BotusBuild
Everything posted by BotusBuild
What wall type should I use?
BotusBuild replied to BotusBuild's topic in General Self Build & DIY Discussion
Already happened 😀 -
Both those frames are seeding an idea -
The oak just wanted to join in 😀 -
Type 1 or recycled crushed for ground bearing slab?
BotusBuild replied to flanagaj's topic in Concrete
We had 75mm crusher run for our temporary access (still there 😀). We've had upto 32 ton lorries over it and its stood up well. I would use it for a slab foundation - probably will use it for the garage, with a 50 - 75mm sand layer and DPM before slab is poured -
Love that? How much? Do they do a single pitch roof? -
To me, priceless 😀 -
That must have taken some serious prompts into ChatGPT. Impressive
Update: (or "Christ, the f*&K up gets worse") We ordered a wall hung toilet. Having cut a hole in the skimmed plasterboard I was reminded that there was another pipe (behind that insulation in the picture) in the way of mounting the Grohe frame. Feck it. So, tomorrow, I pick up another bunch of bends and create the latest water flume (not open to the public for rides!!) to re-route that downpipe, from the cloakroom above, towards the corner (to the left) so the frame will fit in to allow the wall hung toilet to empty into the visible socket on the right in the picture. Also, the brown pipe will be replaced by a Y junction, and so the white waste pipe and black boss will also have to be refitted. Time for a🍺
Wrap it round that support post? DOOR _______<______ | ▪︎ (post) |______>______
So a bit of a revelation today on the trees front after a visit by a family friend who is an arborist. As a result we will be moving the garage so that the risk from falling trees is now much less than we had thought. Now thinking that ICF and steelframe are probably overkill and I think its between block work and stick build. I note that as of now no one has actually voted for stick build although @Mr Punter commented positively about it. -
Sunken Garden and Rain Water?
BotusBuild replied to Paulgwat's topic in Landscaping, Decking & Patios
Paul, Thanks for adding the context. One question I do have is where is the storm water drain in relation to where you plan to place the "sump" in the original post. You say 1m up, but is there any part of it that you get to that would be lower than the gully? I know it that may mean "tapping" into the pipe and would be awkward. Just asking. It looks like the pump you mention has capacity to move the water faster than it might accumulate. I would, for likely future storm event size increases, tack two of those sump's together. When you dig down can you put a DPM around the outside of the wall you intend to build to stop water coming through so that you are only concerned with rain that falls on the area? -
It is to be commended that you are trying to be considerate to your neighbours, but, this is the way the gardens were designed in the first place, and those around you must already know this is a possibility. Unless you have received some legal notification NOT to sit in your garden and NOT to overlook anyone, then avoid all this unnecessary cost and get on with enjoying YOUR outside space. 🙂 -
We will be embarking on a new garage build, and my mind is totally undecided on what wall build type to use. No doubt I'm going to be as confused after this post as I am already 🙂 I've added a poll to this post. It will have a 150mm raft foundation with a ring beam. This is to protect trees roots as best we can. Did I mention trees? Trees in close proximity on 3 sides so risk of falling branches and/or whole trees. To house classic car(s) and a four post ramp. Will be used as a garage was always intended to be used, not as a shed!
