scottishjohn
    23
  1. If you seed it you will have to cut it and maybe it will get damaged with building works I would leave it till you are done then weed kill it and level out and sow it then you could strim the thstles +nettles in between time
  2. exporting without a battery you are going to be stuck with low rates lookat octopus FLUX you can fill up your own battery between 2 and5 in morning for 4.42p and sell it back to them later inthe day between 16-1900 hrs for 27p--even in wnter when your panels are not doing much it could still be a big winner you need to check your postcode cos the rates are different for other parts of contry I would not have gone for PV without a battery --thats where you can start to make the money back
  3. Iwould worry that it is too thick and will take foreverto dry out Icould be totally wrong just when mine was done it took 6weeks with underfloor on to get down to the 3% moisture the floorers wanted to lay stick down LVT and that was after they had ground it all to get it toally flat but the final job showed they knew what they were doing best trade on the job by far that floor is made up from hundreds of little bits only big bits are thesquretiles -even the border is seperate bits
  4. Iundertsand what you are sying ,but I can from experince that is not the case when i did my tero underfloor 25years ago ,very littlechoices and ifno was about so I routed all the cipboard floors --1km of them amdlined the groves with foil and then covered it with 6m ply -to put some strength back in in it the piping was Keetriple tube --a rubber syatem whereyou have 2 feed pipes and one return all fixed together to make a 10mm thick and 30mm wideassembly Ithen covered underside of floor with space blanket 40mm thick asI had spce to get underfloor --not bad but there were elaks as its just not possible to get it air tight On top of the floor i use my old axminster carpet --they could not tell me what the tog value --nobody had ever asked that even with the underlay it worked--not perfectly but worked ok just took time to vcome through 3 years later i conveted to a tiled floor the main difference was the speed in the temp change In some ways that type of system could be looked on as better ,because you are not heating up a BIG slab then if the days are not consistantly cold you do not get any overheating of house I know that maybe a novel idea to most --but we live in a country where the daily temps can be totally different ! day to the next the upstairs i did what this man has done and it was not a success as hot air leaked out the ends of the joists and keeping it up tight to the floor covering was not good oor easy at that time i was using a solar thermal cylinder 40 panels along with an lpg boiler it worked OK then later on iwent for an ASHP which worked out better as I saved the total cpost of the lpg but In sumatiom Ishould have saved myself alot of grief and fitted and over floor system in the first place.but there were not many out there then to choose from a mistake on my part ishould have gone that way I still like solar thermal -but the downside is the cost of storag no problem getting enough hot water for the year --butyou would need a swimming pool in the basement- kingspan tech calculated for my house ,after giving him all th info that i would need at least 15000litres for it to work and that would be 3buffer tnaks with different temp levels to get everything the sun could do through out the day and building aninsulated tank that big would not be cheap Idid have some problems caused by lack of storage with the solar--#look at tank temp at 8.00 inthe morning --17c --after running underfloor all night by lunch time on a summers day the t300litre tank would boiling ,as i hade specified non regulated vacumn tube but it just shows there is heat in the sun even in scotland --problem was lack of staged temp storage
  5. If iwere doing it again iwould use what they have inmy new house for upstairs in your case for all of it https://theufhgroup.co.uk/products/tekwarm-foiled-400-kpa-ufh-board-1200mm-x-600mm this is covered with t+g cement board , thats the heat sink,then floor covering of choice total system thickness will be around 40-50mm mount directly onto your origina lfloor boards you will have no air leaks to underside and insulation as well and ump the upstairs rads if you want to do it all you can doall that and still live in the place just need to trim your doors
  6. I concur habing done a similar job on old house you will be loosing the heat to drafts andlack of hard contact to the floor. the insulation needs to HARD up to thespreader plates and pushing thepiping hard onto the floor so no quick fix for this rip up floor and do it right then you need to balance the flow of the rrads ,cos water will go easiest way --so turning the flow down on them might help as well thr UFH will never heat up to same as rads and really rads if are original ones from gas boiler will not be big enough --cos of the reduced flow temp from ASHP--genrally they need to twice as big ,cos tmep from UFH will be around 30 and temp fromgas boiler to rads would be 50+ so they need to be much larger surface area to give same heat pout put Iwould not worry too much onthat at this time you need tosort out the downstairs FH problems first and then later you can maybe chane upstairs
