scottishjohn
how will you accomplish this the weight of even small stones like i did my firepond will be large and i do not think they will stay on if you intend to stick them to the straw bales then there is the problem of finding enough stones of suitable thick ness for a large area i used approx 2 tons of granite pieces + 2tons of sand + 12 bags cement to fix them and that is not to a full wall height as you will have with a house and it is very time consuming and can only be done when it is dry and need covering for at least 2days to make sure the mortar does not get washed by rain so for full nouse you will be taking 4 times that amount I used them as i have a very large volume of them on site from previous quarrying and granite set making in the past the only way i see it wroking is if you clad outside first with exterior ply and attch a mesh to it to give something for the mortar to stick to yes you could buy stone cladding panels ,but not cheap and they would require a solid frame work to fix them to I have no problem with straw as insulation where you are it will be good if thick enough ,but not as the outer wall which will still need wood for window and door openings .
so are you saying that to get total drop from one side of house to other you add all those dinensions together? which would be 115mm drop ? have you measured the other way as well?
but twice the protection
I maybe read it wrong I thought you wanted to make the wall solid and water proof 6-1 will not make it water proof you either want it to stop dampness or let it breath make your mind up if you do as you say you are then relying on your slurry -to be the water proof barrier the3-1 mix with water proof addative will make your wal lstrong and water proof basically same mix as you would cement rendr the outside is the outside lime mortar ,if so it will let the water out that way and not get to inside
like most surveys the questions are loaded to get the answers they want when common sense will give anybody with a half a brain the answers
Scotland - Ban on stoves in new build houses lifted.
scottishjohn replied to ProDave's topic in Stoves, Fires & Fireplaces
yep I have had a cheap chineese generator for years and if we get a power cut just turn off at mains and plug it into a 13amp socket fine to run everything but the cooker will maybe up grade it for new house with a bigger one so it can run ASHP easily ,but to be honest Ihave akready seen how long it takes the house to cool down when ASHP is turned off ,and that is a couple of days amd that was from 22c to 16c it was on to dry out the subfloor for the floor fitters to start work -
Am I mad? Plan for amtico stick down in wet room..
scottishjohn replied to CalvinHobbes's topic in Floor Tiles & Tiling
from watching my floor fitters doing my LVT floors they would not consider it without a self leveling layer to start with and then lots of time spent checking it for actual level and cleaning every spec of dust then and only then did they start laying tiles and use a heavy garden roller type thing to make sure they are down flat after laying no UFH for 2 days at least ,then very low heat for a week to make sure everything is happy OHH and a humdity reading of less than 3,7% in subfloor before self levelling applied more than that could cause lifting of tiles over time with trapped moisture trying to get out -
and it will be a cold roof system?
my advice --for what its worth don,t be stingy bugger and rake out any loose mortar then redner it with aproper mix like 3 -1 with waterproofer and only pva or SBR what you are going to do that day after severe dedusting and washing -stone is not very pourous like blocks yes let it just dry but not dry for days before rendering as it will not really bond as welland might just skin I have bo knoeledge of use of "tanking slurry" but can confirrm two coats of ehat isay is good enough to make above ground fish ponds and in my case a firepond
that is fine if you do not have sarking board or plywood sheeting --but not with it and certainlt not in high wind areas like scotland and cetrainly not if you are using a warm roof shit and moisture gathers up the back of them over time and causes rot Iwould worry using modern flimsey trusses without plywood sheeting to give wind bracing
are you really sure on your measurements if it was 10mm in600mm length it would be a 1 degree slope ,but you are saying maybe nearly twice that thiis is from the simple inflfight avaition navigation correction rule-- 1in60rule 1mile of track after 60miles =1degree off track borrow a laser level and check on outside of house to measure exact drop from one side to other or buy a cheap water level kit and check it about £10 for one make sure you get all air bubbles out of piping before use it was good enough for the egytpians to lay foundations for the pyramids i used one to level my wall heads when rebuiling them for the fixing of wall head plates and when the builders arrived to put the roof trusses on they checked with laser and it was spot on to 1mm over 25m length and 8m width of building