Slow progress towards a new home
BotusBuild commented on BotusBuild's blog entry in South East Cornwall Low Energy build
We're not ditching it, just able to delay when its installed -
BotusBuild posted a blog entry in South East Cornwall Low Energy build
Well, it's been nearly 9 months since we moved in, and I didn't leave a list last time, so here are the parts of the last list that still needed work. As you will see there still remains a lot of stuff to do. You'll soon learn why they're still here 😞 more stone work - still on the list but much reduced rainwater soakaways - still on the list rainwater collection system - decided after deliberating a lot to leave this out for now as it's not a condition backfilling - partly done, still on the list concrete lego brick retaining wall - delivered, to be fitted Flooring - en-suite and "attic" room left to do Wood cladding - still on the list Fit internal doors - one last door to do Fit en suite - basin and bog outstanding Build MY garage - still on the list A green roof system, because its on the planning application, and may be required for certificate of completion (unless someone can enlighten me as to how to avoid this, and be able to delay the installation) - still on the list, but good news on the completion element for this below. Back in August 2025 we moved into a building site, and worked hard to get the remaining bedrooms completed before our first Christmas for which SWMBO had invited MY family. Not sure whether to label this action as bullying, blackmail, fraud, spousal abuse or whether another specific crime was committed. But, we got there, and a fantastic Christmas was had. Also during this time, we managed to secure a buyer for our old house. We had decided to stop calling it home to start the process of removing 29 years of emotional attachment to the place in which we brought up our two children, and in December we removed pretty much all the remaining furniture in readiness for Christmas and what we thought would be a completion on the sale in January/February of 2026. You may recall me asking questions about a retaining wall which was holding up the new buyers getting a mortgage. Now, this wall was not a part of the house but on our boundary about 2 feet or so away from the side wall of the house. It has a crack in it and the lender wanted it repaired. We had requested an SE to come give us a report, hopefully to tell the lender to stop being a d1ck, and we had arranged to meet them on the 6th January. We arrived the day before to find it difficult to open the front door because there was some plasterboard behind it which had come from the landing ceiling at the top of the stairs. This had been caused by a leaking water pipe in the loft. Subsequent water bills showed that 28m3 of water had come through the ceiling - we now had a major water leak insurance claim repair to deal with. And the upshot of the SE visit the following day was they said it did need fixing. B0110cks!! So, now instead of a completion in Jan/Feb, we were looking at a completion in 3-6 months. We then found out that the retaining wall was our liability, and not the people who owned the land behind it. This put a huge dent in our plans. Everything we had planned to do in the first half of 2026 (work on the house and a ski trip) went on hold as we got someone in to repair the wall (in March, once the rain had stopped) and to deal with the insurance company who thought it was a great idea to appoint two separate companies to complete the drying out/repair work - WHAT COULD GO WRONG? We sat down, and reworked our plans for work on the house. This has been limited to work that we could carry out with little spend because either it was something outside in the "garden" (read mud bath), we already had the materials on site, or the materials required were not hugely expensive. What have we been up to in between complaining to the insurance company about the lack of co-ordination and progress (WHO WOULD HAVE THOUGHT?) We bought parts to start finishing off the rainwater drainage pipework, which also allowed us to do our first bit of hard landscaping, some steps down to one side of the house, and starting off the path as well. We still had a lot of stone cladding to complete, so once the weather improved, I set to completing most of this. There are still a few odd bits and pieces to do once the balcony and connecting bridge have been completed (one of the large ticket items that is on hold). The other main area of work has been the en-suite bathroom, where we spent a little bit of savings and created a service wall on two sides, got it plastered and painted, and also installed the walk-in shower. After a bit of back and forth, SWMBO agreed to a wall hung toilet pan (thank you to those who responded to my cry for help). So, the en-suite requires said bog, a basin and vanity, tiling behind the basin, flooring and a door to be completed. All materials on site or on order, and the plan is to get on with that over the next few weeks. So, where does all this leave us? Well, the bits of good news we've had:- - our BCO visited just before Christmas and gave us a list of things he'd like to see before he issued a completion certificate, and on that list found that the green roof was not required to be fitted, but just some documentation about what we proposed to put up there. I know what many will think, but we will probably still install one at some point, but it does mean we can delay installing it until after completion. - I mentioned we secured a buyer for the old house. Well, they have stuck around through all our tribulations and we will be completing on June 5th. Come mid June we should have the following major items to complete, and the funds to do them: Balcony including balustrade Connecting bridge to balcony Balustrade by internal stairwell Exterior porch floor rainwater soakaways - still on the list concrete lego brick retaining wall and backfilling Flooring - "attic" room left to do Wood cladding Finish the en suite - as outlined above Build MY garage - still on the list A green roof system Once all that is done we might also be ready to clear the site of the touring caravan we used for the first four years of weekends and holiday time we spent building the house and a lot of left over building materials. I'm glad to say there is very little of that as I resisted the "order 10% more than you need" rule, and am pleased to say it only bit me twice in extra delivery charges. This has meant we have incurred zero cost for skips/clearaway etc. and, no, we have not buried it all in a very big hole in the 3 acre field we bought. There's still a lot to do, but as we approach June 5th with lightened hearts, we have a much clearer view of some form of end game, with may hours to be spent creating a new garden around our NEW HOME!! -
What battery drill should I buy? The choice is bewildering.
BotusBuild replied to jimseng's topic in Tools & Equipment
I don't know. Never had to try it