  7. taking into account all said above the simple answer is build a fence on the boundary ,then they have to set back their wall or destroy your fence --that will be a clear case of trespass how close is your building to the boundary -will there be an issue if maintaince is needed by either party ? I certainly would never build closer than 1 m from boundary i understand in towns space is at a premium --butwants to be at least some gap or that will maybe stop some expansion plans you or next owner might have and how high is htis wall remebering founds need to be twice the wall width as a general rule--which means they will be right over the boundary and could preclude any expansion on your side later and now is the time to make a stand -not once building starts I have been through this in a commercial application and it started with the deeds of both properties which had boundaries in different postions due to the properties being old and the descriptions in the deeds of the boundary so that stopped everything for some time whilst proper surveys were done--but it did get legal and eventually a surveyor had to knock pins into the ground to show the agreed boundary I am guessing your deeds are not 200years old as mine were --so should have actual dimensions of them ? so as i said to start with iwould be errecting a wall or fence onthe boundary line and he then has alter his plans --unless he will move his wall back its all a game of poker in the end and if you can hold him up he might become more sensible on placement of wall
  8. thats not going to do alot for the view Ihad an eagle owl on my workshop roof to stop the seagulls and rooks going on it and dropping things and crapping on the sales cars lined up in front -- it worked for a while -but they got used to it going to try kids toy windmills in plant pots --hopefully that will deter them
  9. this the thing most people would notspot the difference between ravens ,rooks ,carrion crows and jackdaws the only members of the corvid family that are obviously different are magpies and jays but all of them would go for soft old fashioned putty for sure my widows of ocurse are modern double glazed the prime thought is they are attacking thier own reflection but how to stop them without iradication
  10. windows been in for over a year and all of a sudden I have suicide attacks mainly on the big bifolds by ravens to such an amount that they are drawing blood and leaving windows covered in birdspit =blood and below them piles of shite I witnessed one attack whilst we were having an evening meal ## this was two ravens attacking together ,til i got up and waved my arms about ravens are supposed to be the smartest birds around last night ,when we were not here they attacked the front one again even though there is scaffolding in front of it ( forsolar installation) and again left blood on the window the first obvious solution is shoot them # but they are a protected species ,then they are also very cunning and getting in range would be a very hard job with a shot gun so anyone had same problem and a suitable solution
  11. giv energy batteries have a 15years warranty worth a look made in uk
  12. I cannot find anywhere that covers it maybe me not searching gov.uk correctly
  13. a bit late but from my dealings with openreach and me fitting my own ducting and junction boxs --max they will go it is 150m -as the "cobra" they use is 160m -no bends within 2 m of the end you are working from and they supplied me with all the stuff and nice slow 90degree bends that are a tight fit on thier ducting the boxs how ever are major over kill need to dig down 400mm --and in my stoney ground to fit them and they have a concrete lid --so they use same for everything that is going into a footpath or road way waiting for them to come and csble it now -but they still will not direct to fibre --copper first then fibre later it is political decision of thier part ,so the fibre team do not get billed with ducting etc-or thats what i am told
  14. my guess is YES as its already been extended got to be worth a conversation with planning before you do anything
  15. why not tank the inside?
  16. slates look very old and fragile# exect some to break if they come back and do it as suggested maybe thats why they did it that way to save you the expense who knows how far back they would have to go once they start removing slates ? couldd maybe end pu with a complete reslate there are cerainly adhesives that could be used under the lead ,once you clean the slates that would work
  17. I have Samsung at new house-- 16kw unit and depending on how hard it works it is near silent to acceptably loud as its outside
  18. what cleaning products and soap powders are ok with a treament plant so as not to kill the bacteria anybody that has used for for some time --what are you using ?
  19. you only show one baton far better to use cross batons ,then there is no ledge for moisture or crap to build up on over the years single batons with osb sheeting caused my house to rot as all winter the dust etc were damp ,,so 25 years on i had a problem on the north side of the roof the extra cost of double batons is very small and also gives you a bigger gap
  20. or below them change the Pb for insulated PB and loose maybe 35mm in head room,and you got a warm roof as it already has insulation above and only rafters are not insulated,but to be fair wood is a pretty good insulator
  21. It is not really a cold roof that is where all the occupied space is insulated from all of the loft and roof --eg flat ceilings I am guessing as it has pB then it is occupieed below the insulated roof section I would call that a wram roof so back to your question I do not see any need to slit it as there will always be low pressure on one side of the house due to winds ,heating of roof etc etc so it should cause enough of a draft to pull from one side to the other,just make sure there are no cold bits where the eaves meets the walls