and should be used as animal bedding ,not to build houses in a very wet and windy part of the world there is a reason why they built crofters cottages from stone when they did not have the mechanical means of moving heavy objects easily 2-300 years ago and it is why alot of them are still standing us it to build an insulating inner wall by all means but not as an outer weather shield
because they are lazy, tight fisted idiots there are no technical advantaghes to use single batons ,only disadvantages
must be plenty of derilict stone buildings to get stone from build with that maybe like a drystone wall but with mortar and then coat it with render in and out and an insulted internal structure how ever you like ,with a cavity stone lasts forever I am presuming this will be a self build ,so buidling instone you can stop and start as you like and build as time allows
500mm that would be very thick 300-350 is more like it in most builds yuo do not actually need a brick outer skin if you want you could do it all in wood as in sips construction I f you areself build and can lay blocks ,block construction in and out will be cheapest and can get you want ever you want I would say.my own opinion that wood cladding outside is more likley to be a problem over time if attention to detail and quality of the cladding is not as good as promised yes itis very much in fashion at this time but there are not many 200year pld wood houses around in our climate scandinacia has cold but dry winters nad hot summers ,we have wet ones annd that includes the summers sometimes having lived in s/w scotland for 40 years nowI have seen even the rendering and stone walls can go green on the sides of the house not facing south ,so hence my dislike for wood cladding forestry commsion used to build all their office and workshop structures from wood ,but not anymore as they have found the problems
road planings --experience of them over time AS
scottishjohn replied to scottishjohn's topic in Driveways
at least 10years ago this is why resurfacing of roads does not last as it used to older type it was semi melted on hot days and healed up ,but not so with new type add to that the fact that they only lay it in 35mm thickness and even on wet days when it never gets a chance to bond to the lower layers and we have a recipe to keep the pot hole repaiirers in biz for ever it amazes me how they think it can work laying a much cooler tarmac than they ysed to on to wet foads and expect it too last you used see flames coming out from under the tarmac laying mchine as they dried out and heated the road as the tarmac was laid ,you never see that now as they don,t heat the road , with flames andwhich used to heat and blow the water away how could anyone think laying tarmac on a cold wet day is going to make it bond to the layer below, hence why you see patchs of it coming off down to the layer below and then along comes the patching crew and a year later the patches peel off the reason a tarmac man gve me for the 35mm layer is that if they laid it at 50mm - and it came off it would then be classed as a pot hole and would have to be repaired much sooner under EU regs one of my pet hates --I have been watching sections of road where the old surface has been replaced more than once in the past few years and yet th eold sections which were ok are still ok proof it it were needed that the new product is not as good as the old type all in the name of polution control to cut down the petrolium based tarmac emmisions add to that the change some years ago of not allowing use of granite chips in tarmac because it was said they made the surface less gripper cos they were hard and noisier again EU regs yes granite chips in tarmac were and are harder and made the surface last longer I know this is fact because that was the main reason that the quarry I am on was shut in 1992 althoug the quarry had superb stone for building and monumental work ,that produced lots of waste which went into tarmac production and super white gravle chips for drives and pathways along with granite sand for use in concrete for sewers and harbour constuction flod defences as it does not wear away the same as it was and still is the best for constant contact with water granite sand is now well over £120 per ton as opposed to normal building sand at less than half the price and instead of granite they turned to whinstone for tarmac when all said and done you drive to grip on the road and modern tyres are much gripper than they used to be anyway -
at least 10years ago -
how long ago was it you did this as newer type of tarmac is a chemical setting type-doyou cannot haet it like old tarmac and use it again that is my worry that newer types of plannings will not bond together as older type which came from an old road made with real tarmac thanks for the replies boys as for cost, quite cheap here £15 a ton if you collect or £100 a truck load ,so I am told -
as title what experience deos anyone have of them over time and how thick can you lay them so they will not move about with traffic
Wall tiles out of level / not flat surface
scottishjohn replied to MortarThePoint's topic in Wall Tiles & Tiling
