems enormous in the moment. Stress will be high. But, without a doubt (for me, with zero prior knowledge) it was definitely the best decision. -
No recommendations apart from have you considered managing the project yourself? It’ll save you a bundle and you will more than likely pay much more attention to what is going on, and what soon needs to be going on, than any professional project manager. -
Probably bitten off more than I can chew...
Russdl replied to Allthegearnoidea's topic in Introduce Yourself
Do you need those? It’ll be plenty light enough in there with the windows you have planned, those roof lights will just add complexity and cost (and maybe leaks) and be noisy when it rains. Wracking my brain for a ‘positive’ but can’t come up with anything. -
Why not go for a flat roof, wouldn’t doing that solve your problem? EPDM is very DIYable. -
ASHP low pressure help pls
Russdl replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
Holy sh*t, and what a noise, has he left a spanner in the pump?? I’m sorry I can’t help in any way, but do go in all guns blazing tomorrow. -
Yep, this stuff. It was around -2 when I took the photo and been negative temps for about 8hrs I think. I didn’t think +10 was too bad but I haven’t done the sums (Steamy will do those I suspect). Actually the foam is probably a degree or so warmer than the +10, that coldest spot is the plastic Ubbink connector.
- 100 replies
- mvhr vents
- filter
It’s chilly and foggy outside and the ‘Mk2’ insulated pre filter box is performing admirably. The Ubink insulated ducting being the coldest thing in the MVHR room now. It did seem to seem to be noisier/running faster than normal. I had my suspicions that the pre filter mesh may be getting clogged again, I also had my suspicion that freezing fog may be having an adverse affect on the air permeability of the fine mesh… Turns out the freezing fog was playing a major role in restricting air flow.
- 100 replies
- 3
- mvhr vents
- filter
All went well in the end. I know some on here have had a good experience with Fermacell, they are probably more experienced in that kind of thing. Me, as a rank amateur, struggled. Good luck with whatever you end up doing.
- 78 replies
- dry lining
- fermacell