been here on my present house when i made an ensuite from an built inwardrobe and some of the bedroom I made the foolish assumption that the wall, as it was plasterboard would be flat in both directions my solution was to use lots of tile adhesive as a basecoat to get it right once i had removed the tiling to start again the lesson is assume sod all and check before hand with a long straight edge and repair anything first before starting and is why a professional will always want to use self levelling before starting to lay a tiled or LVT floor as the planks are very thin this was 20years ago and I made same mistake when useing 600mm floor tiles in living room 6mx5m bigger the tiles the less tolerance you have to get edges correct again in a rush to get on and we were living in house as well it started off fine but as i got across the floor it got worse and the thought of wasting half the tiles and time repairing it after removing tiles --I just carried on and got more bags of adhesive I ended up using twice the adhesive as it should have done it get it right the house was not new and the chipboard flooring and joists were not level and had bowed between the joists and probably not helped by me sinking UFH pipes into the flooring and sheeting with 6mm ply over top to put strength back in floor and this had been running UFH with carpet over it for a couple of years -- I checked it when I did the ufh ,but did not check again before tiling we all live and learn -
seems to me this is a problem you brought on your self by not keeping them to the boundary in the fist place good luck
Solid wall Internal Wall Insulation (Warm Batten) design
scottishjohn replied to Annker's topic in Heat Insulation
that will be internal walls which are dried from both sides from heat in house for 100years the outer walls are different as one side can be wet +cold and other heated by internals of house and thats where you will get condensation if the dew point is reached kile the inside of a single glazed window on a cold morning. I doubt you will have any DPC in a victorian house so thats the other place capillary action from water in the ground sucks it up which is why we have a DPC to stop it happening and why with no DPC it pays to have ground level outside house a lot lower than floor l there was reason why expnsive big old houses had steps up to entrance level, even if they did not have cellars to keep floor joists etc well above any rising damp from the foundations as genaral rule rising damp will only go up to a metre maximum on modern house with concrete floors etc the floor level will always be at least 150mm minimum above the ground level outside if not then lots of french drains and pea gravel to soak away any water from the walls look at the detail for dpc under a slab and where it finishs inside the walls above the floor level into the walls usually where the outer wall DPC is and your TF kit starts on dwarf walls -
you do not need air bricks ,and air bricks should be ducted through both walls to under side of house to vent under the suspended floors ,not just in outer layer to make a draft up the cavity just let it happen naturally --warm air rises and so takes moisture with it and we are talking about an old house which we want to dry out or keep it dry at back of wall as for fire risk you fit intumescent fire stops which only expand if there is a fire and blocks off the cavity as for getting condensation on VCL--thats shows your insulation is not good enough and or lots of air leaks through it -if correct the insulation should stop any chance of condensation assuming you are not hydroponically growing weed inside -
so you need to make a clear passage way for air to go from under floor behind the lathes and right up to the loft if you want somewhere for the moisture to evaporate out on well built houses the floor boards stop short of the walls to allow a gap and the plaster to fall into the space under the floor If you intend to remove all the old lathes ect and build a stud wall instead then it it easy to fit a vaour barrier onto the studs after the pir infill , just make sure you have this air gap top to bottom of the house and through the first floor into the eaves or cold roof space my old house was TF with brick outer venitng into cold roof being clever ,as i thought i blocked up the gap at top of wall into roof space the roof is sheeted plywood to my suprise when i checked it after one winter i found the north side of the roof was showing black mould on inside of ply wood unblocked the gap i had filled and it stopped so that is where my understanding of need for ventilation in the cavity comes from are you sure you cannot accept loosing al ittlem ore space on outer walls , and use 100mm studs and then use insulated plasterboard to bump up the insulation smae goes for ceiling into roof space vapour barrier with insulation above and get it much more air tight will you really notice a loss of another 100mm for all the beneifts it will bring very easy job to construction stud walls insdie and between the exsisting ceiling and floors,rembering to cut gaps out of floor boards behind the stud walls if there is not sufficent gap -
replacing asbestos cement soffits
scottishjohn replied to Del-inquent's topic in Roofing, Tiling & Slating
on your head then you have been informed
